1960 corvette straight axle installation
Discussion in 'The Hokey Ass Message Board' started by Larrysgarage, Jul 6, 2009.
  1. Larrysgarage
    Larrysgarage
    from Palatka,Fl
    Hey guys, any body got any thoughts on axle type,whether stock steering will work,any hints on installation? I think I would like to bolt spring hangars to frame, and use stock spindles and drums at least for now. thanks in advance,Larry
  2. NeverEnuf
    NeverEnuf
    from Louisiana
    The stock drums on the Vette are the same as the 49-53 Chevy which some local guys use on 55-59 Chevy truck straght axles. There is a guy in Houma used this before on his 57 Chevy car.
  3. spinn427
    spinn427
    from indiana
    HOw much wider is the 55-59 chevy truck axle than the 48- 54 chevy truck axle?
  4. brigrat
    brigrat
    from Wa.St.
    The hole front clip & box is same as the '49-'53 Chevy car. You won't want to use the stock box. Better off sub framing the front with 2x3 and build fron there............... JMO
