Coupe decklid install
Discussion in 'The Hokey Ass Message Board' started by WhiteDevil, Jul 21, 2009.
  1. WhiteDevil
    WhiteDevil
    Hey guys time for some more hamb help....Im looking to install my steel decklid on my 31 coupe. Its just got two bolts holding it on "to swivel" it open at the top. It fits well just wanted to see what guys are running for mounts at the top and what latch is the best way to go...(besides the bungy chord) Heres a pic of one that I saw and I was also wondering what latches those are from in the pic... any help is greatly appreciated as always!
  2. WhiteDevil
    WhiteDevil
  3. 35PontiacCoupe
    35PontiacCoupe
    from COS
    I'm having a hard time trying to get help on a decklid too! My problem is different from yours tho... Apparently the hinge people are taking the night off!
    It looks like the hinges in that pic are some sort of sedan setup. I'd say mid to late 30's chevys, probably fords too.
    These are from a 38 chevy. $76 bucks from Chevs of the 40's.[​IMG]
  4. Ratty55
    Ratty55
    from Frohna,MO
    I got these at a swap meet. The guy said they were off a morris minor.
  5. Lazy White Boy
    Lazy White Boy
    The origional set up works very well, why mess with it? I understand if you are trying to do something trick or custom, but if not why use ladder parts?
  6. SATANSSHO4
    SATANSSHO4
    they are 49 ford hinges in that pic
  7. WhiteDevil
    WhiteDevil
    I dont have anything yet....two rusty bolts holding the lid on at th top and nothing in the bottom....whats the best way to get all of this done???
  8. chopper99
    chopper99
    Not 49 Ford hinges.
  9. WhiteDevil
    WhiteDevil
    I kind of like how those external hinges look....any ideas?
  10. NortonG
    NortonG
  11. Lazy White Boy
    Lazy White Boy
    Go to any of the model a parts suppliers and order the correct parts. My decklid was pretty rusty so I had to remake the plates for the pins to slide into but the rest was really easy, if you want to go stock. As for the bottom, just get the right parts. I used a stock handle and made the catch for it, it was really simple.
  12. SATANSSHO4
    SATANSSHO4
    they look like these that i bought for my coupe [​IMG] 49 ford hinges iam i wrong?
  13. WhiteDevil
    WhiteDevil
    lazywhite boy can you take a pic of the latch you made....just for reference..and who do you buy your A parts from there is a bunch but I have heard bad things about some
    Satansshoe4 do you have pics of them installed on your coupe?
  14. SATANSSHO4
    SATANSSHO4
    didnt install them yet running the original setup but feel the back of the car needs some chrome it very plan looking
  15. Mudslinger
    Mudslinger
    These are 49 ford hinges but not the ones posted at the top.
    I should also add theres a left and a right 49 ford hinge.
  16. dans30
    dans30
    Hey WhiteDevil,
    On my 1930 Model A, I just used 3/8" bolts with the threads ground down. and washers for hinges and they work fine. As far as a latch goes, I used a VW trunk latch hidden in a recessed license plate in the panel below the trunk lid. I can provide pics upon request.
  17. Greaser Bob
    Greaser Bob
    Hey SATANSSHO4 got any recent pics of that *****en hot rod of yours!?
  18. WhiteDevil
    WhiteDevil
    dans30 lets see those pics.....sounds great
  19. coupeHEAD
    coupeHEAD
    www.brattons.com www.snydersantiqueauto.com
    www.macsautoparts.com All 3 of these are good and reputable
  20. WhiteDevil
    WhiteDevil
    Does anyone have any tech on the rear decklid latch install or any pictures of their setup? Also anyone have pics of the older style hatches installed? The 39 or whatever chevy or ford latches....
  21. WhiteDevil
    WhiteDevil
  22. pasadenahotrod
    pasadenahotrod
    from Texas
    1. Get a Model A parts catalog from Snyder's or Mac's or Battlefield.
    2. Read it.
    3. Stop when you get to deck lid/rumble lid hardware.
    4. Look for hinge ***emblies, latches, hold-ups, handles and striker plates for a deck lid equipped car.
    5. Order what you need.
    6. Open the box when it arrives and install the parts.
    How much easier can this be? Model As have more parts available than any other car ever built including most brand new ones.
  23. WhiteDevil
    WhiteDevil
    Thank you that really helped alot.......I was talking about the 39 style latches not stock model a latches
  24. Dan1955
    Dan1955
    I used Triumph Spitfire hinges on my 30 coupe trunk. Still looking for a latch.
  25. Dirty Dug
    Dirty Dug
    Why reinvent the wheel? Order a Macs catalog.
  26. Ratty55
    Ratty55
    from Frohna,MO
    Are we building 1000 point factory restorations here? If he wants externals, that's his choice.
    There's not much to installing external hinges. Just make sure you get them square with each other so they don't bind up. Space them evenly from the edges of the lid. You may have to make spacers as most hinges were originally designed to be bolted to thicker deck lids.
  27. WhiteDevil
    WhiteDevil
    Thanks guys for all the help....and it will be nothing of a factory restoration
  28. Roothawg
    Roothawg
    I am doing the exact same thing today. All of my parts are jacked and by the time I buy all of the missing pieces I'll have almost as much or more in it, than a set of external hinges.
    Has anyone physically installed a set of 49 Ford hinges on a model A coupe?
  29. WhiteDevil
    WhiteDevil
    I was trying to find someone that had installed them as well...I didnt know if since where they mount to the body has a small downslope if there was any problems or shims needed etc....
  30. el Scotto
    el Scotto
    from Tracy, CA
    I have a pair of those late 30's Chevy hinges, and they are definately "sided".
    On a car like an A, I'm pretty sure you'd start by sanding the bases to fit the shape of the A sheetmetal. They have a slight curve to 'em depending on the which side you're looking at.
    Next, I think you'd have to remove the pins, slide a piece of straight rod through the holes on both of them when you mount them so they would work together and not bind.
    Kind of like door hinges on a Model A.
    That's at least what I'd figure, but mine are still sitting in a box and I drive my A-bone around hoping gravity will keep my trunklid on.
