I.D. E.T's
Discussion in 'The Hokey Ass Message Board' started by chopped, Jun 15, 2009.
  1. chopped
    chopped
    Could this be one? I picked up two Sunday at a junk shop. One has a depressed area for the lug washer the other dosen't have the depression. Any ideas?[​IMG]
  2. choppintops
    choppintops
    Really small pic.
  3. chopped
    chopped
    I can't get it to resize, If I can run down a 5 yr. old to fix it I will.
  4. GreenMtnBoy
    GreenMtnBoy
    All the ET 5-spokes I've seen have ET cast into the front side of the web between 2 spokes.
  5. Weasel
    Weasel
    Some of the ET five spokes were two piece construction with a steel rim and aluminum center. I have both types. Take a magnet to the rim and see if you have one of each.
  6. Fwiw - a couple of ET slot mags I have, have ET lV cast onto the inside rim flange.
    If they p*** the magnet test, you may have a pair that were part of a running change during manufacture.
    Get some close-up pics of the wheel flange area - both sides, both wheels.
    If you can't resize them, send em to me and I'll see what I can do.
    C9Mach@msn.com
    If it turns out you have a couple of 'orphans', somebody has the other one and you could always do a swap, buy, sell....
