Whats a industrial Hemi worth?
Discussion in 'The Hokey Ass Message Board' started by Edelbroke, May 30, 2009.
  1. Edelbroke
    Edelbroke
  2. Hot Rod Michelle
    Hot Rod Michelle
    Only what someone is willing to pay for it.
  3. choppintops
    choppintops
    Detail man, deatails. Does it run? Complete? Rebuildable?
  4. Hemirod
    Hemirod
    from TX
    I know this is not what you wanted to hear, but he is right. I have seen complete 392s go for $800-$2000 for a good rebuild able motor. I have also seen guys pay as much as $4000 for a piece of ****. You just have to test the waters. Put it on Ebay and see.:):cool:
  5. George
    George
    What's the use code in front of the valley cover? Is it a 354 or 331? Short tail or long if it's a 331?
  6. dodgedifferent2
    dodgedifferent2
  7. dodgedifferent2
    dodgedifferent2
  8. storm king
    storm king
    I've got an Industrial 331 with a bolt on extended bell, it spent it's whole life running a welder. They are practically bulletproof. I wouldn't sell mine for a grand, wouldn't pay more than a hundred or two to buy one.
    The correct answer remains, it's worth what you can get someone to part with for it.
  9. kooldeuce
    kooldeuce
    Just like property in the good ol USA ......
    They ain't making any more of it :cool:
  10. There are no numbers on the valley on an industrial. There will be a tag behind the driver side head on the bellhousing mount. It is highly likely that it is a 331. The only 354 industrial was a 56A, so far as I know. Any other numbers will be a 331.
    If you wanna know what its worth, check ebay.
  11. Fordguy78
    Fordguy78
    Those valve covers are pretty cool that they say Industrial instead of Fire Power.
  12. Side
    Side
    From what I have seen and read here you never really know if it's a 331 or a 354 by the tag. They were a m***ed produced engine. Only way to really tell is to measure the bore.
  13. Edelbroke
    Edelbroke
    It runs, it it's mounted to a water pump that was used by a local fire dept. I rwally cant see the numbers right now, i'll start pulling it out today, I can see it doesnt have a built in bell housing. I'd like to find a different intake for it, the 2 barrel on the motor has a govenor.
  14. George
    George
    When you take the intake off check the under carb p***age. Some are square & some are tall & narrow. The car intake won't cover tall & narrow. They either have to be welede @ the top or use block off spacers, also Hot Heads sells a 4 bl intake that covers it.
  15. Edelbroke
    Edelbroke
    I Found the numbers on the block on the front of the intake, they are NE5640070
    From what I can find online, this is a 354 Chrysler Hemi, 9:1 compression 280 hp.
  16. George
    George
    354 car block, where it has that code it may be a complete car engine that someone dropped in.
  17. dodgedifferent2
    dodgedifferent2
    NE56
    354 cubic inches
    1956
    HP 280 @5200-
    Torque 380@3200-
    compression -9.0-
    carb-4BBL
    i agree car block. someone has swapped some stuff into that motor before ... aka the valve covers.
  18. checkedgoldtop
    checkedgoldtop
