Features The 1955-1956 Plymouth and Dodge Thread
Discussion in 'The Hokey Ass Message Board' started by MrBelvedere2, Feb 12, 2009.
  1. MrBelvedere2
    MrBelvedere2
    from Davis, CA
    what's up everybody, it's been a little while, what's everyone doing to they're 56 Plymouths lately? I myself have just been driving and enjoying it, I am about to get the generator rebuilt though as it seems it's not charging all of sudden....
  2. FunnyCar65
    FunnyCar65
    from Colorado
    I pulled the engine and trans so I can rebuild both then I'll start on the body work.
  3. plodge55aqua
    plodge55aqua
    from Alberta
    Im waiting for a Exhaust Manifold to arrive.. Broke the Drivers side off on a speed bump last Tuesday.. It the Nicest day so far out of the Year.. and Im grounded..
    Hope every one is doing well..
  4. Squablow
    Squablow
    Has anyone ever swapped a different radiator into these cars? My '55 Dodge was running so nice, but it majorly overheated the other day, blowing a huge amount of antifreeze out. It might be something simple, I haven't really looked at it yet (I was so disgusted, I got it back to the shop and left it there) but if I do end up needing a radiator I'd like to know if there are any easy swaps. Having the stock one recored would be great but it's so expensive.
    Last week I finally got my new fuel pump and installed it, the car ran great, I put the door panels back together which turned out really nice, and drove it quite a bit. I thought I had finally reached daily driver status with this one. Maybe next week.
  5. sickboy713
    sickboy713
    from oildale
    put some stripes on the car and changed the wheel color
    Chilberto likes this.
  6. RPM Ron
    RPM Ron
    my 56
  7. MoonshineRoyal
    MoonshineRoyal
    Finally got some pics of my Royal on my computer, so I thought I'd show her off. The last one is my dog, Mopar, sitting in the front seat and in serious need of a haircut. Right now I've just been working on the starting system, so I can get her to crank.
      218.6 KB
      210.5 KB
      207.8 KB
      152.5 KB
      133.9 KB
  8. SapienKustom
    SapienKustom
    from Merced, CA
    Hey thats my 55 in Santa Maria. I need to figure out what I'm going to do for a grille. thanks for posting them up.
  9. FunnyCar65
    FunnyCar65
    from Colorado
    The grill treatment on this 55 is kinda cool.
  10. patrick66
    patrick66
    Looks like a portion of a '55 or '56 Olds grille, I don't remember which is which.
  11. Squablow
    Squablow
    Being that it has parking lights in it, I'm guessing it's a 55 Chrysler bumper bar.
    True to form, I got my cooling problem in the '55 figured out, then I had 2 days to drive it before it broke again.
    The cooling problem turned out to be a mouse nest in the top tank of the radiator, it was packed in when I took the cap off. Must have had a mouse build a nest in the engine while I had the water pump off for a rebuild. The cap and the thermostat would have prevented the mouse from getting into the radiator, so I ***ume it filtered it's way through the motor and got stuck there since it wouldn't go through the fins.
    Then, as I was driving it on Sunday, the lights got real dim and the battery gauge was showing discharge, so hopefully it's just bad connections and not a junk generator.
    This car sure has been a load of trouble for me.
  12. SapienKustom
    SapienKustom
    from Merced, CA
    I saw that wagon in Santa Maria and let me tell you it is a beautiful car! I really was digging the grille and had thought about using the Olds grille bar before, but I don't know if I want to copy the wagon. What do you guys think? Think it's no big deal to copy it or what?
  13. FunnyCar65
    FunnyCar65
    from Colorado
    Got started on the body work,made a couple of changes to the hood.
  14. 56 belvedere
    56 belvedere
    from France
    i have the same job with mine
  15. FunnyCar65
    FunnyCar65
    from Colorado
    How about the outer sections of a Henry J grill?The pieces with the park lights.
  16. SapienKustom
    SapienKustom
    from Merced, CA
    Hey those look pretty good. Thanks
    I like the work you did on your hood. Keeps us updated on your work.
  17. FunnyCar65
    FunnyCar65
    from Colorado
    Here's a quick sketch of what I have planned for the rear tail lights will be 58 Bel Airs.
  18. I still have my friends 56 coronet more door for sale $1500 OBO PM for details Larry
  19. SapienKustom
    SapienKustom
    from Merced, CA
    That's going to look good. I have always liked those taillights.
  20. MrBelvedere2
    MrBelvedere2
    from Davis, CA
    well I finally got though the mopar show season, it was about 105 degrees today in the swap meet area, sold some stuff, made out pretty good, scored a rebuilt 3 speed 727 for a big block for 150$ so now i just need to mock it up. come september the car is going down for a transmission and rear end swap. then save up for a new motor.
    One problem I am having though, is it doesn't seem to be charging all of a sudden. The amp light comes on at speed instead of idle like normal. I just put a new voltage regulator on 6 months ago, and the generator is putting out 12.13 volts according to the voltmeter. Could the regulator have fried on me? I did some research and peopel have said you use a solid state regulator, part# VR706 to replace the points style one. The only problem is that mine has 3 connections ( ARM, FLD, and BAT) while the VR706 only has 2 ( BAT, FLD) so how would I go about wiring it in? just put the 2 wires in the same connector? It doesn't sound right to me....
  21. 64gal500
    64gal500
    from Dexter MI
    ok newbie here and know nothing about old plymouths but just made a deal on a 55 plaza more door str 6. love the hooded eyes its what drew me to the car so any advice for a new guy?
  22. DRUGASM
    DRUGASM
  23. RPM Ron
    RPM Ron
    That's going to be a good looking ride - can't wait to see more pictures
  24. 64gal500
    64gal500
    from Dexter MI
  25. 56 Dodge Pickup
    56 Dodge Pickup
    Hey I just wanted to share some pics of my 56 Dodge truck this first one is at Watkins Glen getting ready to go the track for some laps! [​IMG]
    This is a shot of the chrome firewall and the slant six motor [​IMG]
  26. rrunner
    rrunner
    from florida
    56 Plymouth 015.JPG Hi all, new here this being my first post. I just bought a 56 2dr wagon and finally got it home, Florida, from Cali. and cleaned up. I am very interested in parts, not being able to find many as of yet. I am in bad need of a rear gl*** and gasket or a entire hatch with the gl***.io keep it dry for now Any ideas where to find any wagon parts?? Thanks.
  27. George
    George
    Do an intro! Check out www.forwardlook.net
  28. 64gal500
    64gal500
    from Dexter MI
  29. missysdad1
    missysdad1
    Your car reminds me of my grandfather's, though his was a 4-door. It was an ex-state police cruiser from Maine, though I don't think he ever knew it. It was just a good, solid late model used car to him. It had been repainted a light green, but you could still see where the bubble gum machine and the whip antenna had been.
    That car would haul a**!!! It had the big 4-barrel motor with push-****on automatic and factory dual exhaust! It would smoke the tires as long as you wanted (Don't ask...)! :rolleyes:
    But it wouldn't stop worth a darn. Grampa was hard of hearing and couldn't hear the metal-to-metal groans in the brakes until it was too late. He and Grammie were okay, but the car didn't make it. :(
    Too bad. It was a great car! :)
  30. noodles56
    noodles56
    Was hoping someone here could help me with my 56 Savoy. I got some NOS fender skirts and I can't figure out the mounting hardware that came with it. I can post some pictures but basically there are two brackets for each side. One shaped like a triangle and one with an oval hole on it. There are 6 holes total for bolts, yet only 4 bolts were in the kit (which is what the kit says on the cover so I ***ume it's complete).
