History Name That Engine Trivia Thread
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Jul 19, 2009.
  1. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    Looks like a Pontiac Straight 8!
    (couldn't be because your picture's name Pontiac flathead?)
  2. RichFox
    RichFox
    I'm going to guess Northstar on the blown hemi looking engine above.
  3. kelgar50
    kelgar50
    from socal
    Hers another one
  4. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    It might be...I think I'm wrong on the 5.7 or 6.1L Hemi, the oil filter isn't right, and some other stuff isn't either...
    And it doesn't look like a modular ford...
    Cadillac was really thinkin' when they put the starter under the intake on those Northstars..
  5. Negative on the Suburu, Goggo was closer.
  6. the-rodster
    the-rodster
    Think - world's largest car manufacturer....
  7. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    Shit, I didn't even think about that....Toyota Crown Hemi?
  8. RichFox
    RichFox
    Well then I'm back to the Lloyd. I'm doing the same thing just spread out. Why are there rules on this anyway?
  9. Revhead
    Revhead
    from Dallas, TX
    try this one
  10. Harry Bergeron
    Harry Bergeron
    from SoCal
    Tatra air-cooled V8
  11. Harry Bergeron
    Harry Bergeron
    from SoCal
    Bugatti aircraft engine, but not the one from the Bugatti aircraft itself, which used two mounted end-to-end.
    This one has two side-by-side on one crankcase, sort of an H-16, concocted by some American fellow whose name escapes me.
  12. kelgar50
    kelgar50
    from socal
    You got it
  13. Rich. Is the first inline 6 a Studabaker? Page 1
  14. RichFox
    RichFox
    Yes. That's pretty much it for my wierd engine stash. I will throw in one more but it's pretty famous. Been pictured by others here before which is where I copped the picture. Well since I'm here I'll throw in some easy ones. The yellow one in the background is my Plymouth 4 cylinder flathead. We are not guessing on that.
  15. Harry Bergeron
    Harry Bergeron
    from SoCal
    Yes, it really is an automobile engine.
      46.6 KB
  16. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  17. Gahhh, Lloyd is good enough....
  18. RichFox
    RichFox
    How about a name that engine with that head? We already did the block I think
  19. Truckedup
    Truckedup
    This is a piston engine devoloped by the USA at the end of WW2.At full power it used over 500 gallons of gas per hour, What is it?
  20. shake
    shake
    from central az
    Guffey, I'm really interested in your Offy-like four banger. It appears to be water cooled with the cylinder fins as an extra, 4-valve and with dual ignition. Are those Winfield carbs? I've no idea what it is. Can you tell us something about it?
    Shake
  21. shake
    shake
    from central az
    Truckedup, I believe that monster motor is a Lycoming XR-7755.
  22. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Close, but no.
    Its a rare 41 Ambassador "600" series 177 cid flathead 6
  23. Truckedup
    Truckedup
    Yup,the largest displacement piston aircraft engine,probably the largest gas engine used in anything that moves.
  24. RichFox
    RichFox
    What did it go on?
  25. Truckedup
    Truckedup
    It was devoloped late in WW2,but no aircraft at that time needed such a large engine.Running examples made 5000 hp with 7000 hp possible .Just after the war the Lycoming 7745(cubic inches) was scheduled for use in the B-36 6 engine bomber.But politics prevailed and the B-36 was powered by 6 P&W 4360 air cooled radials of about 3500 hp each.Not enough power for such a giant plane.It was water cooled,36 cylinders arranged in 9 banks of 4 cylinders each.
    Studabaker supposedly had even a larger engine,nearly 9000 cubic inches,but none ever were actually ran.
  26. GearHeadSoul
    GearHeadSoul
    Ford X8... experimental precurser to the flathead.
  27. murfman
    murfman
    Here is another.
  28. RichFox
    RichFox
    The above looks like a Willys F head. Here is an earlyer picture of the Banger I posted couple months ago
