over heating ing. coil
Discussion in 'The Hokey Ass Message Board' started by chrisbob12, Jul 30, 2009.
  1. chrisbob12
    chrisbob12
    What's causes a 12 volt coil converted from a 6 volt coil on a 1947 Ford V/8 to over heat and boil? please help me to correct this problem. Send me your ph.# and I'll call you back
    Thanks, bob,
  2. Piewagn
    Piewagn
    You need to install a balast resistor!!!
  3. Da Tinman
    Da Tinman
    You did install a ballast resistor?
  4. Da Tinman
    Da Tinman
  5. bert haddock
    bert haddock
    from England
    Similer problem with mine although I have a 12v dynamo coil and regulator set up the coil always runs really hot and I sometimes lose ignition.
    I have a good quality Lucas sport coil (lucas and quality in the same sentance - scary)
    Bert
  6. F-6Garagerat
    F-6Garagerat
    Yeah, ballast resistor. The coil is only supposed to see 8.5 volts or something.
  7. LowKat
    LowKat
