Tech Threads Listing for Tech Week 5/27/09
Discussion in 'The Hokey Ass Message Board' started by zman, May 27, 2009.
  1. zman
    zman
    from Garner, NC
  2. zman
    zman
    from Garner, NC
  3. henryj429
    henryj429
  4. buckeye_01
    buckeye_01
    I can't wait for them to start rolling in.
  5. MN Stumpjumper
    MN Stumpjumper
    I like that alot. Simple and effective. Thanks.
  6. blown49
    blown49
  7. Little Wing
    Little Wing
    from Northeast
  8. ago
    ago
    from pgh. pa.
    e: Tech week! <hr style="color: rgb(229, 229, 229); background-color: rgb(229, 229, 229);" size="1"> <!-- / icon and ***le --> <!-- message --> [​IMG] boost reference edelbrock AFB carbs
    <hr style="color: rgb(229, 229, 229); background-color: rgb(229, 229, 229);" size="1"> <!-- / icon and ***le --> <!-- message --> This is how I modified my 2 500 Edelbrock AFB carbs on my blown 354 Hemi.
    The modification allows the carbs to get the true vacuum signal under boost. Without boost ref carbs the motor can be making boost and pulling a vacuum on the base of carb (blower ****ing) and the metering rods are pulled down and lean out the mixture, when you need the opposite. This happens most when your throttle plates are not completely wide open and your blower is just starting to make boost,
    Machined up a 5/8" aluminum base plate, cross drill the plate with long 5/32 drill. Drill and tap base for 1/8" NPT thread. JB weld the notch in secondaries so vacuum signal will only pull from blower manifold. get a 4 hole carb gasket and punch new holes to reach power valve ports, ( in middle of throttle holes) Plum with 1/4" tubing. It works very well tested it with 2 vacuum gauges.
    <!-- / message --> <!-- attachments --> <fieldset cl***="fieldset"> <legend>Attached Thumbnails</legend> [​IMG]
    </fieldset>
  9. ago
    ago
    from pgh. pa.
    I put 50 miles on the car since I modified it.
    It was too hard to read both vacuum gauges under boost and also drive, because when it comes on the boost (7PSI) its hang on. I need to test with a co-pilot. I have a LM-1 A/F meter I will connect back up and report back. The Edelbrock metering pistons are not like Holley they don't blow out. I have 5" metering spring on it. It does seem to run smoother off idle, I don't have a reason why, because under no boost it should act the same. I still have tuning to do, thats why LM-1 going back on. I thought about this a lot and I could see at not full throttle opening and under boost before modification it could be possible for the metering rods to see vacuum from the blower ****ing and run lean .
    32 Ford 354 Hemi, 6-71, 2 afb 500cfm carbs, 114deg. blower cam, 5sp. Tremec, QC. front carb pri.jets .082, metering rods .053-.066, sec jets .098, rear carb pri jets .086, rods .058-.071, sec jets .095
    Ago
  10. bgbdlinc
    bgbdlinc
  11. zman
    zman
    from Garner, NC
  12. ago
    ago
    from pgh. pa.
    People telling me to post my own thread, I'm not sure what they mean?
    Ago
  13. zman
    zman
    from Garner, NC
    You had already posted that tech like a month ago. So I don't know if it would qualify. I merely list the "new" tech threads that show up during a tech week.
  14. bgbdlinc
    bgbdlinc
    ...sorry, I misunderstood, your call....
  15. brett4christ
    brett4christ
  16. BZNEIL
    BZNEIL
  17. ago
    ago
    from pgh. pa.
    Z-man, I don't care if it qualifies,maybe someone who didn't see might use it,
    Ago
  18. Squablow
    Squablow
  19. metalman
    metalman
  20. Scott
    Scott
  21. Q
    Q
    All I've got is this......
  22. NTAPHSE
    NTAPHSE
  23. AntiBling
    AntiBling
  24. rob lee
    rob lee
    from omaha,ne
  25. choppintops
    choppintops
    When does the week end? I have one I'm putting together.
  26. Kilroy
    Kilroy
    from Orange, Ca
  27. 34FordConv
    34FordConv
  28. Rob Kozak
    Rob Kozak
