History 1955 Chevy Gasser ... White Lightnin
Discussion in 'The Hokey Ass Message Board' started by Searcher, Nov 2, 2008.
  1. SOHC427
    SOHC427
    Great car, and history. Sure hope you find the cars location.
    Eric
  2. DE SOTO
    DE SOTO
    I dunno, Maybe its cus were in So.Cal :D
    But i remember as a Kid in the early '70's every gear head in my Little town had a Bad *** Ride.
    Not like the Tonka Trucks & 40 thousand dollar Euro box's Kids have today.
    I have an Uncle that was in his Late teens & early 20s then and he had some *****EN stuff, Wish i had his Pics.
    One that stand out was a '54 2dr Post Bel Air, 2x4 409, 4spd, & Posi .. Crome front suspension, Straight axle, Fat & Skinny Cragars Painted Forest Green Metallic.
    They striped a REAL 409 Impala for the running gear !!!
  3. Searcher
    Searcher
    More pic's.... Some aren't very good...but they are a glimse into the past.
    These were taken at San Fernando also.
    59 ? Elco tow vehicle....no trailer :D old school. Cragars all around.
    benchseat4speed likes this.
  4. Searcher
    Searcher
    I know it was Aluminum...
  5. Fogger
    Fogger
    Searcher, Great to see more shots of the '55. Before we put the big block in I cut out the firewall to clear the heads and Vertex mag. Made the throttle linkage out of aluminum blocks with oil-lite bushings. Actual pedal was a freeze plug brazed to the rod. I had the roll bar bent by Mercury Tube in Glendale and Dave Bettis, who was ***ociated with the LA Roadsters, welded it in. Dave and his shop are long gone but he was located in the Los Feliz area east of Hollywood. Bettis had worked for old man Walker in the Walker's Muffler shop on Hyperion Ave. Still hoping someone locates the old g***er. The FOGGER
  6. whatever
    whatever
    the hamb rules this is truley cool
  7. vintagedrags
    vintagedrags
    1960 elco.
    Man I hope someone finds this car, *****'n!!!
  8. Searcher
    Searcher
    Couple more....
  9. Mr Haney
    Mr Haney
    the real deal......thanks for sharing ! ! nice build
  10. Searcher
    Searcher
    I got together with "Fogger" today at the Road Kings car show, and he brought out a bunch of pictures of "White Lightnin". It was great meeting him ( super nice guy ) and also getting to see his 32 3 window.
    This is a picture of him at Lions getting a bit of air.
    I hope he will elaborate on this shot.
  11. HFKND1
    HFKND1
    from Peoria, IL
    Hey Fogger was that Ron Brown's shop that did the front end? I have made contact with him on myspace. Great guy love pick'n his brain.
  12. ironandsteele
    ironandsteele
    all i can say is wow.
    cool story.
  13. Searcher
    Searcher
    Bumping this shot to this page....
  14. thirty7slammed
    thirty7slammed
    from earth
    Damn, what a cool thread, thanks Searcher & Fogger...........................
  15. Searcher
    Searcher
    Heres something I thought was cool....the heads off of the small block that was powering the "White Lightnin" in the above pic are now on the SB in his 32.
    Tell us a story " Fogger " :D
  16. thirty7slammed
    thirty7slammed
    from earth
    Very nice 3W, & very cool history. Fogger, whats with the spacers under the vette valve covers? Must be running a pretty radical cam...........
  17. Fogger
    Fogger
    The shop that did the front suspension and frame was **** Fletcher and Ted Brown. Ted's still around the hot rod scene and was well known for his T-buckets. Fletcher/Brown Race Cars was in Lakewood, Calif. The front end on my car was a straight tube with Willy's spindles and gutted brakes. Stock '55 Chevy steering. The FOGGER
  18. Fogger
    Fogger
    Cam isn't that radical but to clear the Comp Cams roller rockers and poly locks I had a shop tig the spacers onto the valve covers then had them surfaced for a positive gasket seal. The SB is 360 inches, 10-1 compression, the old GM 461 Mondello heads are off the '55, 10 lb Schiefer flywheel, Muncie M-20 4-speed, narrowed '58 Olds rear axle with Henry's axles and a Dana posi. I still have an old Chet Herbert #50 roller cam and may put it back in someday. The setup is basically what I ran in the '55 except more cubic inches and the mild cam. The FOGGER
  19. Fogger
    Fogger
    Searcher, Good meeting you and your friends today. The above shot was one of the last times I ran the small block at Lions. The car was initially set up for bracket racing only and was very consistent so easy to run the right number. When we put the big block in my partner wanted to run B/Gas NHRA. Problem was the wheelbase was stretched about 2" thus making it an Altered. So during the '67 Winter Nationals we moved the front axle back to make it legal for the gas cl***. The best run with the 427 was 10.80 @ 129 mph at Lions. It was a fun ride power shifting at 8000. That was real old time racing, no rev limiter, no ignition box, no stab and steer automatic trans. Thanks for posting the shots. The FOGGER
  20. Fogger
    Fogger
    Ok Searcher, I've had the 3W since '82. Built the ch***is in the late '70s and found this Ford body at the Pomona swap meet in '82. Been driving it since '86. It is all Ford sheet metal. In '99 returning from the Bakersfield March meet an old man in a Dodge van ran into me hitting my car twice. Fortunately no one was injured and the CHP determined that he was 100% at fault. So with the help of the body man that I had purchased the body from and the insurance settlement we straightened the fenders, bumpers, hood and grill shell. Then chopped the top 2 1/4" and filled the roof with a '64 Mustang coupe top. All the body work and chop was done in a backyard in Culver City by one of the best metal finishers to ever work on old Fords. I painted the sheet metal in my garage with black acrylic lacquer. I've always enjoyed this car and to me looks much better with the chop. See you guys at the LA Roadster show. The FOGGER
  21. SteadyT
    SteadyT
    Great thread, and great to see another 55 from the days at Lion's.
  22. five five
    five five
    from SoCal
    Like everyone, I am enjoying this thread very much. The picture find and the timing of the replies are amazing.
    As an aside to the topic here, it might be of interest that the very last p***, ever, down the Lion's quarter mile was made by a '55.
    It was months after The Last Drag Race, and for sure was the very last p***, made by a garage-built drag car driven on the street illegally.
    The p*** was made in the left lane as the bulldozers were tearing up the starting line area of the right lane.
    The hardhats on the 'dozer crew were yelling and making a big scene, and it was drizzling, but the hook was there and the 13:1 LS-7 / M-22 / Olds was speaking through a set of Lakewood Pos-A-Tractions and it found its mark halfway through second gear and made 7,400 in 4th at what would have been the lights at the big end.
    I always thought that it was very appropriate that Lions was finally shut down not by a construction crew that day but an open-header owner-built '55 running low 10s at OCIR and driving there and back on its own tires, in true hot-rodder style.
    I don't get to post much due to time but it's so cool to read thoughts written by people who I understand and can relate to. Great membership here, for sure !
    Long live the postwar-style junkyard-built American Hot Rod !!
    Eric
  23. Track-T
    Track-T
  24. Searcher
    Searcher
    Heres a couple more shots of the 55.
  25. Fogger
    Fogger
    Searcher, The above pictures were taken before I removed the vent windows and replaced all the side gl*** with Lexan. The hood also is steel and when we installed the big block I used a fibergl*** unit. These were probably some of the last shots taken when I was still running the small block, which belonged to Dave Christie. Car ran 11.21 @ 121 at Carlsbad. Dave went on to work on Mopar pro-stock cars and was very successful. Again see you guys at the Roadster Show. The FOGGER
  26. Searcher
    Searcher
    Thanks for the added info, Fogger. My buds and I have been enjoying talking about the old g***er. Where were the last pictures taken ?
    It would be cool if it turned up someplace. I'll keep after it.
    I was thinking because it was a pretty nice car and build it might just be out there someplace in a backyard or ?
    And yes, see you at LARS...we're ( me and the two guys that were in the San Fernando pic ) are going to Limeworks tomorrow.
  27. Fogger
    Fogger
    Those shots were taken at the shop we rented on Rowena Ave near Silverlake. There were 8 of us that shared the shop. Carl's was the body shop next door our shop was to the right. I had access to a spray room (not a booth) where I painted choppers and hot rods. Doing paint jobs and changing automatic trans Chevys to 4-speeds was how I could afford the '55. I'd work 40 hours a week on customers projects and 40 hours a week at night on the '55. Those were the days.
  28. falfas55
    falfas55
    What a great story.I love those 55 chevys.I'm building my 7th one as we speak. It is g***er style.FALFA
  29. Fogger and Searcher,what a great thread.Love that injected big block.Thanks for the story and pics of the cool 55 ....White Lightnin.
  30. ShakeyPuddin55
    ShakeyPuddin55
    Just found this. Great post!!
