Definitive Ranger/Explorer Frame Swap Vehicle List
Discussion in 'Off Topic Hot Rods & Customs' started by Abomination, Aug 18, 2008.
  1. Zapato
    Zapato
    95 explorer ch***is with 98 up Ranger trying to end up with a 2wd setup or anything else mustang etc....
  2. borntowrench
    borntowrench
    Just take the front diff and the axles out, instant 2WD
  3. fast Ed
    fast Ed
    That might take some fabbing or modifying anyway, since the Explorer frame never had the 2WD Ranger style suspension. Unless you can find measurements in a collision manual or something, you may to have to just eyeball it yourself to know for sure.
    We don't have a bodyshop at the dealership I work at, otherwise I might be able to get some more info.
    cheers
    Ed N.
  4. Eddie
    Eddie
    from Georgia
    03 Explorer, 4 door, 2wd, 4.0 SOHC, AOD:
    Width over centerline of rear axle is approx.47 inches (as measured from outside to outside of spring seat socket since that is wider than the frame itself).
    Main portion of frame is approx. 45&1/2 inches overall width as measured about 9 inches rear of leading edge of front door to 17 inches forward of rear wheel opening. This portion of frame appears to be level and straight from front to rear.
    Track width measures 60&1/2 inch with stock wheels however this was measured with wheels hanging (on a frame lift) so would be somewhat more when loaded and on ground.
    I don't know how to post pics, so if anyone wants them PM me your e-mail address and tell me what you need and you post them. BTW, this thing is for sale.
    Hope this helps, Eddie
  5. MScott
    MScott
    from Ontario
    Interesting thread. There was mention of a 34-6 Ford body for the Ranger ch***is. US Body also have a fibergl*** 40-47 body available which is designed to fit on a 83-93 Ranger ch***is. Their web site is http://www.usbody.com/
  6. Frosty21
    Frosty21
    from KY
    I got a '94 Eddie Bauer edition, 4x4, 4.0 v6, given to me. How much trouble is the body to remove from these things?
  7. countryboy1
    countryboy1
    from Barrie
    "I got a '94 Eddie Bauer edition, 4x4, 4.0 v6, given to me. How much trouble is the body to remove from these things? "
    Frosty21, I did a complete swap of an explorer (1998 sport, and turned it into a 99 XLT) they were very simple to removed the body, i had everything tore down it about 8 hours, i did not save many of the parts from the 98 though as it was a wreck only the motor and ****** and on fender were saved. I also used a loader to lift the body off, simply take the rear window out and slide the loaders forks through and lift, and you are left with a rolling ch***is.
    <!-- / message -->
  8. countryboy1
    countryboy1
    from Barrie
    I have a frame from a 1999 xlt still, what are the thoughts out there on Mounting a 1950 dodge on it, I know the mopar fellows may have a coronary over using a motor/drive train from ford to power a dodge, but i am considering it let me know what anyone thinks, or even better if anyone has ever attempted or done it for the dodge
  9. Frosty21
    Frosty21
    from KY
    The motor is blown up, and the transmission is out. I don't think its worth stripping the body off for the rolling ch***is, as its the pre-torsion bar 4wd set-up.
  10. olyrailman
    olyrailman
    Say will a 49 F2 fit on a 1998 Ranger Frame????
  11. 48prerunner
    48prerunner
    from ny
    I have a 48 f-1 with f-2 fenders mounted up on a 91 4 door explorer frame just ahd to cut the distance of the stake pockets off the bed and shorten it up. Used the explorer pedals and steering column also.
  12. Abomination
    Abomination
    Maybe not your bed...
    ~Jason
  13. wrong generation
    wrong generation
    from new jersey
    is there any one that actualy has a 53-54 f100/f250 mounted on an explorer or ranger ch***is ?
  14. chrisser
    chrisser
    I saw this link and mistakenly thought you had to send for the pdfs
    turns out that when you click on the link for a model year (like 1999) and ignore the verbiage, there's a table of contents link. If you click that, you get to the PDFs.
    I don't know if anyone else made the same mistake I did.
    Here's a direct link to '99 ranger drawings and data:
    https://www.fleet.ford.com/truckBBAS/non-html/1999/62_63.pdf
    and Explorer
    https://www.fleet.ford.com/truckBBAS/non-html/1999/60_61.pdf
    I've been looking at S-10 swaps for a project, and while they're otherwise a preetty good match, the steering box up front was a major obstacle. I believe the ranger/explorer are R&P.
    The info isn't as nicely presented as the GM books for the S-10, but still better than having to go to the junkyard with a tape and a pad of paper...
  15. Bigcheese327
    Bigcheese327
    Not for all years, though, right? I have an '86 B2600 and I don't think it's Ford based.
    -Dave
  16. 62rebel
    62rebel
    so, i'm understanding that my gen1 exploder with it's blown POS A4LD ****** might be useful after all?
    i'm more than willing to ditch ALL the engine/trans portion and slip a 302/C4 in it if possible, and slide it under something more interesting.
    if only to have more modern brakes and steering.
  17. What's the width and length on those early rangers think they would be good for a track roadster setup
  18. Wild_47
    Wild_47
    Whew, Finally read through the whole thread. Thought I would share my explorer swap.
    91 4 door Explorer 4x4, 47 ford cab and hood, 41 merc front fenders.
    Fits pretty good for as far as I have gotten. I cut and raised the floor under the seats 3" to allow some clearance for the transfer case. Used parts of the firewall from the explorer while mating up the firewall and floor. Still need to slide the cab and fenders back another inch or two but its lining up not too bad.
  19. Thread three weeks old but oh well.I read where it is suggested not to put a RANGER or s-10 frame under a FALCON. I have a '62 RANCHERO and would like a RANGER frame for modern supension.It was said that on frame would be on top the other. How about using RANGER floor pans and wheel base adjustment by changes to the quarter panel? Bitting off to much? Thanks Ken N.
  20. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Wild 47 ----I like that 41 merc sheet metal combined with your cab !!!! nice chop too!!!!!
  21. koolkemp
    koolkemp
    If I had to do this swap I would cut everything out of the rancheros underneath channel it over the new ch***is and build new floors front to back, lottsa work
  22. dw6770
    dw6770
    from Wisconsin
    Has anyone tried a 1937 Ford Coupe on a Explorer or Ranger Frame? I have a 37 coupe with a bad frame. Thought I would try a 95-01 Explorer.
  23. hotroddon
    hotroddon
    My 91 Explorer 2wd had the Twin I Beam, same as pre 98 Ranger. I used Suspension Techniques drop beams to lower it.
  24. Nick_R_23
    Nick_R_23
    Is there a difference in the frames/suspension of a V8 Explorer from 95-01 versus whatever else they came with (v6's?) ?
    How well do you guys think an Advance Design Chevy 1/2 ton would work on a 95-01 2wd V8 Explorer frame? Id have to extend the frame of course. Id had another frame planned to swap under my truck, but after seeing pics of the Explorer frame in this thread, I think one of those might work better.
  25. CHARLIE_HUSTLE
    CHARLIE_HUSTLE
    from CHICO CA.
    Ive got a '59 f100 & would love the upgrade of brakes , steering & suspension. Anyone know if this will work for me? How close to bolt on can i expect?
  26. Abomination
    Abomination
    The S-10 ch***is swap sister thread was closed yesterday. FYI.
  27. SeniorBliss
    SeniorBliss
    from SLC,UT
    I have a '42 Ford super deluxe and want a modern ch***is.
    I have 2 enigne/trans options
    1. Brand new small block Buick v6 that is a high performance motor and a Turbo 350 trans w/3500 rpm stall (bought for a song on a whim). They are both ZERO miles, car-show quality but NOT Ford.
    2. 5.0 V8 and AOD from a 90's Lincoln with about 80K on it.
    Best options? Thought?
  28. joelocke
    joelocke
    from Tucson
    OK, I'm actively shopping for an explorer to swap the ch***is out for my 48 ford coupe. I understand that the easy engine hook-up would be 95-early 97 four door, v8, with 2wd. I also am under the impression that there are aftermarket wireing harnesses that will allow me to use a newer model. Questions:
    1) are my ***umptions correct so far?
    2) How new can I go before the frame changes? I understand the very new Explorer's are unibodys, so obviously I cant go that new.
    Thanks,
    Joe
  29. completogrande
    completogrande
    from edmonton
    hey guys.. ok so im totally new to all of this,....this site... these cars.... etc.. but i bought a 47 ford 1 ton...... and after seeing all the cool stuff.... i was thinking of just trying to swap the ch***is.... i finally got the flat head running and i rebuilt the carb and fuel pump.. its running now so cool.. i got a stuck waterpump.. but might have free'd it up today...now...but with the split rims... brakes.. suspension..... here is the question.. i want to drive the thing and although the flat head is cool.... will the ranger or explorer ch***is work....? do you keep the colum do you got to relocate stuff. do you use the same firewall???? these are all questions i have no idea about.. ill take a pic.. of what i got... and just by a fluke... i recieved a 2001 explorer today for free running
  30. the renegade
    the renegade
    from pensacola
    has anyone try'd to put the Explorer ac system under the dash of a 50's style truck
