What body filler are you guys using?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 29, 2009.
  1. K13
    K13
  2. blkcat77
    blkcat77
    Rage Gold + Rage extreme
    Seems to me rage extreme is a whole lot lighter than rage gold. It also levels itself pretty well without pinholes.
    Last time I used evercoat glaze it shrunk a lot. I guess I did something wrong but I sure wouldn't use it again.
  3. super plus
    super plus
    Oh!:eek: wait a minute we painted the car first then we put on the Bondo or hide a wobble, Ya thats what we did :cool:
  4. lesabre59
    lesabre59
    I gotta disagree..I found metal to leave less pin holes, easier to clean plus platic can get deformed easier and leave streaks in the filler..JMO!
  5. Speedmaven
    Speedmaven
    I like Rage Gold or Extreme, whichever I can get locally...Pricey, but worth it.
  6. MERRELL
    MERRELL
    rage gold....
  7. Chaoticcustoms
    Chaoticcustoms
    glaze isnt ment for filling, and probably dont wana put it over anything less than 150 scratches. Ive had shrinking issues and a buddy of mine used it for filler. I try and just use the rage extreme instead of the glaze. Really no reason for it if your using extreme. I hate glaze btw..
  8. chad
    chad
    I know this is an old post but...I have always used Rage but I recently tried the Fuzion and its as good if not better than the Rage for half of the cost
  9. bigern007
    bigern007
    Rage premium gold,,,,,,,,nice stuff
  10. PUTRID FAME
    PUTRID FAME
  11. herbet99
    herbet99
    from Central NJ
    I recently tried Martin CUZ (I think). Seems to work fine and you can get it at Napa
  12. I am by no way a pro but I have done a fair bit of my own work. I like the Evercoat line. I use the short strand filler over welds, Rage Gold over that , and metal to metal glaze over that. I use Slick Sand overall the fillers,and top everything off with Epoxy sealer . It works for me, my local supplier stocks everything so I am good to go . The labor in sanding and prep is the same weather you use a cheap product or the right stuff so why not spend a few extra bucks and be safe with a product line you can trust.
    Rex
  13. davis574ord
    davis574ord
    I have been using rage gold since it came out, easy sanding and hardly any pin holes as long as you mix it right! Kinda pricey but you get what you pay for, i fixed a van 1/4 panel and the whole thing was filler, insurance company to cheep to replace it, and a month later it was rear ended really hard, and the filler folded up with the metal and didnt even crack! Good stuff as far as im concerned! Good luck!
  14. Master of None
    Master of None
    Another one using Rage gold. Once you use it, its had to go back to the cheaper stuff.
