Customs Advice on Colors for My 54 Chevy
Discussion in 'The Hokey Ass Message Board' started by pushrod_mike, Jun 11, 2009.
  1. pushrod_mike
    pushrod_mike
    from Austin TX
    OK guys here is what I am thinking of trying. I will not be doing any of the work so don't worry about my lack of talent because that is a good variable to take out of this problem. I'm thinking of painting my 54 2 dr hardtop gold metalflake and then do the top in silver metalflake as well as the rear quarter stripe. Will that work together?
    Here is the other part of it. I'm thinking of doing an old custom style interior with rolls and pleats and big diamonds and whatnot and using gold zodiac metalflake for the majority with silver zodiac metalflake for the inserts.
    Can I match the paint to the zodiac? will it be too much? am i crazy?
    I think it would look good only if its pulled off perfectly.
    what do you guys think?
  2. SinisterCustom
    SinisterCustom
    Uh....silver and gold look horrible together....IMO.
    But this guy digs it......
  3. HotGarbage
    HotGarbage
    from Texas
    Agreed.
    Black and silver looks good.
  4. jnds53
    jnds53
    Yeah, if your a Raiders fan!!!!!!!
  5. TERPU
    TERPU
    BLACK! No Silver anywhere on it. Or Dark blue and silver, but the guys are right Raider mobile. Also I like the White top Black combo on a hardtop, harder to pul off on a sedan. Sedans tend to look like cop cars in the B/W. But paint it however you want you have to drive it. The wheels & gl*** color will have a huge affect on the combination as well so keep that in mind. The gold needs to be as a very moderate accent as it becomes overpowering and tacky when used without restraint. You could use gold piping on your seats and do the rest in a more subtle base tone which matches the wheel color and interior scheme. Also if you are using pattern in your upholstery pick a 50's era pattern and it will always look right no matter what you do pleat wise.
    Good luck,
    Tim
  6. Bling! No, seriously. It would be money.
  7. belair
    belair
  8. Abner
    Abner
    If you do, paint it the gold and silver you could do different size flakes to set it a little more apart. If done right it should look pretty tough, but it could end up looking flamboyant(sp?). imo. but go for it.
  9. 54 savoy
    54 savoy
    o.t. but can see contrast
      153.1 KB
  10. Winged Avenger II
    Winged Avenger II
    from Wisconsin
    it will look like a cartoon
  11. The37Kid
    The37Kid
    If you have the Bel Aire trim dark blue, the stuff on a Mercedes or Audi. Roof and quarter panel insert area in that cream Dodge uses on the Magnam wagons.
  12. philly the greek
    philly the greek
    from so . cal.
    whatever color you do ,just make sure you can repair it . Sometime ,somewhere ,it's going to get damaged.
  13. OLLIN
    OLLIN
    my .02, I would do it all gold and maybe white interior with gold zodiac accents, but no silver metal flake..
  14. rustypipes
    rustypipes
    from san jose
    ha ha
  15. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I'd go with one of the colors and a white top to make things simple. Simple customs are happy customs.
  16. R Frederick
    R Frederick
    from illinois
    Mine, I played it safe. But I could picture a silver roof.
  17. hudson hot rod
    hudson hot rod
    I like flat black no matter what color it is.....
