lets see your model a floors
Discussion in 'The Hokey Ass Message Board' started by skottyknukkles, Jul 17, 2009.
  1. skottyknukkles
    skottyknukkles
    fellas looking for some ideas for my sedan i would like to see all your scratch built floors and sub frames. thanks@!
  2. hvychvy
    hvychvy
    Does yours still have the factory sub-rails in it?
  3. Slag Kustom
    Slag Kustom
    30 pickup
  4. skottyknukkles
    skottyknukkles
    i have no floor at all. im planning on getting it in over the week end. seeing the pictures helps get the wheels turning in my head. heres some pics of what i m working with. 1 st pic is the drivers side. second is the p***engers i started to make some tubs for the slicks.
    im going to use 16 gauge for all the sheet metal. i dont want the floor to have 5 million bars all over the place. the center panels are going to be removable for acess purposes. i searched alot of posts but came up with only a few inspiring pics.
    the truck with the suicide doors is similar to how i would like to do the side panels in mine. thanks!
  5. skottyknukkles
    skottyknukkles
  6. Ghost28
    Ghost28
    28 chev sedan delivery
  7. PoPo
    PoPo
    bringing it to the top because I will be building a complete floor such as yourself coming up this fall.
  8. poofus1929
    poofus1929
    from So Cal
    Me too man. I still have a lot of builing in front of me.
  9. skottyknukkles
    skottyknukkles
  10. 29paul
    29paul
  11. AstroZombie
    AstroZombie
    from Marina, CA
    33 Plymouth coupe. Still needs finish welding
  12. Tin Can
    Tin Can
    I went a little overboard on my subframe tubing
  13. 35mastr
    35mastr
    from Norcal
    I have not even started.
  14. mopar210
    mopar210
    Heres mine "1929 hemi a hot rod. .059 thick and hard as hell to form .
  15. Chaoticcustoms
    Chaoticcustoms
    Ha and i was guna PM you the link to this thread too just incase you missed it
  16. Deuce Roadster
    Deuce Roadster
    DEUCE sedan ... not a Model A :)
    This one belongs to a good friend of mine. Has bead rolls in it to prevent " oil canning " :D
  17. skottyknukkles
    skottyknukkles
    this is great stuff guys keep em coming!
  18. A-Wall
    A-Wall
    heres mine, running wood for the rest
  19. PoPo
    PoPo
    I'm interested in how to PROPERLY connect the subrails to the sides of the body. If I keep it stock I have an idea but if I channel it an inch or two then what?? Any advice
  20. Ghost28
    Ghost28
    do a kick up in the door area like the late 50s or early 60 trucks had if you have the room.
  21. skottyknukkles
    skottyknukkles
    bump for some more pics
  22. mosimpson
    mosimpson
  23. Oldkrow
    Oldkrow
    Are you guys using the exhisting subrails to build the channel off of?
  24. bab59
    bab59
    BTTT Need some inspiration. Thinking of going with 1x3 behind cowl to rear of car since I have nothing and repop rails will need to be cut up alot.
      219.8 KB
