Toilet Paper Oil Filters... Literally
Discussion in 'The Hokey Ass Message Board' started by 65Luck, May 6, 2004.
  1. KreaturesCCaustin
    KreaturesCCaustin
    from Austin, TX
    I had one in my '59 GMC when I bought it. It made it to over 417K on the clock before the odometer finally gave out. I drove the thing around for a year before I finally replaced that with a remote that took a spin on filter. I bet that old six had about a half a million miles on it before getting T-boned by a Camaro and totaled.
  2. 51chevcoupe
    51chevcoupe
    Personally I think it is a '****ty' idea. hahahahahaha....... damn I'm funny!
  3. Road Runner
    Road Runner
    I added a Frantz filter to the fullflow Wix about a year ago and the oil stays clean on the dip stick now between oil changes.
    The TP also removes water during the colder humid months.
    Big rigs and fleet and commercial vehicles use it to extend oil change intervals.
  4. kwoodyh
    kwoodyh
    WTF? :eek: Corvair powered Motorhome? Who would of thunk?
  5. ramzoom
    ramzoom
    Had a 57 Country Squire which was all original and ran great with a Fratnz..I lived in an apartment so couldnt do oil changes at home so took it to a jiffy place.. seeing all the young guys come over and freak out when I took out a roll of Scott toilet paper and proceeded to unroll enough paper to fit the roll into the frantz filter..They thought I was nuts..The original owner ran them in all his cars and used Scott tissue so I wasnt about to break tradition..
  6. Steelsmith
    Steelsmith
    I first encountered the Frantz filter in the mid '70's. Still have an original sales brochure somewhere ...
    There was a drawback to the TP idea though. During the making of paper products from wood pulp, certain acids are present either naturally or added to the paper during processing. There are remnants of those chemicals in paper products. They can be 'cooked out' during prolonged exposure to heated petroleum, (oil). Those acids are then circulating through your engine. They are a minor concideration, but there non-the less. An upgrade to the original Frantz filter system was adding a mesh screen plate to the interior bottom of the filter canister The toilet paper was then replaced with cotton-waste. The 'cotton-waste' was in the form of mill-ends of cotton fabric or clean rags. These worked fine as a filter, but it became a messy business when changing filter medium.
    Eventually the company discontinued this 'upgrade' and went back to the original toilet paper filter, as the effects of the acids in the TP were judged to be inconsequential to the life of the engine as long as you changed the TP every 1500 miles.
    This information was p***ed on to me from an old boss of mine who was a vender for Frantz filters.
    Dunno how accurate this info is, but I do know there is acid in paper processing.
    Just a thought,
    Dan Stevens
    dba, Steelsmith
  7. stlouisgasser
    stlouisgasser
    I've heard this story for years and have NEVER like the idea. At this point in my life, I now have 40 years of professional experience of using toilet paper for it's intended purpose.....ONLY. I don't like the idea of having something in my oil pan, pump, and gallerys that can can flake/tear off and clog oil p***ages. Toilet paper just seems to me to be to fragile as a filter media.
  8. panic
    panic
    What is always present in your oil after a few miles of normal service (besides some normal combustion byproducts), especially after short trips and cold weather?
    Water.
    What do all brands and type of toilet paper have in common (and different from any other paper product: stationary, paper towel, xerox, grocery bag)?
    They disintegrate in water. They're made to dissolve in water.
    That's why they have those big signs ("don't throw paper towels in the toilet!")
    Not sure? Ask your local DWSGE Engineer how long toilet paper lasts in a septic tank.
  9. corsair
    corsair
    I believe Franz offers paper rolls specifically intended for their filters because of all the above stated reasons. No worries about dissolving in water, or acids, or anything else.
  10. I don't recommend them. We had one on a parts chaser pickup in the early 60s. The condensation in the oil created by short trips caused the TP to break down and pluged every oil gallary in the engine. Thats how TP is designed. To break down when exposed to moisture.
  11. Well im gonna find out first hand. I installed the one i bought yesterday. This afternoon i put it on my 64 chev 3/4 with a intergrated head 1981 250 six. Now i have to get some John Wayne toilet paper. Ever take apart a standard oil filter they have paper elements. The old chev gets worked very hard we use it for a wrecker and pull trailers with it. Every time it is driven it is to do some hard job.:) OldWolf
  12. LowKat
    LowKat
    I used one as an oil puke can of sorts. My engine is too new to have a PCV outlet in the back of the block and I wanted to run unvented old 283 valve covers.
    I used an aluminum intake that had an oil filler tube. Then drilled through one of the coil mounting bosses into the lifter galley. On the underside of the intake I made a sheet metal baffle to keep oil out. Then, I tapped the hole for 1/4" NPT and threaded in a 90* fitting. From this fitting, ran copper tubing to the oil filter canister, then back up to a PCV screwed into the base of the carb.
    I figured if any oil did get ****ed up, it'd collect in the canister.
  13. 52style
    52style
    bought a chinook motorhome years ago had a franz filter on it and a grenaded engine
    looked like jiffy lube diddnt change the paper had the mileage sticker on the window still had a few thousand left till the next oil change the toilet paper still had the old oil in it from before the oil change
    i imagine there good as long as you remeber to change the paPER EITHER WAY I TOOK IT OUT WHEN I REBUILT THE ENGINE
  14. DaxxRuckus
    DaxxRuckus
    Yep, pulled a roll of TP out of the filter housing in my 1959 Fairlane. I've heard of people doing this for years.
  15. 49ratfink
    49ratfink
    here's another old post to go with this old post. http://www.jalopyjournal.com/forum/showthread.php?t=151919
    I've never used one, but people seem to like them. you can get new ones on ebay, or parts to fix the older ones like O rings and such.
    they are an auxillary oil cleaner, they pick up big stuff the filter misses.
    the oil still breaks down, it just now breaks down cleaner with less particles in it.
    oil and filter and TP still need to be changed.
  16. evldoer
    evldoer
    from leroy wi
    I run one in my diesel pickup(duramax), change the tp about every 1000-1500 miles and add a qt of oil it is fine- no break down of the paper at all. If you ran it longer between changes, I can see a problem with it breaking down though. It is a secondary filtering unit, still have the regular filter on engine, but I rarely change it-actually I cant remember when I changed it!
  17. Well it has been a month and the toilet paper filter has not caused any problems also the oil is looking cleaner. i think that it does do what the maker claims. I didnt change the oil when i installed the frantz oil cleaner. I will give the wrecker its yearly oil and filter change soon. i also drain a gallon of coolant from the engine and add a new gallon of anti freeze once a year.:eek: OldWolf
  18. Ed ke6bnl
    Ed ke6bnl
    keeps my oil cleaner and I believe the engine cleaner on my dodge diesel 98.5. I am sold on it. change it about every 2000 miles add a quart the add some fresh additive. ED
  19. Road Runner
    Road Runner
    Funny this post came back.
    I just changed my first TP roll after 2500 miles this morning. - See picture.
    I plumbed mine in parallel with my Wix full flow filter, instead of draining it into the crankcase.
    The flow is slower, as it depends on the pressure difference of the inlet and outlet of the full flow filter, but it still works perfectly. I just don't have to change the TP roll as often.
    Changing it is easier than the full flow filter. A couple of minutes and no mess without one drip of oil.
    The only time you hear someone poo-poo this filter is when they use it as intended and without having any personal experience with it in oil filtering.
    The engine's oil system is no septic tank with enzymes and as you can see, no paper fiber has been dissolved.
    This is with Rotella Diesel oil, which has 50% more detergents and 100% more dispersants than regular motor oil, so the oil should be darker on the dipstick, even with my new engine.
    Before I used the Frantz, the oil was almost black running the same distance.
    I get the TP directly from Frantz and the couple of dollars per year are like a minor donation for their efforts over the last several decades.
    This is not intended as adverti*****t - I am just reporting my personal experience and of course I am happy with the results.
    I like simple things that make sense and work well.
  20. Ed ke6bnl
    Ed ke6bnl
    here is my set up been working great.
    I did pu a newer housing for this one on ebay and we will have my boy have them both powder coated when he does his install on his dodge diesel. ED
  21. Florian
    Florian
    I´ve got a 1955 Chevrolet 265cui engine, without oil filter.
    Now my question is, do I have to stick to the stock byp*** oil filter or would a single Frantz toilet paper filter do the trick?
  22. If you were seriously convinced that this works, you could put the same thing together for about 10 bucks at the hardware store.
    But to believe this thing actually works, you also need to believe that the entire world has been brainwashed by the evil oil companies into regular oil changes and that toilet paper is the best filtration medium, in spite of the millions of dollars spent annually on filtration research. Wouldn't this be original equipment on all new cars? Think of the sales tactics: this car never requires an oil change!
    They provide no independent testing, only testimonials. They offer ambiguous claims like "[FONT=arial, helvetica][SIZE=-1]we guarantee the Frantz Oil Filter/Cleaner will keep your oil ****ytically clean 100% of the time." [/SIZE][/FONT]The website has no definition of what "****ytically clean" means, no engineering do***entation, and contains several outright lies[FONT=arial, helvetica][SIZE=-1].
    [/SIZE][/FONT]This has all the signs of being a scam, and given how long it has been around, I am sure it has been very profitable.
  23. 296ardun
    296ardun
    I put one on my 30 Ford roadster with a 324 Olds...didn't have room for the stock filter so mounted it on the firewall, chrome cannister and all. This was back in '61 so the company has been around for a while. I suspect that toilet paper was different back then, none of this super soft stuff....maybe the super soft stuff was never meant to be in a Frantz Miracle Oil Filter?? I do know that the filter worked for me.
  24. LowKat
    LowKat
    Probably need the individually wrapped "commercial" stuff.
    Another canister idea if you use it for "period correctness" and don't like toilet paper, would be hiding an Oberg style filter inside.
  25. arkiehotrods
    arkiehotrods
    My '47 Ford coupe doesn't have an oil filter. I think its lack of a filter works every bit as well as a toilet paper filter.
  26. lostforawhile
    lostforawhile
    wouldn't this work even better today since most oils have gone to ****? :D
  27. Road Runner
    Road Runner
    Here is some data the owner of Frantz emailed me when I send them a link to this post a while back.
  28. I first dismissed the frantz filter as just plain stupid. Bought one at a auction with some other stuff for $1. Them i googled it and found it does the same thing as the luberfinder filter,s that are used in semi trucks. The peterbuilt i drive has a luberfinder also over a million and a half miles no engine work ever.So i installed one on our 64 chewv 3/4 wrecker. And i am convinced it does what the maker claims:cool:. You still have to change oil and filter regularly. And use John Wayne toilet paper. But folks can think what they want. OldWolf
  29. Greasy64
    Greasy64
    I'm surprised the "Banger" guys haven't posted about this. I'm sure they have elsewhere. Seems to me like an engine with non-detergent oil and no filter at all would do better with one of these. With regular oil and TP changes (John Wayne Brand or whatever) seems to me that they could be a good thing.
  30. 28 jalopy
    28 jalopy
    from arizona
    I have one just like the pic. but it has a sleeve with cooling fins all around it. Kind like a beehive canister. Is that common? Im gona run it on my flathead.
