ever cut glass with a plasma cutter?
Discussion in 'The Hokey Ass Message Board' started by 55 dude, Dec 18, 2006.
  1. Mopar34
    Mopar34
    plasma cutter for gl***?? I doubt it unless the gl*** was at least 2 inches thick and even then I wouldn't think so.
  2. 19Fordy
    19Fordy
    Does anyone make a portable waterjet cutter? Might work better than plasma.
  3. Jay Rush
    Jay Rush
    Don't the 2 guys on the orange lift know they should be wearing a seat belt
  4. Customikes
    Customikes
    from SoCal
    Oh come on now Nads, they've been making wood shoes in Sweden for centuries :eek::D
    We still managed to put out a few decent metal men :rolleyes:
    On the plasma gl*** cutting, plz include pix. I'll make popcorn and call the medics...
    Then again you got this weird plasma gl*** cutting example on you tube... www.youtube.com/watch?v=rzaGSF0xnT0
    Mike
    www.Customikes.com
  5. I cut sheets of 1/2" aluminum sandwiched together all the time............. makes a nice, clean cut.
    I don't do gl***..............
  6. super plus
    super plus
    I have cut the chesse a few times
  7. brewsir
    brewsir
    NO...I tried this yesterday with a piece of laminated gl***.
    First I tried aluminum foil which melted quickly and the arc lost ground....after it got hot and shattered the top gl***.
    Second attempt was with a piece of 20 ga metal laying on top of the gl***....same results...very hot gl*** makes huge cracks.
    Lastly I placed the steel under the gl*** and started an arc ....it kind of melted the gl*** but also got hot and caused huge cracks.
    Myth busted as far as I'm concerned. The rapid changes in temps of the gl*** will always cause cracks.
  8. temper_mental
    temper_mental
    from Texas
    I was talking about steel or stainless I will try aluminum some time.
  9. budd
    budd
    like i had posted in this thread allready i have cut ceramic gl*** with a plasma, the cut was about 1/4" wide and it made icicles on the underside, totaly unuseable, no cracks but ceramic gl*** is not supose to crack when heated, you take a piece of ceramic gl*** and have one end in a bucket of ice water and melt a hole with a torch in the end sticking up out of the water, but i dont see a use for it in autos unless you wanted to make a window in your exhaust manifold so you can watch the pretty flames. hey maybe a small round window in each of your header tubes would be cool.
  10. cool57
    cool57
  11. I'd imagine it would lose it's temper for sure if you came up and whacked it for no reason with a hatchet. I'd lose my temper if someone tried to whack me with one.
  12. turdytoo
    turdytoo
    I'm not beleiving I actually read this whole thing.
  13. Slickster51_50
    Slickster51_50
    I'm with you on this one!!!!!!!
  14. bobjob55
    bobjob55
    I think it would be dangerous !! even with a water jet!!but i hear water jet is way to cut gl***...
  15. bert haddock
    bert haddock
    from England
  16. dabirdguy
    dabirdguy
    You owe me a keyboard.
    There's diet coke all over and inside mine now.
  17. oilslinger53
    oilslinger53
    from covina CA
    no. it will heat the gl*** up too much and crack it. The thing about cutting or grinding gl*** is you have too keep it cool.
  18. cool57
    cool57
    Forget plasma, I do it with dryer sheets. It's dangerous in it's own way but it works every time-IF you know what you are doing.
  19. firemunkey
    firemunkey
    from temecula
    Dryer sheets, ha! I'm going to buy up all the local supply, miracle tissue!
  20. If the dryer sheets dont work, I bet this guy knows how to do it...
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/rLDgQg6bq7o&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/rLDgQg6bq7o&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
  21. wow, washing your engine parts in the dishwasher and now cuttin windows with the plasma! its comedy hour on the hamb!!! lol
  22. 296 V8
    296 V8
    from Nor~Cal
    she could use a plasma cutter
  23. NTAPHSE
    NTAPHSE
    Hey it is tech week, somebody do it!
  24. 55 dude
    55 dude
    thanks for the laugh guys,never though tech could do that.:p:p
  25. plym49
    plym49
    from Earth
    I was waiting for the dryer sheets to make an appearance! You all never disappoint!! :)
  26. blinddaddykarno
    blinddaddykarno
    My welding instructer claims it can be done by making a dam/channel with clay or something similar to hold water on the cut line. I'd like to see it, albeit from a distance!!
    Brian
  27. socalmerc
    socalmerc
    from socal
    if my boy cheech can find away so can you!!!!:D
  28. Tic
    Tic
    OK I'll join the fun... I tried it with a Mason jar (canning jar) and a low setting. I sprayed the jar with conductive spray paint and it did cut the gl***. It cracked the gl*** from where I started the cut, up to the top of the jar but not below the cut. I left the jar in the sun after I sprayed it so it would warm up to minimize expansion. I also tried it with a piece of laminated gl*** and when it cut through the top layer and hit the plastic it would blow out. I also left the piece of windshield out in the sun before I tried the cut to pre-heat it. I didn't get any cracks but it didn't make a clean cut either.
    Tic
  29. TripletEngineer
    TripletEngineer
    from Atlanta
    I read this link long ago but did not have a plasma cutter. Eventually, I got the torch and gave it a try. Yes, backing or fronting gl*** with a sheet of metal works just fine.
    http://www.youtube.com/watch?v=f34LdyvHmvo
    I have some really thick aquarium gl*** that I will try soon. If I can get it to cut through 3/8 gl***, I'll make a jigsaw puzzle.
    Thanks.
