anyone used the Eastwood hot rod flatz knockoff paint
Discussion in 'The Hokey Ass Message Board' started by dannyego, Jul 28, 2009.
  1. dannyego
    dannyego
    Its half the price. I wonder has anyone used it and with what results
  2. Just Jones
    Just Jones
    I'd love to know the answer to this one too - bump for the left coast PM crowd
  3. roddinron
    roddinron
    You mean it's from Eastwood, and it's half the price!!! Holy ****, what's hot rod flatz charging???:eek:
  4. sik_kreations
    sik_kreations
    damn that keep raising the price of hrf. its 150 a gallon for black. it used to be 99. if ur gunna use black, id use the sem hot rod black instead. more durable.
  5. dannyego
    dannyego
    whats sem hot rod black?
  6. bloodyjack
    bloodyjack
    If ya order on line and type 20off in the coupon box you will get 20% off the price
  7. dannyego
    dannyego
    order which paint? whats the website?
  8. dannyego
    dannyego
    just went to my local paint store and the SEM hot rod black is $70 a qt. Ouch!
  9. The Gambler
    The Gambler
    ****S!!! dont use it, sprays bad stick with hot rod flatz. easy to use and is worth the money.MY 2 cents.
  10. HotRodBen1987
    HotRodBen1987
    are there any other colors? i think black is way over done. also house of kolor makes a flattening agent you can add to your paint which gives it that satin or flat look
  11. dannyego
    dannyego
    already ordered it before the "****s" post. Ill let you know how it works out. I have heard the hot rod flatz ****s to lay down also.
  12. chaos10meter
    chaos10meter
    from PA.
    I just used a gal of single stage black and a qt. of flatner.
    Looks good to me.
    Buddy of mine used John Deer blitz black like 35 bucks a gallon but it was a bit too shiny for my tastes
  13. bloodyjack
    bloodyjack
    The Eastman site http://www.eastwood.com/
    the 20% code works for anything on there site
  14. atomickustom
    atomickustom
    John Deere paint is super cheap and looks good.
    A buddy of mine has sprayed 3 cars with it over the past few years. Goes on smooth, but it's kind of semi-gloss. But they also sell it in a flat and a glossy. Seems durable as all get-out. I used flat black single-stage enamel on my car and his look better than mine.
  15. allstarderrick
    allstarderrick
    Tried the Eastwood stuff, I don't know if I got a bad batch, but I was horrible. I bought it to use on the inside/underside of a couple of roadster bodies that I was doing to try to offset the cost of the usual SEM or Dupont products I'm used to. Ended up doing it twice, so definatley no savings in the long run. The product had poor coverage and was " chunky". Tried refiltering it a few times but seemed to want to give me a textured/dirty finish. Again, maybe it was just a bad batch, haven't tried it again.
  16. zman
    zman
    from Garner, NC
    tractor paint is for tractors, just go to your local paint store and get whatever color single stage you want, add 25% flattening agent. Presto. It'll have UV protection. Look better. Hold up well. Cheaper than hot rod flatz.
  17. fuel pump
    fuel pump
    from Caro,MI
  18. SCR8PINHRD
    SCR8PINHRD
    from delta pa
  19. Scrap Iron
    Scrap Iron
    from Mesa, AZ
    Hot rod flatz i have came in an Omni can with a HRF lable? maybe they added some sort of flatner and the color. but it worked nice. when I repaint the coupe it will have HRF.
  20. dannyego
    dannyego
    looks damn good to me
  21. BBobb
    BBobb
    I have shot both the HRF and the Eastwood hot rod black.I think they sre both ****.I went back over them with the SEM and no probs since....my two cents
    here are both my rides with the SEM Hot Rod black
  22. 57blevins
    57blevins
    from omaha ar
    The last two rides I painted hot rod black I used duponts Hot Hues hot rod black. It's the best that I've found, Yes it's high dollar 80 bucks a qt. and 40 bucks for the pt. of cat. but you can paint a whole truck or car with 2 qts. Have not tryed B/C with flatner in the clear, But thinkin about it. Maybe someone that has will chime in. Alot of the hot rod blacks I've used are hard to keep from streeking.
  23. sik_kreations
    sik_kreations
    http://www.coastairbrush.com/products.asp?cat=580
    cost about 7 bucks to ship for 100 bucks.
    2 quarts will do a s10, soo a medium size car would be about 2-3. not to mention the quality is better.
  24. zman
    zman
    from Garner, NC
    Base coat would already be flat. Now single stage with flattener. That's what you do, that is exactly what Hot Rod Flatz is.
  25. greazy john
    greazy john
    just go to your local paint jobber the all carry cheaper brands [ economy paint] and they can add flattener to any paint brand and if you think 100 to 150 for a gallon is too much the last paint bill for 62 impala bc\cc in ppg concept red 2gal color 2 gal clear,was$ 2300
    now under stand this is a full frame off ...but this real world pricing..nothing wrong with trying to save money , but the first thing you see on a car is the paint
    just my input we go through this every day at my shop
    thanks john at MIZERVILLE KUSTOMS 865 456 6884
    GREAZY HUBCAPZ EAST TN
  26. dannyego
    dannyego
    Im not overly concerned with looks, I just want to seal it so my sweat from working on stops making rust spots on the primer I have to fix. That and I want to do touch ups on it as I do the body work. Thanks for all the input. The coupe with the Eastwood looked good to me so I have no problem going with it.
  27. sik_kreations
    sik_kreations
    so u did a bc/cc, but with concept single stage?
    whats a gallon of ppg single stage red going for nowadays? 6-700?
  28. DirtyThirty
    DirtyThirty
    from nowhere...
    My friend, and club mate did his sign shop truck with it...looks just fine to me, half the price.
    He said he didn't mind spraying it, or have any problems at all...
  29. 57blevins
    57blevins
    from omaha ar
    The base coat has no UV protection in it, It's not the same as single stage paint with flatner in it.
  30. dsiddons
    dsiddons
    from Indiana
    **** man thats great....
