I have asked before to no avail but I'll give it another shot, maybe someone new can help - does anyone have a set of ansen (clutch and brake) pedals that they would be willing to make me a set of measured drawings of, I want to try and build a set-
Yes , that is what we are using. This set up takes the 60-62 chevy truck master cylinder that has both brake and clutch outlets. If this is what you want, I will draw you up a print and send it to you. it doesnt look very hard to make. Dale
Honest just made a set for his truck. He copied an origonal borrowed from B***. If he doesn't see this send him a PM, I bet he can measure or take some pictures. TZ
very basic three sided box with holes for the master to mount on the flat bolted to the firewall and a bolt going through the sides with two swing pedals hanging off it. bracket bolt two cleavis' two pedals some older car mags, Hot Rod, Car Craft etc, will show them in Moon ads. etc. Paul
If you use the Chevy truck m/cyl, don't forget to swap the cylinders innerds. The brake cylinder has the residual valve and your clutch will be slow to return if you don't swap the insides.
Paul, Thanks for posting that. I'm thinking anyone handy at fabrication could come up with something with that drawing. You could "scale" it to fit your application. Just remember to keep the pedal ratio correct, or you'll end up with a stiff pedal and little braking or lots of pedal travel (or the need to pump the pedal) to get the needed action. BTW, slave cylinders of different configurations can be had at any of the circle track supply houses. Maybe someone here can post a source, or just call Speedway Motors. Frank
Also your local NAPA store has a listing for the master cylinder and slave cyl. that was used in the GMC/chevy truck application. Frank
No pics of the pedals, but here is the underhood view of my old Minor. I used the old Ford cylinders.
cool picture 60's style! that will help, I think all I probably need to do is get the m/c (or gasket if there is one, dont remember now if I saw one in the moon ad) for hole spacing and the rest should be pretty easy. I think I understand pedal ratio pretty well, the pushrods though - dont they need to be any specific length?
can anyone provide these dimensions? back of mount to centerline of pivot bolt hole? (the upper dimension lines on my drawing) center of brake pedal pad to clutch pedal pad (the lower dimension lines in my drawing) how thick of plate should I use? what to use for pushrods? how thick material for the pedal arms? anyone tell me how big and how far apart the big holes for the m/c are? how big and where to locate the bolt holes on the m/c? On 60's drawing there are two holes at location B and location C, why?
cool topic. building your own pedal ***embly from scratch would be nice because then you can get them to fit perfectly. A little bit more work than I can handle right now so I ended up buying a set. You can probably get some good dimensions off of the wilwood website. http://www.wilwood.com/Products/Pedal***emblies/002-FSMP/fsmtmc/index.asp
Anybody know how much one of those rebuilt Chevy master cylinders costs without a core? New Willwood clutch and brake master cylinders cost around fifty bucks each. The new slave cylinder is about fifty-five from www.daymotorsports.com
Wow! I'm more interested now. Somebody get me some dimensions. I could manufacture a few sets of these if there's an interest.
here are the dimentions of our pedals. Sorry, I could not get the dia. of the two large holes. You can use your master cylinder as a guide for these and also the holes that bolt it to the firewall. The master cylinder mounting bolts go through the firewall and the pedal bracket holding it all together.
Just a couple more notes. A "c" clip snaps on each end of the 5/8 shaft to keep it secure in the pedal bracket. Also, I put a grease fitting in the top of the tubing that is welded through the pedal arms. Then you will have no wear or squeaks. I would use 1 inch o.d. tubing at the top of the pedal arms. Mine is smaller and there is barely enough wall thickness for the grease fitting threads. I also added a 1/8 thick plate between the pedal bracket and firewall that is about twice the size of the pedal bracket. this spreads the "load" out when you are mashing the brake or clutch and helps eliminate firewall flex. Good luck, Dale
[ QUOTE ] Honest just made a set for his truck. He copied an origonal borrowed from B***. Sorry, I could not get the dia. of the two large holes. You can use your master cylinder as a guide for these and also the holes that bolt it to the firewall. [/ QUOTE ] The night Honest cut his out I was also starting a set. The large holes are 2 inch dia.
If you are just bolting the system to a flat sheetmetal firewall, add some reinforcing to keep the firewall from flexing especially on a panic stop. a couple of rods from the bracket to the dash board will help a lot.
Im running the same set up in my coupe I also have a 4" recessed firewall. So I had to do a little slicing and splicing for clearance.
The diameter of the "big" hole that the M/C sticks through is 2 inches. Yep, it's a good idea to reinforce the area behind the pedal set-up, it does get a lot of presure when you stomp on it... Note how the center of the piston bore is offset from the center line of the pedal arm. You can't use a regular clevis, you have to use a rod that bolts to the side of the pedal arm as shown in the illustrations. Anyone know a source for these? A note on the M/C: I'm not so sure the Chevy truck will work, I believe there was a post awhile back about the linkage in these trucks crossing over -- and the clutch and brake cylinders are reversed. I'm not familiar with these trucks, so I'm not sure this is correct or not. I used an M/C out of a 61 -66 International: Bendix P/N # 11357.
Detonator, Wasn't it already posted that you should switch the internals on the Chevy master cylinder should be switched to put the residual pressure valve on the brake side? I think this might solve the crossover linkage problem you mention. The only other issue could be that there is a different bore size in the master cylinder. Frank
Hey Frank -- I don't know if the Chevy has the same bore on both sides, but the International does, it's one inch. If there was a post on flipping the Chevy over I missed it. Seems like trying to switch the two sides might open a can of worms, but I don'r have any experience with 'em. Do you know anyone that sells the push rods for this set-up? Dave
Detonator, The switching of the internals was posted on this thread by tommy, maybe check with him to see if the bore sizes are the same. I ***umed they were when he posted about switching the residual valve from one bore to the other. Frank
