1952 chevy rear axle options
Discussion in 'The Hokey Ass Message Board' started by FRITZ, Jun 15, 2009.
  1. FRITZ
    FRITZ
    I picked up a 52 chevy hard top that has no rear in it, what can I get that will bolt in or comes close, something late model that will work with a small block and automatic. I have no rear springs either. any idea what will fit or where I can get a set?
    FRITZ
  2. FRITZ
    FRITZ
  3. Second Gen Camaro. Drill a hole for the locator pin so the wheels are centered and the rest is cake.
    55-57 Chevy is close enough to work too, lots of others will fit physically but the perches need to be moved.
    No other springs but 49-54 Chevy or the Posies made for these cars fit, because they're narrower than most others. If you just need to cob it into a roller, some 4x4 pickup front springs could be made to work with a little t*******.
  4. FRITZ
    FRITZ
    NewYorker thanks for the info.
    Anyone ever done this swap? whats a new set of springs go for?
    FRITZ
  5. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I am putting a '53 Olds rear in my '54 Chevy. Open Driveline and all around pretty rad Rear. Have not done it thought so i can't tell you if it's difficult or prices yet.
  6. I've used the Posies Super-slider springs and the Ch***is Engineering springs....liked 'em both. Unless you can find 'em used (which I was lucky enough to do), you'll pay $350-500. The Posies are cool 'cause they use the original shackles. The CE springs come with shackles, so you'll have to drill or torch the rivets out of the frame that hold the stock ones. Both will drop your car a few inches and still ride smooth.
    Another option for cheap and plentiful rears is S10 4x4. You'll just need to cut of the spring perches and weld on a new set. The Mopar universal perches work nice for this...$11 at Summit.
    Bryan
    RJ Mora likes this.
  7. atomickustom
    atomickustom
    Brand new springs I seem to recall cost me around $300? That was for the Posies "superslides." Stock replacement springs are $270 from the National Chevy ***ociation.
  8. 49ratfink
    49ratfink
    ch***is engineering sells a spring kit for these with springs shackles lower shock mounts the whole 9 yards. 5-6 hunred bux I believe
    prolly something in the chevs of the 40s catalog, and even fatman has some listed.
    these are very popular. I don't think it would be too hard to get another set of stock springs off ebay or locally.
    I've never used one but a S-10 4x4 rear seems pretty popular for these. had a 2nd gen camaro rear in my old sedan. it was a bit wider than stock, I had aftermarket chrome wheels and couldn't run my skirts.. it was close, so prolly with stock 5" rims it would work
    the one i have now has a 65 Nova rear. first year for the 10 bolt and narrower than the 2nd gen camaro, and I think even narrower than stock. not sure when novas got wider, but the 67-69 Camaro is the same width.
    had a 53 with an Mopar 8 3/4 rear... don't know what it came out of though.
    I don't have a stock one sitting around or I'd go measure so you can take your tape measure to the wrecking yard and find one that works. maybe someone else here could do that for you.
  9. sharkfoodjohnny
    sharkfoodjohnny
    The stock rear end in a '52 measures 60". A 55-57 chev and 1st gen camaro rears are also 60". Ch***is Engineering, Posies, and a host of other companies make spring kits for these cars. The hardest part is drilling the rivets out of the spring brackets.
  10. BadLuck
    BadLuck
    I used a 75 Nova rear end in my 52...worked out great....
  11. jmschristiansen
    jmschristiansen
    My brother & I put the rear end & springs from a '69 Camaro under my '49 Fleetline. Had to fabricate the brackets, as the original springs are parallel, and the Camaro's are narrower in the front than in the back. A day's work, and it ended up pretty nice.
  12. firemancooter
    firemancooter
    I have 78 Camaro springs under mine. They work pretty good. I also have a set of stock springs I will make you a deal on if you are coming to this side of the state.
  13. junkyard junky
    junkyard junky
    I just put a 57 chevy in my 52. Had to buy Mopar spring pads. They already had a hole for the offset.
  14. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    8.8 mustang explorer
  15. Lowbrow52
    Lowbrow52
    I have a 74 Nova that I am getting ready to put under my 52.
  16. SLAMIT
    SLAMIT
    I put a 64 chevelle rear in my 49 fleetline. Perfect width. I bought a ch***is engineering rear leaf kit to locate and then hated how it sits in the rear. So now I am going to 4 link it with bags and a notch.
    Honestly if you dont have anything under it already buy the 4 link kit from Alex Gambino. This thing is amazing and worth the effort. you will spend about the same in the end no matter what. and you cant argue that it will work better and look way cooler as well.
    The moral of my useless rambling is that I wish i would have not tried to be a cheap *** and half *** it. I could have done it the right way first and spent half the money.
