buick straight 8 guys- quick question
Discussion in 'The Hokey Ass Message Board' started by MIKE47, Jun 12, 2008.
  1. MIKE47
    MIKE47
    from new jersey
    Anyone know what other years/engines intakes are compatable. I have a 1953 263 and need to find a 2x2 intake for it. What other intakes (years) will fit?
  2. Aaron65
    Aaron65
    from Michigan
    Intakes from any 248/263 will fit...320 intakes will not...Go check out buicks.net and look at the straight 8 section. There are guys building manifolds on there right now...
  3. Lobsterboy X
    Lobsterboy X
    Ive been told that the only stock 2x2 manifolds were made in 41. i had a lead on one for my 320, but i dont know anyone who can weld cast iron..
  4. MIKE47
    MIKE47
    from new jersey
    So what years did they come in?
    248...... 19??-19??, etc?
    263.........
    320........
    Sorry to ask so many dumdb questions. I'm new to these and have no knowledge of them at all.
  5. Buford
    Buford
    1941 and 1942 :)
  6. art.resi
    art.resi
    I had a 41 special 4 door with two 2's. Ran good.
  7. diego64
    diego64
    from oceanside
    1941 and 1942 buicks had dual carb intake and dual exhaust manifolds for both the small and large series I8. Eedmunds also made dual carb intakes for both. Either option is hard to find and pricey. Other than that, its make your own.
  8. Little Wing
    Little Wing
    from Northeast
    Yep 41/42 we had one,,There was an ad on OSR a while back,,guy had one cheap the whole set up.think it was South Jersey
  9. Lobsterboy X
    Lobsterboy X
    for my 48 roadie, i found a manifold, cracked for 300 bucks. i thought about it and realized that it would cost me more than 300 to get someone to weld cast iron!
  10. gearheadwelder
    gearheadwelder
    from CT.
    $300 sounds like a lot to weld cast. Check with one of your welder buddy's to try a 309 tig wire or some ni-rod from your local weld supplier. Some of the older cast welds easy, but heat cycles on exhaust manifolds can be tougher to get right.
  11. RichFox
    RichFox
    Something I was working on
  12. diego64
    diego64
    from oceanside
    this is the edmunds i just finnished installing. i think it looks better than the stock duals, but is usualy harder to find.
