Exhaust manifold gasket material
Discussion in 'The Hokey Ass Message Board' started by Captain Freedom, Jun 15, 2009.
  1. Captain Freedom
    Captain Freedom
    from Upstate SC
    What I want to do is make some exhaust pipe flanges, weld the pipes to/in them, and have the flanges bolt to the manifolds and seal like headers do.
    What kinda material should be used for the gasket?
    Copperplate, aluminum flashing, welding blanket, oven mitt, asbestos shingles?
    The parts stores don't have anything (plus they probably all hate me), and I want to go riding tonight. What about High-temp silicone?
  2. choppintops
    choppintops
    Soft copper always works.
  3. bbtom30
    bbtom30
    from so. cal
    Hi-temp silicone is what Sanderson recommends.
  4. choppintops
    choppintops
    As costly as thier stuff is, they shouldn't need anything to seal them :rolleyes:
  5. undergroundss
    undergroundss
    I get 12" x 28.5" sheets of exhaust gasket material at NAPA. #2499 (Fel Pro, "Pro Ramic"). It is perforated sheet metal between layers of composite material. It can be cut with sheet metal shears. I use a Dremel with a cutting disc for the small, tight areas. Permatex copper high temp spray works well when applied to both sides of your custom gaskets.
    tb33anda3rd likes this.
  6. deuce666
    deuce666
    from Oregon
    Undergroundss - when you use the Fel Pro exhaust material, do you still need a soft metal wrapped around either side? thanks.
  7. gas pumper
    gas pumper
    I used something from Jeg's on the BBC lakester. It came in a sheet and you draw it out and cut it. I used the gasket making hole punches for the radiuses and hand sheears for the straight cuts. Looks like factory and it was a paper kind of material on the outside of a metal perforated core. Nice stuff. They have been on for 3 years and the material is great. We take the headers off a lot. We had no luck with premade gaskets that didn't fit right and always blew out where there wasn't enough support.
  8. blue 49
    blue 49
    from Iowa
    I did what you're planning to do to bolt my pipes to rams horn manifolds. I used Mr. Gasket header gasket material. Anyone that sells their header gaskets should have or be able to get it in sheets.
    Gary
  9. deuce666
    deuce666
    from Oregon
    I used the Napa /Fel-pro "pro ramic" material. It worked great!! Thanks much
  10. greg32
    greg32
    from Indiana
    Flatout Gaskets in Illinois can make a copper custom gasket for you
  11. '51 Norm
    '51 Norm
    from colorado
    I had a set of headers that I couldn't get to seal no matter what. One night I needed to get them back on and didn't have anything to use as sealer or gasket. So I "temporarily" installed them using 100% silicone bathtub caulk. Three years later when I sold the car the calk was still sealing the headers.
    It worked for me, your mileage may vary.
  12. undergroundss
    undergroundss
    I did not use any additional materials.
  13. Bandit Billy
    Bandit Billy
    I have several cars with headers and I use RemFlex gaskets. http://catalog.remflex.com/
    No retightening of bolts, great seal, long lasting. I hate replacing header flange gaskets, so I really don't care how much I have to pay to prevent the h***le of doing it over in a couple of years.
  14. What wrong with a regular old doughnut gasket? They never leak or fail unless you ****emup or the bolts rot away?
    Or no gasket
  15. Bandit Billy
    Bandit Billy
    You ever seen a V band clamp? I just used these on my 34's exhaust system. No gasket, perfect seal, easy removal and ***embly and takes up less room. Weld the machined ends to your pipes, slip on the clamp and tighten. The clamp pulls the two pieces together. I used them on my headers, mufflers and tail pipes.
    H380 likes this.
  16. deathrowdave
    deathrowdave
    from NKy
    Turbo Diesel Clamps !
  17. Great clamps, don't work for **** on manifold end though.
  18. Bandit Billy
    Bandit Billy
    Very true, that's what the remflex gaskets are for.
