Homemade gas pedal pic's
Discussion in 'The Hokey Ass Message Board' started by nickpayton, Jul 5, 2009.
  1. nickpayton
    nickpayton
    from a
    I would like to say first that I did search and I did find a few threads, BUT most of the pics were gone and the ones that did have pics there really weren't a lot to see. I even searched the regular old inter net.
    So with that said, I'm wanting to make my own gas pedal and I want to see what you guys did and maybe get some ideas for mine. Let's see some pic's of your homemade gas pedal, please.
  2. treb11
    treb11
  3. nickpayton
    nickpayton
    from a
    Thank's, that's one that I've already seen.
  4. leaded
    leaded
    from Norway
  5. X38
    X38
    Mine
  6. poofus1929
    poofus1929
    from So Cal
    Nice work
  7. edsel
    edsel
    I don't have a pix but I have good luck using early ford pedals , my last one came from a mid sixties T-Bird with stainless trim , what is nice about these is they bolt flat to the firewall with two bolts and you can use a cheap after market throttle cable you cut to fit, these make a clean install and they are comfortable on your foot during long drives , you do plan to drive the **** out of your rod ? Right ?
    Edsel
  8. burtrido
    burtrido
    Didn't Nads make a really cool Pedal a while back.:D
  9. Toast
    Toast
    from Jenks, OK
    Here is one I just made out of 5/16 bar stock and a couple of hiems, Oh yea, and a base drum pedal:D
    Here it is with the interior mocked up.
  10. geage
    geage
    [​IMG][​IMG][​IMG][​IMG]
    heres my pedal, its rude and crude, but it works like the wind , when I punch it to the floor old lady's cover there ears and run like hell,rubber and smoke fly all over the place.and for some strange reason I get this uncontrolable **** eating grin on my face
  11. dawg
    dawg
  12. chopt49
    chopt49
    Now that there is cool!
  13. Canuck
    Canuck
    Kind of different. Mounts on outside of the firewall with return spring running vertically and a rod to the carb. The large end is a mount for one of the switches to control the Switch Pitch. Made out of bits and pieces of the original from the engine donor.
    pecker head likes this.
  14. Kevin Lee
    Kevin Lee
    Super Moderator
    Hahaha.
  15. swade41
    swade41
    from Buffalo,NY
    No pictures but I was experimenting with a straight rod through the firewall to a bell crank that attached to the the carb. The rod was spring loaded with just a flat ****on s**** type end on it. It would have been great in the tight confines of my T but the rod was to far to the left near the steering column to work out.
  16. nickpayton
    nickpayton
    from a
    This is some good stuff. Keep 'em comin'.
  17. beverlyhillbilly
    beverlyhillbilly
    From stock Model A Ford.....
  18. axeman39
    axeman39
    from Saco Maine
    kick b*** pedal with linkage from a late model gm something or other, cable to carb.
  19. jamesgr81
    jamesgr81
    Ludwig pedal is the cat's ***! Speed King says it all......
    Great job.
  20. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I like that idea..I got one of those laying around too..
    not sure if it would work for my build yet
  21. GAB-KC
    GAB-KC
    Here is a pretty simple little pedal. Some round rod, a piece of square tube to cut the bracket from, a piece of tube for the trunion, and a bit of plate for the s****.
    Dave50 likes this.
  22. nickpayton
    nickpayton
    from a
    Kiwi Kev, do you have a close up of the pivot from the top point of view? I hand to see how you have it all bolted together. It's cool looking.
  23. Von Hartmann
    Von Hartmann
    Theres a real easy way to make the pivot for your linkage. Unspoke the hub out of a front bicycle wheel and weld some arms to the spoke flanges.
    Its smooth as hell cause it's all ball bearings.
  24. beverlyhillbilly
    beverlyhillbilly
    Works good..for the flathead..the part where it connects to carb has to be bent around where it will pull instead of push..use a lengthened Model A throttle rod on flathead..
  25. lakester47
    lakester47
    Here's a pic of mine, sorry that the photo isn't any better.
  26. nickpayton......Here is a shot of the other side....
  27. nickpayton
    nickpayton
    from a
    Thanks Kiwi Kev!
  28. Asphalt Outlaw Hero
    Asphalt Outlaw Hero
    from Dixie
    This is the bicycle hub set up on Kevein Lee's old car (now mine).
