Cad/Lasalle transmission with ford mount
Discussion in 'The Hokey Ass Message Board' started by greazhonkey, Jun 14, 2009.
  1. greazhonkey
    greazhonkey
    Does anyone remember a tech post that described how to remove the long tail housing and shorten a cad/lasalle transmission and then use a ford transmission mount. It was a scanned article from an early hot rod magazine. Jog anyone's memory? Thanks.
  2. 7&7
    7&7
    from Colorado
    PM Paul he has it. I too have it but, have no scanner.
  3. Paul
    Paul
    Editor
    pretty simple stuff
    as a matter of fact,
    I think you pretty much summed it up
    I'll try to find the one magazine article I have
    but it doesn't have a lot of technical info
    in the meen time here is snapshot of a couple I've picked up all ready converted
  4. greazhonkey
    greazhonkey
  5. Paul
    Paul
    Editor
    here's the article, what there is of it..
    converting the '37 top shift, the side shift will of course be pretty much the same
  6. Pete
    Pete
    Whats the easiest way to install a shorter tail shaft and retain the open driveshaft??
    Pete-
  7. ROCKET88COUPE
    ROCKET88COUPE
    from TEXAS USA
    50 olds trans same as cad short open drive getting rare one year only trans
  8. RocketDaemon
    RocketDaemon
    from Sweden
    i was reading that magazine yesterday!, anyhow
    how about do this change to a closed driveline, and use the rear end of an early flathead truck ****** with opendrive...
    i have 2-3 or something long tailshaft lasalle ******s (and 2 1950 olds ones also ..) and an truck ****** laying around in the garage i figured i was going to test to use the opendrive part of thatone on one of the ******s...
  9. Bruce Lancaster
    Bruce Lancaster
    There is a better article with dimensions for the cuts on Ford part to make it fit the cad rear bearing properly...the one shown relies more on Permatex than fit there. I think I've sent it out to a number of people on here...no scanner.
