Is your car ready for cow oil?
Discussion in 'The Hokey Ass Message Board' started by TooMany2count, Jul 21, 2009.
  1. Ole don
    Ole don
    Yup, the old Ford no longer backfires, now it says MOOOOOOOO!!
  2. snt there enough orcabettys at shows already?
  3. plymouth1952
    plymouth1952
    Hell I still do that ! great for killing blackberrys. I am not sure I am up to cow dung in my 5000 $ motor.
  4. Plowboy
    Plowboy
    I will only run 100% pure Angus beef oil in my car.
  5. kwoodyh
    kwoodyh
    It's USA designed and made, has the SAE and API SM rating so it has to meet some tough standards. I wonder if it is cracked with heat like a conventional or processed (chemically cracked) like a synthetic? Might be a hot new product to try? It's kind of a back to the future deal it's only been about 150 years ago (maybe more?) that the world was powered and lubed with animal fat, so save the whales and now the cows my ***! Too bad we are using cow feed (grain) to make ethanol for E85! It's kinda mis-leading saying it can be dumped on the ground with no worries, that is only true if it hasn't been used in an engine, once it's used it too becomes a waste that has to be disposed of correctly.
  6. Shifty Shifterton
    Shifty Shifterton
    Powered by bovines and constructed of natural fibers, that's the car of the future. Wonder how long til honda releases a hybrid called the Conestoga. They'll probably call it an SUV, but we'll all know it's really a wagon. The road apples they leave behind will actually be cleaner than the streets in LA.:D
  7. DrJ
    DrJ
    Just a lubricant from a different animal this time.
    This lifted from: http://www.shadetreemechanic.com/lubegard.htm
    "...Years ago, sperm whale oil and its derivatives were used as additives in virtually all automotive lubricants. The products were so effective that a car's transmission fluids were generally never changed, and the transmission lasted the life of the car. Some 30 million pounds of sperm whale oil were used every year; to supply the demand, hundreds of thousands of whales were slaughtered until the species was faced with extinction.
    In 1972 the Endangered Species Act outlawed the killing of whales and the use of materials derived from whales. For years the automotive industry relied on other animal based products such as tallow or lard oil. These proved to be an inadequate subs***ute, leading to poor overall drive train performance, premature drive train failure and transmission failure due to heat. A dedicated and highly skilled research team, in conjunction with the Department of Agriculture, developed a revolutionary new technology derived from vegetable oils. Liquid Wax Esters®, with a chemical configuration similar to sperm whale oil, have been shown to outperform sperm whale oil. ..."
  8. Yeah, I dispose of my oil each time I burn my slash pile. Great firestarter.
  9. traffic61
    traffic61
    from Owasso, OK
    Will we have to check our engine's cholesterol count every so often? Throw a couple of tabs of Lipitor every other oil change?
  10. Maybach's use only Kobe oil... available only at Moobil stations, which would be bull.
  11. stealthcruiser
    stealthcruiser
    That's not sick....................What about,"Put me in your douche bag, and run me through one more time!":eek::eek::D
  12. tjm73
    tjm73
    Non-fossil based oil in 2 strokes could be a good thing. Bring back 2 cycle street motorcycles. hmmmmm.......
  13. G V Gordon
    G V Gordon
    from Enid OK
    Yea, it's just a small block but I'm "beefing" it up.
  14. vertible59
    vertible59
    Speaking of streets and totally O/T...isn't asphalt a petroleum by product? What's the difference between dumping waste oil on the ground and covering millions of acres with asphalt? Wonder how the Greenies would like it if the streets in front of their houses were dug up and turned back to dirt roads. Just asking if there's not some hypocrisy being championed in all this save the environment stuff.:confused:
  15. tdoty
    tdoty
    Is that why really old gear and trans oil has that funny smell to it?
    Tim D.
  16. It is a petrochemical byproduct but it is contained and can not 'rum off' oil pored out is not contained and continues to spread contaminating everything it touches and eventually makes its way into water courses.
    I'm not a greenie by any means but I drank enough oil and fuel tasting water in the service. Why is it that water on EVERY Navy ship tastes like that?
    Or is that what they save for us Army 'P***engers'?
    Doc.
  17. TooMany2count
    TooMany2count
    from Cahokia,IL
    Why :rolleyes: ??????????????????
    She'll tell me the same thing she's been saying for years.....
    NO ! ! ! ! ! ! ! ! ! ! ! ! ! :eek:
  18. InPrimer
    InPrimer
    Had a segment on Dirty Jobs, some guy would collect all the naturally deceased cows and eventually run them thru a grinder, one of the by product was a base to produce synthetic oil sorry can't remember more than that, but it piqued my curiosity, exactly where does "synthetic" oil come from??
  19. 29nash
    29nash
    from colorado
    Some of us haven't fallen for the myth that we are DEPENDENT on Oil from other sources. Actually we purchase what's available at the best price.
  20. pool
    pool
    I have used lard in my cutting oil in my home machine shop for years works great.
  21. dudley32
    dudley32
    can you put it on a biscuit ?
  22. vertible59
    vertible59
    Was not suggesting that dumping motor oil on the ground was ok. The deal about asphalt just came to mind and made me wonder. There again, I have seen oil sprayed on dirt roads to keep dust down, and to make the surface less susceptible to erosion. Also, how many thousand gallons of oil, leaked from cars and trucks, seep through the asphalt, and contaminate the environment?
  23. Yep, Soylent oil, made from human by-products. How's it perform compared to other oils? Depends on the person.
  24. David Chandler
    David Chandler
    Maybe a s****ful of the cleaner, will eliminate your high cholesterol?
  25. I used to raise pigs while in Future Famers Of America and alot of the literature out there for swine raising is very old but still applies to today. I remember reading about how some breeds of swine were raised purely for production of their lard/fat. It was a common item for many home uses, at the moment they escape me. I just remembered lard when this topic came up and how every part of swine are used upon slaughter for many things. Gasoline/fuel may be a future use lol. I would think that lard would smell better for cutting things then some of the petroleum lubricants out there smell. When I worked in a machine shop a year ago some of the oils used for cutting were very toxic and smelled it also.-Weeks
  26. Insane 1
    Insane 1
    from Ennis TX
    What do you mean???... What else are you suppossed to do w/old oil?????
  27. TooMany2count
    TooMany2count
    from Cahokia,IL
    Let's all remember when oil production first started there was a by-product of the oil that was just dumped on the ground because at the time there was no real use for it..
    Got any idea what it was?????????
    Gasoline..................
  28. Chaoticcustoms
    Chaoticcustoms
    haha, reminds me of a southpark episode where cartman gets pissed off at this kid and turns his parents into chili and makes him eat it BAHAHAHA...wow im a sick ****er too huh..
  29. torchmann
    torchmann
    from Omaha, Ne
    I'd eat a dead animal but boiling down it's fat to put in my car is just creepy
  30. rixrex
    rixrex
    How about gr***oline?..they're making it...
