Projects It's Sunday afternoon, what did you accomplish this weekend?
Discussion in 'The Hokey Ass Message Board' started by SanDiegoJoe, May 31, 2009.
  1. uglydog56
    uglydog56
    I por-15'd my frame and moved the spring perches on the 8.8 so I can swap it in as soon as I get some ford bolt pattern 15x7's.
  2. No work......just play.
    Went on Saturday to the Rt 66 swap meet & car show in Joplin.
    Didn't find much for a Plym at the swap....only a tail light frame.
    However, the car did win first place in the Stock to 1948 cl***.
    And, last weekend, I took the car to the 66 Drive-In theater at
    Carthage where it was used, along with about 30 others, as a
    prop for a segment of Great American Road Trip. They are doing a
    Rt 66 theme. The segment will be shown on July 14, on NBC.
  3. Those are cool what did you use for material?
  4. JEPPA
    JEPPA
    Did Jack squat?
  5. FIFTY2
    FIFTY2
    Put on my $5 seat covers...
  6. Spent the day trying to get my O/T barn find running- 1972 F100 stored inside since 1984.
  7. slefain
    slefain
    from Atlanta
    Started out just going to bleed the brakes on the '61 Olds F85 and turned into a carb rebuild. Got the front brake bled fine (rears need to be rebuilt, next on the list) and went to crank the car up. I did a trans service on the lousy Slim-Jim trans and adjusted the linkage. I was looking forward to see if my work made a difference on how the trans shifted. Connected the battery, hit the key and nothing. Hit the carb with ether and it kicks over but won't run. After much cleaning and thinking I finally checked the carb fuel filter. There wasn't one. Whoever had the car before me had yanked it. So I go and open up the bowl, it look like I was panning for gold. Cleaned all the jets and anything else I could when I notice the power valve O-ring was missing a CHUNK out of it. Well that would sure do it. So now I need to fix that and put in a new fuel filter. It's just as well, the weather was nice out and the local car wash at the end of my street was a ghetto street party on rented blinged wheels. Last thing I want is anyone to know what I have in the garage (no mufflers on the '61).
  8. Labold
    Labold
    ...ended up with poison ivy doing yard work.
    I should have just stayed in the garage.
  9. Dreamweaver
    Dreamweaver
    Started cleaning out the front garage so I can put all the extra furniture thats stashed in MY back garage into the front one.
    Going to pick up a new resident for the back garage in 2 weeks!
  10. HotRod33
    HotRod33
    I had to change the heads on my motor in the 33 friday and then took it to the Rust Revival.... Saturday we Drank Beer, looked at cars, Drank Beer, listened to music, Drank Beer, met alot of good people, Drank Beer, ate barbeque, Drank Beer, watched alot of cars doing burnouts.... Did I mention we Drank Beer...... It was a ***** driving home, we couldn"t drink beer.....
  11. dabirdguy
    dabirdguy
    Took a vacation day Friday so I had a 3 day weekend.
    Friday -
    Swapped heads on the rebuilt 350 engine we put into my '85 el Camino because I had newer heads on it before and the serpentine system would not bolt up to the double-hump heads I put on it. We replaced the engine because it was making a racket after just 1350 miles.
    Had an electricina over to rewire the house so my compressor doesn't blow the breakers on my rec room where the wife uses her computer.
    Saturday - Reveled in the Rust revival show. Had a blast.
    Sunday - Tore apart the enigine we replaced in the el Camino. It had all bad mains and 3 bad rod bearings. It seemed to be another bad Oil victim at first thought. Then I noticed that cylinder 1 had cap number 3 and rod number 5 in it. Crank is toast.
    So... probably bad oil AND an ***hat doing the work. Bought a freshly ground .010/.010 crank off of Craigslist. I love Craigslist!
    The Rust revival made the weekend a great time in spite of the bad motor news.
  12. atch
    atch
    went to the rust revival. i thought you were all going to be there. i missed a couple of you...
  13. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Started on the family '54. Got the rear end out and started knocking a bit of the rust off. Took the roadster out last night to a friends for dinner and ripped a hole in the roadster's oil pan. Highs and lows.
  14. kwoodyh
    kwoodyh
    I worked! In Iraq Sunday is like a Monday! No wonder it's all ***ed up over here! ;)
  15. tathataboy
    tathataboy
    from Olathe, KS
    I finally got the grill off my '56 Plymouth Savoy-***-rustbucket. Put some "make do" weather stripping around all the doors to try to slow down the wet. Taped in a plastic cover for the missing rear window. Took the rest of the mouse-eaten cushion off the front seat. Tried not to freak out about how much work needs to be done on this mess (a serious episode of "What the Hell Was I Thinking??"); my wife talked me down off the "just part it out and sell it on eBay" cliff.
    One thing at a time, gotta remember to focus on one thing at a time.
  16. Friday; Branded my self fixing some welds in my buddies 4-link
    Saturday; cut more floor out of the Shoebox then went to my G/F's 21st birthday
    Sunday; Played hangover nurse and Branded myself welding more floor into the Ford
    Monday; Ordered a new set of sleeves, so by tuesday, No more branding.
  17. aldixie
    aldixie
    Picked up my first Model A saturday. I've wanted one since I was 14, 29 years later.:D
  18. onlychevrolets
    onlychevrolets
    He was Jack Off
  19. czuch
    czuch
    from vail az
    Worked 5 hrs Saturday. That was nice. Got home did breaks on the Bugatti,(looks like a Bugatti, sounds like a VW) then moved the 72 suburban onto the tarmac and jacked, pressure washed and did wheel removal ops. Followed by rum and coke.
    Sunday daughter and self rode to cooler climes and went back in time to the old west. Had real good BBQ and scored left overs.
    miniscule loss of blood, 350 bike miles,happy daughter. SUCCESS,I win.
    Had
  20. milwscruffy
    milwscruffy
    this!!!!! actually just hung and welded th drivers side 1/2 quarter. will be finishing up that side this week. been a long couple of months, but there's light at the end of the rust tunnel.
  21. Stevie Nash
    Stevie Nash
    Dropped the front end 2 1/2 in's. Now I have tire clearance problems! Damn!!!!
  22. That is an awesome picture! Love it!
    Davo
  23. mckinney
    mckinney
    from Texas
    Sounded like a productive time....
  24. sko_ford
    sko_ford
    my body now bolts to my frame
  25. Bigdaddy
    Bigdaddy
    I went and picked this up...I think 3 people on this thread got Coupes this weekend!
