Progress pics of a customers '63 Chevy truck.
Discussion in 'The Hokey Ass Message Board' started by Ava Mae Hot Rods, Jun 22, 2009.
  1. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Game Plan: Thorbeck Bros k-member, tri link back half, mandrel 2x4 .120 crs step notch and rear section, close to laying out body on 30" over-all diameter tires.
  2. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Yes Sir.
  3. Foppa
    Foppa
    i am yeallous (spelling?) of you bazooka.. looks like a real neat truck build..
  4. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Yea its gonna be pretty cool. I can't wait till its done.
  5. SapienKustom
    SapienKustom
    from Merced, CA
    Looks good. Sounds like you guys have a good plan.
  6. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Thanks
  7. Used Up Junk
    Used Up Junk
    from Merced, CA
    That's gonna be a *****in' little truck and those notches look killer. Did you bend those yourself, have them bent, or are they something you can order prebent? Sorry for all the questions but being able to get mandrel bent tubing like that would be a HUGE timesaver for some of the stuff we are working on. That front crossmember is cool too I'm sure we've all seen these trucks going down the road with the frontend hanging out from under the sheet metal yours is going to look really clean. Great work and keep us all updated 'cus I'm going to steal some of your ideas lol...
  8. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    I got those things pre-bent to my spec. I also have fire wall back rails available .180 crs super strong. Not that .120 crs **** that flexes. However the step notches come .120 crs, because its a small piece not much flex.
  9. DRUGASM
    DRUGASM
    cool. little more high tech than the one we got going. looks like some nice parts and pieces are gonna get 'er low. keep the pics coming.
  10. chaco
    chaco
    from Modesto,CA
    That's gonna be sweet. Keep us posted with pics
  11. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Should hopefully have alot done by Monday night, I'll post some pics this weekend.
  12. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Um, ok along with my phone... My camera is dead to because I forgot the charger. So here are some intermission pics of other stuff I've done.
    Air lines, brake lines, fuel lines, and battery cabels ran through the frame. I know, gay and street rodish.
    Some battery tray holders I made.
    No nuts needed, I have these amazing drill bits that tap at the same time.
  13. DRUGASM
    DRUGASM
    cool. that looks like its gonna be a nice set up. whats the color called? looks kinda like the 99 honda si blue (ah ****, i just said honda on the hamb).
  14. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Its just a candy blue powder coat.
  15. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Ok I will have pics up late Friday night, just been crazy busy with other stuff.
  16. DRUGASM
    DRUGASM
    sweet, i wanna see that thing laid out. those are some good looking welds.
  17. CenValyCali
    CenValyCali
    from Hanford
    Hey that looks great.
  18. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Ok, took forever checking specs for tire diameter. Got a not so sure feeling so went through all my measurements again. However enjoy.
  19. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    FYI for everyone....
    *Air-lift bags are about 1/2" fatter than Slam's. I normally use Slam's (Made here in Fresno). Collapsed height is the sae as the RE7's Slams.
    *Total notch height from ground 16.5" (will lay out body on a total 29" tire diameter, maybe 30", depending on conditions).
    *Rail to Rail inside width is 29"
    *Rails 2x4 .120 CRS.
    *Welding wire used Prostar .035 (nothing fancy), would have like to use Lincoln L56 but welds are getting ground down anyhow.
    *75/25 Gas
    *60 grit flapper disc for weld clean up and then followed up by 120 grit and last super fine 9" grind sanding disc.
    *Tri link will consist of 2" DOM metal .180 CRS
    I think thats all for now.
  20. Wicked50
    Wicked50
    thats coming along real nice
  21. chaco
    chaco
    from Modesto,CA
    WOW, that is bad***.
  22. Ian Berky
    Ian Berky
    great work man!!
    Ian
  23. joebuick
    joebuick
    great build, makes me miss my 63
  24. FRENCHBLUE72
    FRENCHBLUE72
    Im not positive but on my 72 the center crossmember dragged the ground when aired out. I had to cut the bottom off and plate it flat.
  25. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Have not checked that out yet, but when I do I will let you guys know.
  26. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
  27. SapienKustom
    SapienKustom
    from Merced, CA
    Looking good. You'll be on the road in no time.
  28. Ava Mae Hot Rods
    Ava Mae Hot Rods
    from Fresno, CA
    Okay ya'll. Change of plans.... Me and Bazooka came to a agreement to do a more traditional style of back half. A cut& weld. Here are the baby photos, I thought I had taken pics of the rails mounted but I think they were on another camera. I will be hitting this truck heavy this week so stay tuned.
    Super strong. .120crs 2x4". I built them on a laser leveled fab table.
  29. DRUGASM
    DRUGASM
    thats lookin pretty with that round tube cross member. that axle tucks way in there...you lookin at modifying the floorboards?
  30. 51fleetline
    51fleetline
    damn ..wish u guys were closer.
