Top chop; Top is marked;; PICS;;;
Discussion in 'The Hokey Ass Message Board' started by RUSTY50F1, Jun 15, 2009.
  1. RUSTY50F1
    RUSTY50F1
  2. brewsir
    brewsir
    You have more patience than me ...if I had it layed out it would have already been cut!
    Only problem I see is you will have some work on the sides of the back window getting a nice shape...nothing some pie cuts can't fix.
    That and you didn't like my advice on chopping the windshield an inch less than the rest....but that's OK!
  3. RUSTY50F1
    RUSTY50F1
    Sorry brewsir; I didn't understand what you ment about the 1''. I took the pics before I read you post. RUSTY
  4. brewsir
    brewsir
    You don't have to apologize to me...I'm not hurt if you don't do something I suggested...hell I don't know it all (I just think I do!)
  5. el conejo 1964
    el conejo 1964
    have you considered keeping the rear window stock height? Check out the idea below and a photo of a chop I did. I think it looks way better with the rear window down to the beltline with all the other windows. otherwise, you'll end up with a little"mail slot" window=usually ugly IMHO.
  6. el conejo 1964
    el conejo 1964
    and by the way, it only makes the chop easier as well as looking better, because the rear window keeps its perfect lines all around.
  7. brewsir
    brewsir
    looks kinda like a studebaker with a fullsized window in the rear. I like them lowered an inch or two to center the window...not sure about the full size tho
  8. el conejo 1964
    el conejo 1964
    its a studebaker.
  9. Brewsir and I chopped mine with one inch less on the windshield to get rid of the "forehead" problem that f 1's have. I think it gets worse when you chop em. If I do one again I would go 1 and 1/2 inches less on the windshield and get rid of more forehead. The back window we tried stock at first and it looked to big, sounds funny but the truck almost didn't look chopped from the rear. any way, looks good now stop thinking and start cutting.
  10. RUSTY50F1
    RUSTY50F1
    Truck looks great Tiny; How much did ya take out? RUSTY
  11. slam49
    slam49
    from tulsa ok
    i think you should keep more of the rear window, as others have said.
  12. NTAPHSE
    NTAPHSE
    No suggestions for the chop but you can take acetone to that GM column to remove the blue paint and it's black underneath.
  13. resqd37Zep
    resqd37Zep
    from Nor Cal
    Damn thats a smart trick!
  14. mikes51
    mikes51
    I think the windshield comment is pretty valid. I remember how well Renee's panel came out with the slimmer "forehead".
    Question, arern't all pickup tops quartered when chopping? I didn't see that in the marks. Brewsir, do you think it can be done by slanting the "b" pillar forward? Without quartering, isn't that going to require slanting the back window forward at an angle? Or is the windshield going to be angled back, bonneville style?
  15. NTAPHSE
    NTAPHSE
    Anything to avoid spraying paint in the interior. :)
  16. brewsir
    brewsir
    I quarter all the trucks I chop (except Renee's panel which was done in 3 steps) on most of these trucks a guy could possibly get away without widening the roof any but you either have to lengthen it (about 1 1/2 - 2 inches) or lean the windshield back like you said...bonneville style. But I like a low wide roof with the stock windshield angle myself....so I quarter them. Can't say I have ever seen one done by leaning the back of the cab forward...but I guess it could be done...and in conjunction with leaning the windshield back could give a really unique look....would be a lot of extra work though.
  17. F-6Garagerat
    F-6Garagerat
    This is a 48 F-6 cab, 4 inch chop at all 4 corners, roof was quartered, rear window bottom resized to match top after it was re-attached. Metal work is not done, was our first chop ever. We like it.
  18. custom50
    custom50
    from Indiana
    el conejo 1964
    Don't want to change the subject.
    Just a quick question is that a special mix bronze paint? It looks like bronze in the picture. What ever the color the truck Looks great.
    Thanks
  19. charger
    charger
    from manitoba
    i i would try to keep the same size, here`s a pic of my `55 chopped with the back window the same size,looks more porportioned i think?
  20. RUSTY50F1
    RUSTY50F1
    F-6Garagerat; I like the chop got any more pics up close. RUSTY
  21. fireball350
    fireball350
    Like it has been said, stock sized rear window will make it look too big and not chopped. Try taking a few inches less than the rest of the truck to make the rear window smaller but it will still be large enough to use as a rear window.
  22. F-6Garagerat
    F-6Garagerat
    Thanks, it was our first and we're happy with it. I'm at work now but when I get home tonite I'll send you some more.
  23. I think it was 4 1/2 from the doors back and 3 1/2 at the windsheild, but it might have been 5 and 4. Look at the windsheild of the F 1 with no fenders and you can really see how the forehead has dissappeared on my old truck. I just like the back window smaller but again its your truck do what you want to do to it.
  24. brewsir
    brewsir
    looks good but damn thats a lot of work for 1 inch!
  25. pimpin paint
    pimpin paint
    from so cal
    Hey Rusty,
    I hope you're not over six feet tall! F-1s don't have alot of room to begin with in the cab, chop one this hard, and things get tight inside!
    I wouldn't four-quarter the roof panel on a chop like this, but I'd leave the center of the top panel intact. Add or subtract metal, as necessary, around the edges of the top panel, beside the Header, Cant & Backlight Rails to acheve the necessary amount. This method will enable you to dress the welds, and keep you from having to weld through the near -dead flat area of the top panel. Too, this method will keep what little filler pieces you'll need to add to the top panel to minumal.
    Swankey Devils C.C.
    "Spending A Nation Into Generational Debt Is Not An Act Of Compassion!"
  26. el conejo 1964
    el conejo 1964
    thanks 50. the color is a specially mixed copper with pearl added. Stan Betz at Betz Speed and Color in Orange Ca. mixed it up for us.
  27. banditomerc
    banditomerc
    cut the rear window out,it will probably match the rest of the windows once chopped:cool:
  28. brewsir
    brewsir
    I take it you've never seen TINY haha....he's about 6'2 280 and his truck is cut 5 inches plus a channel!!
  29. Ah thanx buddy, 280, your being nice:) Seriously though ya 6'2" and big boned, truck had better seat position than my 05 Tahoe has. I could drive it much further without leg and back pain than the Tahoe. Even with the 3 1/2" channel it was comfey. I used 66 mustang buckets and put the gas tank under the bed where it belongs. They only get small when you go stock bench and stock tank.
  30. on my 4 inch chop I took 2" out of the rear window 1" below and 1" above the window. also 4 inches on a slanted A pillar is less than 4 inches on the vertical B pillar
