Had them and lost them... anyone have the part numbers (napa etc.) and or application for the components in the GM metric disc brake kit for 37-48 ford spindles?? rotors, bearings, seals, etc... thanks.
looking for the NAPA/part numbers/application for the rotors, inner and outer bearings and seals. i have the calipers and pads dialed but i dont know what to ask the counter guy for on the stuff listed.
Again these are speedway numbers not from there parts book so they might match up at the parts counter at napa for cross reference (rotors 910 31067) (912-TLM11949 outer wheel bearing)with this number they can prolly get you the inner bearing number. ( seals 912-S18580) These numbers are off my shipping papers hope this helps...ghost
I spent 6 yrs working an auto parts counter and while it's been a few years now that outer bearing number is a standard number. All bearings and seals should be standardized. I don't have experience with Speedways part #'s but that TLM11949 is a very common GM wheel bearing so I would guess that they use the standard numbering system. It's the same numbers regardless of manufacturer. Hope this helped.
I thought they were Chrysler Cordoba caliper for the 4.5" bolt circle. I have the instructions at home and the bearing parts are all able to be crossed to a name brand bearing. I will have to look and see if there is any more info....I thought this parts list(w/Napa numbers) was in tech at one point but I do not see it.
scrounged around and found the speedway parts list. unfortunately the bearing numbers dont cross in my program... gonna put a call in and see if the counter guy can help 1* Bearing adaptor 910-09301 2 2* Caliper bracket (left) 702-4475-1-L 1 2* Caliper bracket (right) 702-4475-1-R 1 * Hardware kit 702-4475-2 1 3 1/2”-20 x 11/4” ****on head bolts in hardware kit 8 4 1/2”-20 nylock jamb nuts in hardware kit 8 5* Inner bearing cup 912-TL68110 2 6* Inner bearing cone 912-TL68149 2 7 Grease seal 912-S18562 2 8 73-77 GM intermediate rotor 910-31063 2 8 Ford bolt pattern rotor 910-31067 2 9 Outer bearing cup installed in rotor 2 10 Outer bearing cone 912-TLM11949 2 11 Outer spacer 916-15901 2 12 ** Spindle washer in spindle nut kit 2 13 ** Spindle nut in spindle nut kit 2 14 ** Cotter pin in spindle nut kit 2 15 ** Dust cap (pr) 550-2486 1 16 GM metric caliper (left) 910-31045-L 1 16 GM metric caliper (right) 910-31045-R 1 17 Brake pad set 919-3381 1 18 Caliper bolts 835-2300542 4 19** 37-48 Ford spindles (pr) 916-32104 1
The part numbers you have listed for the bearing are for individual bearings or races. Most parts stores will have these in stock as a set with both. Check this site, your numbers are listed here. To the right is the part number that will likely be on the shelf at the parts house. ex: a2, a3, a6, br2, br3 etc Cesar http://www.koyousa.com/PDFsnomenclature/Taper_Set_Inter.pdf edit: also note that some sets use the same number bearing and but different race(or cup)
The rotors are RAYBESTOS Part # 5214 ,,,,,, BCA/NATIONAL Part # A2 Outer bearing ,,,,,,, BCA/NATIONAL Part # A6 inner bearing ,,,,, BCA/NATIONAL Part # 8871 seal
