Is this 32 Grill Shell Trim Real or Repro?
Discussion in 'The Hokey Ass Message Board' started by tradmapper, Jun 10, 2009.
  1. tradmapper
    tradmapper
  2. FiddyFour
    FiddyFour
    you got hosed... thats a 33 dude
  3. Fogger
    Fogger
    No not a '33, it's a '32 and looks to be original. The seller has 100% feedback so more than likely will stand behind the sale. The FOGGER
  4. tradmapper
    tradmapper
    It is cast from br***, never having seen a real one, I ***umed they were cast in white metal/zinc?
  5. krylon32
    krylon32
    from Nebraska
    I have had 1 in the past cast in br*** also the Ford oval cast in br***, always ***umed they were original.
  6. Corn Fed
    Corn Fed
    The 3 or 4 orginal ones I have were made of a pot metal. I have never had or seen a bronze one. I'd lean towards it being an early repro.
  7. tradmapper
    tradmapper
    I just had a closer look, and it was sandcast, I'm positive it's an early repro.
  8. sawzall
    sawzall
    sorry to hijack.. but I have a part marked "46 ford convertible windshield divider bar" that I believe is also cast br***.. anyone know if this might be stock???
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    The grille ornament is an early reproduction and not a very nice one due to being sandcast. Original ornaments are cast zinc alloy(often called pot metal) and have the Ford part number B-8215 cast into the underside.
    The "gypo" grille emblem "Ford" oval which doesn't even fit the ornament very well at all.
    Original emblems don't have the rim around the edge and are blue cloisonne enamel over chrome plated stamped copper with a stud on the back. The original 32 emblems are quite thick at the center tapering off to the ends.
    The seller of this item doesn't know as much about early Ford parts as he thinks he does or his friends have told him.
  10. pasadenahotrod
    pasadenahotrod
    from Texas
    Windshield division bars are the same for all 41-48 Ford body styles I believe. They are stamped and polished stainless steel with a plated mild steel insert with threaded bungs which slip through holes in the rubber moulding. A painted stamped steel backing plate has countersunk holes in it which the chrome-plated slothead screws run through to tighten the center bar in place.
  11. 34toddster
    34toddster
    from Missouri
  12. xix32
    xix32
    another one of those ebay liars. just look at the other items he has listed that he calls "32 ford" : the banjo steering wheel? and the 97 carb?
  13. Deuce Daddy Don
    Deuce Daddy Don
    Besides all the previous answers, the "FORD" oval should be FORD Blue!!!
  14. tradmapper
    tradmapper
    Paypal accepted my dispute and has guaranteed a refund upon return delivery which they will track online, even though the seller refused. Thanks for the help guys!
