HEAT Coatings on Headers
Discussion in 'The Hokey Ass Message Board' started by The37Kid, Jul 3, 2009.
  1. The37Kid
    The37Kid
    I'll need to get the headers heat coated on the Lyndwood. I'm sure they just used white hi temp paint back in the day but who does the best heat coating today?
  2. HotRod31
    HotRod31
    I use Nitro Plate,no complaints.
    Later, Mark
  3. Clark
    Clark
    Lately we have had no luck with the white header coating. The next set I do will get your normal silver coating...then scuffed and shot with white header paint. The coating should keep the heat down just enough to keep the paint nice.
    Clark
  4. plym49
    plym49
    from Earth
  5. Bosco1956
    Bosco1956
    from Jokelahoma
    I did that on a set of bbc ch***is headers in a 55 chevy. Worked very well.
  6. damnfingers
    damnfingers
    I second JetHot....won't rust from the outside in or the inside out...plus great heat transfer
  7. tommy
    tommy
    years ago between VHT paint years and the current Jet Hot coatings we used to get the headers and manifolds "aluminized" It lasted very well and came out white. It is not smooth. It has a textured finish. It's actually an industrial process that melts the aluminum and sprays it onto the headers. If you want white headers that last you might investigate this process. It wasn't that expensive. It just got over run and forgotten by the current coatings. It fell out of favor.
  8. HealeyRick
    HealeyRick
    from Mass.
  9. 5window
    5window
    I've evry happy with my Jet-Hot coated headers. Noticed they weren't a vendor at the York NSRA show this past June-but then neither were about 40% of the other usual suspects so I am not sure it means a lot.
  10. damnfingers
    damnfingers
    I've got a friend here in Mississippi that's bringing back the aluminizing procedure. The early MG T-series exhaust manifolds were aluminized but we've been having to go to the JetHot procedure since no one was able to do the aluminum coating. If interested PM me and I'll give you his name and address.
  11. Buzznut
    Buzznut
    I've always believed that the best way to keep them from overheating is to do both the inside and the outside...especially with cast iron exhaust manifolds, but supposedly makes a difference with headers too.
  12. Shifty Shifterton
    Shifty Shifterton
    I always wondered what happened to the coating. It was like they coated the hedders with well-worn 36 grit sandpaper
    Biggest drawback was it's ability to attract a greasy hand print. But was a really interesting finish and you could actually tap them with a hammer for clearance without spiderwebbing half a tube like with ceramics.
  13. colorado51
    colorado51
    Had the headers & exhaust pipes (w/mufflers) ceramic coated. Not cheap, but it seems to hold up great.
  14. tommy
    tommy
    The nice thing is that it stands up to Gum Cutter and it can be touched up with VHT white for stains etc..
    It's not a difficult process. I understand that all that it takes is an OA torch and shop air. One of the local body shop/hotrod shops used to do it for the local rodders.
    A machinist friend told me that the system was actually designed to build up large expensive worn aluminum castings for re-machining to factory specs. Somebody came up with the idea of using it as a decorative finish for headers and manifolds. I still have one side of some block huggers that was done over 20 years ago.
  15. Sho Nuff
    Sho Nuff
    Hi temp powder coating works good. Not as costly as ceramic. Very durable and oil and other **** comes off pretty easy.
  16. Bad 35
    Bad 35
    Plus 1 on the powdercoat
  17. stealthcruiser
    stealthcruiser
    We have it here at work......2 kinds..... a flame spray,(oxy-acetylene) with aluminum wire fed into the fire.........and plasma spray, for rebuilding worn surfaces prior to machining back to specs.
  18. MFP2241
    MFP2241
    Another vote here for aluminum coating with good old BBQ paint from Home Despot. The coating REALLY soaks up the paint so it takes quite a few applications, but once it's painted it hold up well and touch-up is a breeze.
    I got the ones for my '64 Falcon done recently for $100
  19. Ayers Garage
    Ayers Garage
    I don't know about the powdercoat. I do powdercoating near full time and have never found a high temp powder that I can stand behind. It all looks great but doesn't have any real durability. It's so bad that I don't even offer high temp powder work anymore, just the regular 450 degree stuff.
  20. George G
    George G
    VHT high temp white is total ****. Burned off right away.
    RoddyB34 likes this.
  21. BigChief
    BigChief
    I 2nd the vote for Swain Tech.
  22. The Wizard!
    The Wizard!
    Another satified Jet-Hot Customer here~
