weirdest part I've ever seen - what is this?!?
Discussion in 'The Hokey Ass Message Board' started by seetz, Jun 8, 2009.
  1. seetz
    seetz
    see this pics, what is this? it's red copper, one bolt with a slot in the middle, two nuts with some sort of H-shape wedged in. it says on the top of the bolt "Reliable SOL 4". it's about 1-1/2" long
  2. mitch 36
    mitch 36
    It looks like an electrical cable clamp to me. Usually used for larger cable/wire sizes. Mike
  3. Piewagn
    Piewagn
    Heavy gauge single strand wire splice.
  4. southpark
    southpark
    bingo.
  5. 40bcool
    40bcool
    from Tulsa,Ok
    True it is a wire clamp.:D
  6. SLCHC-CHIEF
    SLCHC-CHIEF
    from S.L.U.T
    its called a split bolt. Its used to clamp wire together.
  7. vintagedrags
    vintagedrags
    it's called a split bolt kearney. it's used for connecting multiple wires together.
  8. BigDfromthe303
    BigDfromthe303
    It's a split bolt bolt. I use them all the time at work. The SOL 4 means it's for solid #4 wire.
  9. seetz
    seetz
    thanks y'all, I'd never seen one. so what would I use this for in a car? something like split a battery cable to get a second hot wire? any way to guess a year on this one? looks like it wasn't made in China
  10. vintagedrags
    vintagedrags
    I wouldn't use it for anything on a car. These are used for regular electrical work.
    It does look a little old, maybe 50's or 60's, but still only worth copper weight.
    These are every day items in the electrical industry.
  11. Royalshifter
    Royalshifter
    Moderator
    Its a feetle bobbin.
  12. Midnight340
    Midnight340
    Goes in the bottom of a still, adjusts the flow of the moonshine as it drips into the mason jar. What is it with all this electrical stuff? :)
  13. KJSR
    KJSR
    from Utah
    You would use it to ghetto connect some stuff together. It would require some black tape (I'm sure you could use duct tape in a pinch):D.
  14. I thought it was a flux capacitor. Or maybe a kaneuter valve.
  15. VonKool13
    VonKool13
    Thats a **** gobbler. It looks to be 2 nd series, the one you don't need KY for but you probably ought to stock up just in case.
  16. wetatt4u
    wetatt4u
    100 %
    Its a ground lug for the house ground wire for electric or cable TV connection ...
    Not a car part at all.....
  17. Bruce Lancaster
    Bruce Lancaster
    House electrical stuff is much more primitive than car wiring because it isn't subjected to vibration and movement, except maybe in California. Using this in a car would be very dodgy.
  18. The37Kid
    The37Kid
    Yes, I'm always careful not to hit mine with the lawnmower. :eek:
  19. chevy57dude
    chevy57dude
    A "bug" in electrical slang.
  20. lippy
    lippy
    from Ks
    And currently.....a "June" bug. :p
  21. 21tat
    21tat
    Sure the hell is.
  22. shock
    shock
    ..........BTT.........just cause this is so interesting.
  23. RichG
    RichG
    Split bolt.
    ...or you could use it to attach a cats tail to a car antennae (with or without cat)...:D
  24. sir
    sir
    ...grounding clamp!!!
  25. Those are also handy for clamping wire rope/cable , like for a remote hood or trunk release, or a manual back up for when your electric door poppers fail.
  26. Take about a hundred of em, put em in a bag and bing; a body weight for sinking dead bodies in the bay.
  27. 48fordnut
    48fordnut
    its a henway.
  28. It's the factory connector to the turbo powered ciggarette lighter on a 52 Buick >>>>.
  29. redlinetoys
    redlinetoys
    from Midwest
    Connects the smaller copper ground wires in your house to the heavy grounding rod in the earth.
    Common household part.
  30. chevy57dude
    chevy57dude
    "Currently" Ha HA! :D
