Questions on GMC inline 6.
Discussion in 'The Hokey Ass Message Board' started by Ornery37, Oct 16, 2005.
  1. Ornery37
    Ornery37
    from Texas
    Was wondering if anyone knows?
    I am looking at buying an inline 6 out of a 56 GMC 3/4 ton truck. Was wondering what size it might be, if there are proformance parts, and how much it might be worth? I comes with the 4 speed trans.
  2. NVRA #84
    NVRA #84
    More than likely it's a 292 if it's in a 3/4. But it could be a 250. Check Cilfford Performance for speed parts. This site will give you the spec's www.raceseek.com/chevy_six_cylinder.htm
  3. Ornery37
    Ornery37
    from Texas
    Cool! Thanks for the info.
  4. Squablow
    Squablow
    I think '56 is too old for a 250/292 engine. They were still using Stovebolts in the cars in the early 60's, 250/292 came out in the mid 60's, unless GMC was using those sizes before the regular Chevys.
  5. Ornery37
    Ornery37
    from Texas
    I was told it is original to the truck. I use to have a 59 el camino that had an original 235. So was thinking it might be around that size. Also it does not have the vent in the valve cover like the stove bolt that I had in my 53 chevy truck. Thanks!
    Any one know what an inline 6 with tans that was running might be worth?
  6. If it's a 56, it's probably a 270, unless it's out of a big truck. Doubt it's a 228 or 248, but possible. If it's out of a big truck, it'd be really big. The 250 didn't come out til the middle of the 60's, after the 194 and 230 were out.
    inliners is a great site, and you can get some info off stovebolt.com
    As far as worth, it's worth whatever ya wanna pay for it. I've gotten Stovebolts for $50, or $250, or free. It's up to you to decide what you wanna give for it. I'll say one thing though, they aren't getting any cheaper!;) :D
    Good luck. Keep us posted.
    jay
  7. NVRA #84
    NVRA #84
    Opps, I read 56 but my mind switched it to 65. Old age, what can I say.
  8. Patrics does a lot of stuff for the old GMC engine
  9. BIG PORT JIMMY 6
    BIG PORT JIMMY 6
    It should be a small port 270 with a 3/8 belt width setup and the small 6 bolt flywheel, all good stuff to have. The first 3 digits in the serial # beside the dist should be the displacement. There are plenty of performance parts available, none are cheap. Remember nothing is like a Jimmy. Jay
  10. cammed292
    cammed292
    I have a 1950 gmc 3/4 ton and the casting on the block says its a 228, and it came with the 3spd column shift
  11. pasadenahotrod
    pasadenahotrod
    from Texas
    That 4-speed trans will be a Granny Gear 4 speed not worth hauling for use in a rod.
  12. greasy50chevy
    greasy50chevy
    i think its a 270... dont hold me to it though
  13. nexxussian
    nexxussian
    Wow,neat 'blast from the past'.:D
    Not to be a schmo guys, but this thread's from '05.
    Thanks for searching though (as I expect that's how it was found).
