389 Pontiac
Discussion in 'The Hokey Ass Message Board' started by BUSTEDKNUCKLE, Jun 13, 2009.
  1. BUSTEDKNUCKLE
    BUSTEDKNUCKLE
    Can anyone help me identify what parts I have. I do know that they are Pontiac. I have heads, exhaust, intake,short block, and a bunch of misc parts that I would like to sell.
  2. Mr48chev
  3. axle
    axle
    from Drag City
    No one on here are magicians. You need to supply head numbers, block numbers (located on the front right p***enger side of the block) , and if possible, numbers embossed next to the ditributor
  4. BUSTEDKNUCKLE
    BUSTEDKNUCKLE
    Here is what I got
    1 pair heads 9770716
    1 pair heads 092 on center exhaust
    1 short block 212295 YU
    1 complete engine and trans 543680
    1 exhaust 545467
    1 exhaust 9779033
    1 intake 18496572
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The 9770716 heads are either '64 GTO or '63-'64 421 H.O.----a nice find. The 092 heads are nothing special, just bread and ****er '66 389.
  6. Duntov
    Duntov
    Casting #9770716.........1963-64 421 HO; 1964 389 GTO
    Casting #092...............1966 389
    Block code YU* .............1966 389; 1967 400; 1969-1971 350; 1974 455.
    Exh. Manifold 545467.....1963-64 389 or 421 p***enger car.
    Exh. Manifold 9779033...1965-68 389, 400, 421, 428 p***enger car.
    Intake 18496572.......... Not a Pontiac intake manifold.
    *You must check the casting date near the distributor hole to find exact year and displacment.
  7. Scorch67
    Scorch67
    from Omaha, Ne
    I have a bread and ****er 67 389.
    The old cooling system it had went from the radiator through the pump and in one side of the block, through the head, across over to the other head, down into the other side of the block and into the radiator.
    I changed it over to the modern system simply by installing a newer timing chain cover and waterpump. I bought it already built with 6x heads .060 over bore with 400 pistons. I didn't corrupt an original:) The modern cooling goes from the radiator, simultaneously through both sides of the block, into both heads then back into the radiator from the front crossover.
    I was going to s**** out the old timing cover but it wasn't pitted at all. I got almost a hundred bucks for it on fleabay!
  8. BUSTEDKNUCKLE
    BUSTEDKNUCKLE
    What do you think the 9770716 heads are worth?
  9. Scorch67
    Scorch67
    from Omaha, Ne
    I can't say what they're worth but I can say who'd be interested, restorers not racers unless someone is racing stock cl*** and needs factory castings. check with NUNZI"s http://www.nunzi-pontiac-expert.com/ maybe they might be able to tell you more. They race and run an all pontiac junkyard.
  10. treb11
    treb11
    thats 18436572 - the firing order
  11. BUSTEDKNUCKLE
    BUSTEDKNUCKLE
    LOL your right. Thanks
  12. rjsgoat
    rjsgoat
    What are the date codes on the 9770716 heads I may be interested?
  13. 64gtoguy
    64gtoguy
    Email, or PM me I am a Pontiac Geek and would be interested in your stuff,
  14. BUSTEDKNUCKLE
    BUSTEDKNUCKLE
    I would like to sell everything togeather if possible.
  15. shpotty
    shpotty
    from New Jersey
    '66 was the last year for the 389.
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Do yourself a favor and sell the pieces that people want to pay for. Half of the stuff you listed falls into the "no big deal" category. Insisting on a package deal will only turn prospective buyers away.
  17. Scorch67
    Scorch67
    from Omaha, Ne
    maybe that's what it was. the tempests look pretty close I guess. it has the old style mounts, I couldnt bolt it into my 71 firebird without fabricating some mount. I got it from a junkyard, story on it was the farmer just got it back from the machine shop and had it sitting in the car. he stepped out of his truck. his kid put the truck in gear and it rolled across the yard and t-boned the tempest totalling it. I swapped a 78 350 camaro i couldn't get a ***le for and a 71 ford pickup for it. It was still in the bag sitting in the frame.
    the Dad was sellin the whole car and somebody came by put some token money down on it and when dad was not home the "buyer" loaded the aftermarket ******, the wheels/tires, the spare parts and all the goodies from the trunk and left the car unpaid for which is why he gave up on it.
  18. Firebirds use the same mount in a different place, some blocks are drilled for both, some just one or the other.
  19. tbsjr
    tbsjr
    I'm looking for a drivers side exhaust manifold (Part # 9779033) for a '68 Catalina. Do you have one or know where I can find one?
    Thanks,
    Tom
  20. Movinginstereo
    Movinginstereo
    Did you find your manifold? If not, I just checked & I have one.
    Thanks,
    Randy
  21. stuart in mn
    stuart in mn
    He hasn't been here for two years, so he's probably not going to get your message.
