Projects been busy in the shop
Discussion in 'The Hokey Ass Message Board' started by Capt. Zorro, Jul 17, 2009.
  1. Capt. Zorro
    Capt. Zorro
    Made a louver press and car rotisserie with the helpful info from here on the H.A.M.B.
  2. Geophyguy
    Geophyguy
    Looks Great. I need to do the same.
  3. 49ratfink
    49ratfink
    those rotissieries are dangerous. if you are not careful you can accidentally do a ****load of work on a car you don't really like.
    did you make the press part of that louver press or was it store bought?
  4. hotrodjeep
    hotrodjeep
    Slick punch.
    Looks like you could change to an air over hyd. setup if your
    armstong power source fails at some point down the road:)
    Nice simple design.
    Jeff
  5. Capt. Zorro
    Capt. Zorro
    It's a Williams LoBuck press, seems to work good. Be careful, you'll punch louvers in every piece of spare sheet metal in the shop practicing...
    The rotisserie sure beats lying on your back s****ing undercoating off in your face and then trying to overhead weld subframe connectors. I ended up with about $500.00 and a couple days labor in it.
