Uhh,What causes automotive glass to white-fog at the weatherstrip line?
Discussion in 'The Hokey Ass Message Board' started by Ranunculous, Jul 26, 2009.
  1. Ranunculous
    Ranunculous
    I bought my weatherstrip a bunch-of-years back from Packard Farm.
    The gl*** was cut locally by a firm that seems to have an idea what they're doing.CUt and belt-sanded while I waited to fit.All good.
    Today,while washing my truck I notice the drivers side is white-fogging at the bottom edge of the windshield.
    Not what I expected ...
    What causes this?
  2. Separation of laminated gl***....
  3. rgdedge
    rgdedge
    from East Tn
    Yep, its separating and the plastic between the gl*** turns white or it will bubble. If you had it recently, see if they will stand behind their work and replace. Worth a try.
    Tim
  4. hotrod40coupe
    hotrod40coupe
    Quit parking in the direct sunlight.
  5. Ranunculous
    Ranunculous
    Uhh,it's in the garage most of the time?
    It's not bubbling,but the white,milky line bugs the hell outta me.
  6. jamesgs4
    jamesgs4
    from denver
    :rolleyes:
  7. squirrel
    Get new gl***, or learn to live with it.
  8. Ranunculous
    Ranunculous
    Ouch! Those are harsh words...
    I smeared some clear polyurethane on the edges when we installed the gl*** a while back.
    This is the first time this has happened.
    Where you been Squirrel? Haven't heard you post on here in a while?
  9. squirrel
    Oh, I've been playing with robots...
    Sorry didn't meant to be harsh. Gl*** goes bad, some lasts longer than others. I wonder if the urethane affected it?
  10. Ranunculous
    Ranunculous
    Robots? I read where you had an underwater mechanical? Is that true?
    You da man,Squirrel!
    As per the gl***,I've had other laminated adventures(etching and sandblasting display pieces that hung in direct indoor sunlight that have not frosted up.)This is the first that's gotten milky on me?I don't know if washing the truck and allowing water to lay on the weatherstrip milked it up or ? It's garaged and not in long-term UV rays.
  11. I think you just answered your own question.Sounds like the polyurethane is outg***ing between the laminations and reacting with the plastic sandwich material.
  12. mj40's
    mj40's
    I had the same problem in my Chevy with a V-****ed gl***. The Installer used silicone to seal the center. It took about 5 years before I noticed it and you guess it, the gl*** company had gone out of business after 30 years in the area.
  13. Ranunculous
    Ranunculous
    When the fellas belt-sanded the window/windshiled pieces smooth,the one guy told me the heat from the process would melt the the "plastic" and fuse the two panes together-like a really hot cheese sandwich?
    I've used pieces of their same gl*** and etched(gl***beaded) designs into it which have hung inside display areas for years.Weather,moisture and abuse haven't fogged them?
    Must've been the poly treatment? In trying to make things better I've made them worse? It's only the windshield,not the side gl*** too.
  14. rc.grimes
    rc.grimes
    from Edmond, OK
    I have a piece of gl*** thats less than a year old that has already started to fog and it isn't even installed yet. I can understand it on a 30 or more year old windshield but there has to be a common denominator on new gl*** doing this and some way to prevent it.
  15. motoandy
    motoandy
    from MB, SC
    That might be a part of the problem and the solution. Drive it more! Just kidding.
  16. gas pumper
    gas pumper
    I can't explain the new never installed gl*** doing this, but my experiance with gasket installed gl*** has always been if you had to fight the gl*** into the channel, it will eventually turn the plastic white. I figured that stressing it installing it started the separation and time does it's thing. I've put in hundreds of gasketed windows over the years and the problem ones were the ones that went bad.
    Frank
