Rusty bolts ?
Discussion in 'The Hokey Ass Message Board' started by odogg_mia, Jul 30, 2009.
  1. odogg_mia
    odogg_mia
    from Sin City
    I can't seem to get the lug bolts off the tire any help would be awesome I have wd-40 and an impact wrench them sh!ts is on there
  2. Bruce Lancaster
    Bruce Lancaster
    First, see if the vehicle is an old Mopar or not...seriously. Changes the nature of the problem...
  3. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    If it's on the driver's side, there's a good chance that it could be reverse thread. What sort of car is it?
  4. RichFox
    RichFox
    Is there a littl letter "L" on the end of the stud? I once broke a braker bar in Lovelock trying to change a tire on my trailer with International spindles. Then I saw the "L".
  5. BangerMatt
    BangerMatt
    If they aren't LHT, try some penetrating oil(Aerokroil or the like). WD-40 is good for squeaky hinges.
    We always keep a can of Kroil around for these types of situations.
  6. 30dodge
    30dodge
    from Pahrump nv
    Left handed threads on the left side of this car reverse impact -try again.
    If it is the fronts take the drum off and oil from the inside -try again.
    Heat them up let them cool down -try again.
  7. kustombypook
    kustombypook
  8. henry29
    henry29
    Maybe someone switched the drums.
  9. norms30a
    norms30a
    You said lug bolts, if it's an old car with bolts instead of nuts heat one of the bolt heads red hot, then let it cool naturally until you can touch it comfortably, spray some wd on it then try air wrench. If it's the front do what 30 dodge said
  10. 48fordnut
    48fordnut
    try the trans fluid and acetone/brake fluid tip .it was on the Hamb a few mos back. It works.if you don't have acetone use brake fluid and trans fluid.
  11. Swiss50chevy
    Swiss50chevy
    GM Rust penetrant spray, expensive but it will loosen up any nut or bolt
  12. Punko
    Punko
    from Houston
    WD-40 is a water displacement. You either have reverse threads, or you need to use PB Blaster. The stuff is a penetrating oil that will brake any bolt I've had a problem with.
  13. noticed in your signature that you have a 53 desoto...those have, I believe, both left and right hand threads on opposite sides of the car...
  14. odogg_mia
    odogg_mia
    from Sin City
    1953 desoto powermaster
    would the threads be leftys I'm trying the driver side the heads are rusted I can't see any letters
  15. Bruce Lancaster
    Bruce Lancaster
    Left side is LH rotation on many Mopars...do not know if true for '53. Attack one you have not tried yet turning clockwise...see what happens!
  16. Shaggy
    Shaggy
    from Sultan, WA
    AMC too, and old ford too! but i'm talking early 40's 3/4 ton
  17. yblock292
    yblock292
    cheater bar........bout 4 ft.long
  18. J's on squares
    J's on squares
  19. Like everyone else said, and I like to use heat + parafin wax it wicks up and helps lube the threads don't get it so hot the wax catches on fire.
    I have also fractured bolts by heating red hot and taking a can of spray "air" (the computer stuff) and inverting the can so the liquid shoots out. red hot to instant cold fractured the nut. The liquid is super cold Make sure you don't buy the flamable kind, that would be bad.
  20. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Driver's side is reverse thread.
  21. teledan
    teledan
    from Utah
    Get some PB Blaster on it and let it soak for a little while
  22. 50stude p/u
    50stude p/u
    Studebaker threaded them like that too. And yes, i've spent a good 5 mins trying to figure out why my lug nut wont loosen or tighten. :)
    i'd go with a cheater bar and large hammer.
  23. InPrimer
    InPrimer
    sorta O/T when dealing with L hand thread vehicles, when facing the vehicle on the driver side turn the bolt towards the rear, clockwise on the left, counterclockwise on the p*** side ..seems dumb now, but when I was a kid in the '60's learned the hard way on some cars as mentioned.
  24. unkledaddy
    unkledaddy
    Figure out which way to loosen, then liberally apply a breaker bar with a 3 or 4 foot pipe extension.
  25. odogg_mia
    odogg_mia
    from Sin City
    Got one off need to work on other four
  26. Ontario55
    Ontario55
    If its seized on , spray some " Moove-It" (sp)
    You may have to buy that from an Industrial Supplier
    Best I've ever seen or used
  27. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Was it reverse thread or what?
  28. Weasel
    Weasel
    He said lug bolts, but he also said he cannot get them off the tires - makes me wonder how they got on the tires in the first place....:confused:
    Kids nowadays get dumbfounded by LH threads and not the first time I have seen this question on this forum.
    Like the teenage car hop who, when I left my '58 Chrysler in the middle of the restaurant parking lot with the keys in it, was unable to find the starter ****on on the PB trans. The car was still where I left it and there was one embarr***ed kid, when I returned one and a half hours later.:rolleyes:
  29. Defisch
    Defisch
    from Hudson FL.
    50/50 mix of ATF and acetone for penatrating oil works the best. learned that here on the HAMB.
  30. theHIGHLANDER
    theHIGHLANDER
    Nobody mentioned the torch and candle wax. The absolute best I've used when PB won't do it. And yeah I'm sure it was left hand thread. Mopars kept that until 69 on many of their products.
