Projects 1930 sedan project pics
Discussion in 'The Hokey Ass Message Board' started by jtille, Feb 21, 2009.
  1. litemupok
    litemupok
    very nice. i like the work. keep up the progress buddy
  2. boones27t
    boones27t
    from redding ca
    love it. Looks killer
  3. WILTBILT
    WILTBILT
    from VIRGINIA
    Looking good.... Keep the pics coming
  4. Lucky77
    Lucky77
    I dig it, but then again I'm partial to these sedans;)
  5. I SMELL SMOKE
    I SMELL SMOKE
    very cool build!!!! i love your car!!!! wow!!!!!
  6. WILTBILT
    WILTBILT
    from VIRGINIA
    Looking good!!
  7. Looks good. How are you attaching the front end? Will it really be above the frame like that?
  8. jtille
    jtille
    Catcus1 the front will set up something like this
  9. 29Jay
    29Jay
    from Ft Worth
    I'm digg'in it!
  10. rc.grimes
    rc.grimes
    from Edmond, OK
    Like the look of it with the stock axle and wide fives. Not totally sold on the underslung set-up but it does look like it goes well with the car.
    Did you faux patina it?
  11. Bad Luck Engineering
    Looks pretty sweet! Definitely creative. How are you planning on attaching the shackles to the arms?
  12. jtille
    jtille
    Thanks for the nice words people. Trying to get it going by 10-18-09 that will be the 1 year mark
  13. Big Tony
    Big Tony
    Dang, I dig the color....congrats on the progress and good luck on having it smoking the tires by mid-october
  14. jtille
    jtille
  15. Just Gary
    Just Gary
    How'd I miss this thread? And only 10 miles from my house??
    Very nice buildup, BTW. Can you tell us more about the engine?
  16. jtille
    jtille
    The engine is a 276 desoto .30 over Racer Brown cam Lake style headers 6x2 intake
  17. jtille
    jtille
    A couple pics of the Baby hemi
  18. landseaandair
    landseaandair
    from phoenix
    First off, I want to say you do nice quality work, but I have some concerns about the front suspension. One is that there might be too much stress on the radius rods with the spring being so far back. Second, you may want to at least bob the frame horns past the crossmember to lessen the risk of bottoming out or worse. Especially with the weight of the Hemi and lack of ride height. I also don't see any provisions for limiting travel. Shocks could do this, but the placement could exacerbate the the first issue I mentioned. One option for this would be to make legs or nerf bars out of heavy round stock that Z's between the axle and centerlink, then over the axle. They wouldn't look to bad if you chromed them. Sorry, sometimes I can't help myself.
  19. OoltewahSpeedShop
    OoltewahSpeedShop
    The spring is fine that far back. Don't worry about that. No need to bob the rails either. If it rebounds up that far, you need to work on the shocks, not the frame rails.
    Nice build, keep it up.
    Kevin
    Ooltewah Speed Shop
  20. landseaandair
    landseaandair
    from phoenix
    I was referring to the frame getting friendly with the pavement as it seems to be pretty close to begin with, especially in case of component failure. It didn't have anything to do with rebound. I'm also not a real big fan of underslungs to begin with, but at lest most of them have parallel leaf springs with the frame horns turned upwards and are a lot less likely to get hung up on something. I just thought his configuration could do with a little fine tuning.
  21. pan-dragger
    pan-dragger
    coming along nice.
  22. 34Chrysler
    34Chrysler
    I love it, I would leave the caps off the wheels though
  23. jtille
    jtille
    I would leave the caps off but with the ford 9 had to run adapters looks like **** with rear caps off
  24. jtille
    jtille
    Not a update pic but had a question about the firewall looking not stock.It is cut down and pushed back 2 inches
  25. 29Jay
    29Jay
    from Ft Worth
    looking good! Good luck on the 1 year goal! I just p***ed the 2 year mark and I'm still in 2 pieces...
    Jay
  26. jtille
    jtille
    Thanks man... Not going to make the 1 year mark no more OT at work
  27. doctorZ
    doctorZ
    great progress. the front suspension looks like it might hit when the frame bounces upwards, though ... i think the body color with the white firewall and wide-5 wheels looks terrific!
  28. All these posts and nobody has mentioned the spring pack is backwards for the type of front suspension he has setup? Think about it, all the weight is on the main leaf. The other springs are just fillers in that application. Do not p*** go, do not collect $20.
  29. Midwest Rodder
    Midwest Rodder
    Man, its looking real good, The front suspension is killer!
  30. Doh! :eek:
