Ever seen one of these??? 1938 Mercedes
Discussion in 'The Hokey Ass Message Board' started by tbraginton, Jun 27, 2009.
  1. tbraginton
    tbraginton
    from Nevada
    Ok so here is the question is this actually a 1938 mercedes ch***is or is it something different... I take delivery of it tomorrow and just thought I'd put up some teaser pics until I can get a better look at it.
  2. looks about right- nice find! What are your plans?
  3. tbraginton
    tbraginton
    from Nevada
    Gonna get a better look at it (Bought it having only seen these pics). If its worth to much to hack up I guess I'll sell it to a purist otherwise I have every intention of taking the parts I like...
  4. James427
    James427
    Not real valuable as 170 models. Use whatever you can. The parts should make a cool rod.
  5. tbraginton
    tbraginton
    from Nevada
    I really don't know anything about it but the price was right. I take it you know more about these James?
  6. James427
    James427
    They made several models of Mercedes in the late 30's from ther smaller 4cyl 170's and 200's up to the 770's like what Hitler used to have. That's the baby Benz of the day. These baby Benz's never really bring much $$ unless they are an open car and restored well. You can find whole cars (sedans coupes) for about $6,000-$10,000 needing resto. so they are not big buck cars, but they still are expensive to restore. That one may be a little later, maybe like late 40's though. EVen though they were very similar. Mercedes names have typically been their engine displacement. So the Mercedes 170 would be a 1.7 liter adn the 770 would be a 7.7 liter. It's like that even today. You chasis will have a independant rear suspension which may be cool under a street rod and keep people guessing.
    http://www.motorbase.com/vehicle/by-id/-1301310608/
  7. tbraginton
    tbraginton
    from Nevada
    Whats up with the drivetrain looks like its got a unique rear end... Must be a few parts worth puttin on a rod
  8. Looks like a low-pivot swing axle typical of Mercedes up until the mid 1960's.The tube style frame is typical of the base model Mercedes of the era.I did some work on a 37 540K recently and it had a very substantial ladder type frame.It had been modified a bit with a newer 6 cylinder(77 280SE)and Corvette independent front and rear suspension.Probably will be the most expensive "hot rod" ever.Owner bought it without an engine and transmission and looked for years for a correct one.Finally found one for "only" $675,000 dollars.Decided he'd modify it a bit.Hopefully it will be finished and at Detroit next year.
  9. Side
    Side
    Sooo it's an oil burner. I'm confused about the year then.
  10. tbraginton
    tbraginton
    from Nevada
    Okay so I got it today and I took a few more pictures... albeit ****py pics!
  11. povertyflats
    povertyflats
    from Missouri
    Interesting. Not something you see in KS too often.
  12. tbraginton
    tbraginton
    from Nevada
    Thats kinda what I thought! There are quite a few goodies on there ripe for the picking...
  13. sawzall
    sawzall
    i think its newer than 52...
    I have been working on this one.. which I think is a 51 or 52 170...
    http://public.fotki.com/sawzallshop/portfolio-2/benz_restoration/dsc02935.html
    notice that the engine is a flat head
    additionally the front and rear suspension on this one has leaf springs..
    also.. the fancy flex tube on your exhaust system is indicative of a later vehicle.
    be glad you dont have the body..
    the one I am working on is wood structure with steel over..
    they are difficult, and costly to restore
  14. tbraginton
    tbraginton
    from Nevada
    I wondered about that... All the pics I could find of 30's era merced's looked a whole lot different but I could never get a good pic of the ch***is so I didn't know. Any good search engine for the vin?
  15. The Cap'n
    The Cap'n
    from Kansas
    You should register at Benzworld.org
    It's the site I used a lot when I was still driving the 560SEL...and they have forums for different models.
