Help Identify Tool?
Discussion in 'The Hokey Ass Message Board' started by Buickwagon56, May 30, 2009.
  1. Buickwagon56
    Buickwagon56
    I know I am opening myself up for some comedy, but I truly need help identifying this tool I found in my Dads tool box. He's gone but not forgotten thanks for any help! :)
  2. Fordguy78
    Fordguy78
    It looks like it might be some kind of old rivet tool.
  3. Mr48chev
    It looks like it might be some sort of specialized hole punch. Possibly for leather belts of a certain width.
  4. Side
    Side
    How about another pic or two?
  5. bondojunkie
    bondojunkie
    do you know if he ever did any upholstery work?i looks similar to a snap/grommet tool.
  6. El_Gato_Scott
    El_Gato_Scott
    from So. Tex.
    Hog Ring pliers??
  7. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Did your father cut rough lumber? It looks like a saw "set" to me. A set is used to bend or "set " the teeth on a saw whyle it's being sharpened.
    S****ey Devils C.C.
    "Spending A Nation Into Generational Debt Is Not An Act Of Comp***ion!"
  8. The37Kid
    The37Kid
    Kerf setter for setting teeth on a sharpened hand saw. If you look at the teeth they bend left right left right.........
  9. Buickwagon56
    Buickwagon56
    Wow you have all been a great help. So fast too...:) Thanks
  10. 19Fordy
    19Fordy
    A tool to "hand cut" keys for locks?
  11. plym_46
    plym_46
    from central NY
    I concur with the saw set, I have one very similar with an adjustable gauge on it, after sharpeing the teath were realigned to the proper cutting angle.
    I believe the one I have is suitable for every thing from a miter saw to two man timber saw.
  12. Okie Pete
    Okie Pete
    Tool for setting the kref on a saw.
  13. leon renaud
    leon renaud
    from N.E. Ct.
    It's an adjustable saw set used when setting the kerf(width of cut) on a saw I have used them alot .According to the old timers a properly sharpened and "set" hand saw you can slide a sewing needle down the V formed in the teeth with this tool.That is lay a needle in the trough of the set teeth and tilt the saw a bit and the needle will slide from tip to handle without falling off the saw .
  14. Buickwagon56
    Buickwagon56
    Awesome guys thanks a ton....:)
  15. Bruce Lancaster
    Bruce Lancaster
    You are also going to find a little tool that holds a file over a slot...it cuts the teeth down to same height, if they are uneven, before they are filed sharp.
  16. willymakeit
    willymakeit
    I agree on saw set. I have and still use them to set my vintage hand saws.
