350 exhaust cherry red ?
Discussion in 'The Hokey Ass Message Board' started by Ralph Moore, Aug 1, 2009.
  1. Ralph Moore
    Ralph Moore
    Just fired up a friends 32 Ford last week, he's running a 350 crate motor(87ish year model) with an edelbrock performer, Holley 600 cfm (vaccuum secondaries with #64 main jets), Mallory electronic ignition.
    When we fire it up the headers get cherry red within 5 minutes, temperature is over 999 degrees(the max on my scanner). We have tried playing with the timing thinking it may be the problem, but we are wary of running it too long at those temps. The coolant temp gets up to around 175 before we shut it off. The book says 4 degrees BTDC for that year motor, but it's obviously not right.
    Any suggestions?
    Thanks,
  2. Rich Rogers
    Rich Rogers
    Is it possible you have the carb set up way too lean?
  3. 69fury
    69fury
    from Topeka
    check for vacuum leaks around carb and intake, as well. coolant temp is safe so thats a good thing so far.
    edit- was this the first time run with that carb and intake?
  4. Rogers Performance
    Rogers Performance
    Timing to far retarded gas is burning in the headers.
  5. RAY With
    RAY With
    Roger has the right idea and since it's a crate motor it could also have the timing chain off a tooth or so. What ever it turns out to be it needs to be fixed asap. Ryan just finished a nightmare with a crate chev motor so any thing is possible.
  6. Ralph Moore
    Ralph Moore
    we found a vaccuum leak and fixed that, Holley says the jets are right, but we have not tried to change them yet.
    The thought of the timing gears being off a tooth has crossed our minds, but I think we will try advancing the timing first, what would be a good starting point? I've heard that this motor will run at 27 BTDC, but that seems like too much.
  7. RATCAMINO
    RATCAMINO
    that 4 degrees timing at idle is for a fuel injection engine with the distributor un plugged(it's a base and then the computer takes over) should be 12 to 15 with 28-32 total
  8. Rogers Performance
    Rogers Performance
    Set total timing at 32 degrees as a start.
  9. RATCAMINO
    RATCAMINO
    that 4 degrees timing at idle is for a fuel injection engine with the distributor un plugged(it's a base and then the computer takes over) should be 12 to 15 base with 28-32 total
  10. RPM
    RPM
    I'd say bump that timing up at least 10 degrees and check all the advances. Sounds like the timing is way retarded and the fuel is burning in the header tube, as mentioned before.
  11. Ralph Moore
    Ralph Moore
    The distributor is a vaccuum advance style, so timing should be set with the vaccuum off the dist and plugged correct?
  12. ClayMart
    ClayMart
    Keep in mind too that you need more than just initial timing. Does the vacuum advance and/or centifugal advance work like they should? Are the advance weights stuck in the fully advanced or retarded position?
  13. Rogers Performance
    Rogers Performance
    Yes plug the vac when setting initial.
  14. Ralph Moore
    Ralph Moore
    brand new distributor, so they should be OK, but it is possible.
  15. chopolds
    chopolds
    from howell, nj
    I'm telling you...I've seen this problem a lot of times with rebuilt engines!
    After checking all timing/carb adjustments, and vacuum leaks....it's probably the valves are too tight!
    Readjust them , running, to zero lash, + 1/4 to 1/2 turn more.
  16. sloorider
    sloorider
    What do the plugs look like?
  17. sdluck
    sdluck
    Base Crate motor chevy is 7.9 to comp these motos need lots of timing to run ok,12 to 16 btdc with vacuum hose plugged and then hooked to manifold vacuum,will get you in the ball park. Jets don't come in until 2500 rpm.
  18. Rogers Performance
    Rogers Performance
    Yes very easy to do with HYD.
  19. Ralph Moore
    Ralph Moore
    Plugs looked fine, no deposits or strange color
  20. sloorider
    sloorider
    Sure sounds like timing...maybe do a quick TDC on number one and the crank position...
  21. Ralph Moore
    Ralph Moore
    Done that, several times, it's correct unless the cam timing is off.
  22. Meyer
    Meyer
    Just went through something similar, i had the vacuum advance hooked up to the distributor when I set the initial timing. was about 25 deg retarded.
  23. Jingles
    Jingles
    It sounds like either of the following: Cam is not timed correctly; timing is too retarded--- I like about 10 or 12 degrees at idle; or you have a leak between the
    intake and heads--- I had that problem one time many years ago. The cause was
    the intake gaskets. They were too hard and did not compress. The gaskets were
    the early blue one like the blue never retorque head gaskets.
    On the timing issue, you could have the wrong timing tab-- balancer combination and you are getting an incorrect reading.
  24. sloorider
    sloorider
    I think you can rule out vacuum leaks, as this would cause a lean burn and would show up on the plugs.
    Where is the heat greatest on the header?
    Maybe to obvious but, is the firing order correct and the distributor in the correct postion...you know,rotor pointing to number one at T.D.C. on compression stroke.
    Timing or cam/distributor...but still timing...jmho..
  25. sloorider
    sloorider
    Any news Ralph?
  26. Ralph Moore
    Ralph Moore
    OK, after a little playing with it she's running cooler on the exhaust with timing set at 25 degrees BTDC, He took it around the block and it had a little stumble and is idling a bit high (800 rpm), but the biggest thing is now the coolant is running hot. Are we too far advanced now?
  27. power58
    power58
    Read a Circle Track article about getting a photo of a dyno engine with the headers cherry red. They said they had to go super RICH to get the headers to glow cherry red. Just 2 cents.
  28. sloorider
    sloorider
    Wow, you went from 4-25...is that at 800 RPM?
    If so, how about half way...at least ya know its just timing....
  29. Hubbcat
    Hubbcat
    from Sweden
    way to mutch timing
  30. Hubbcat
    Hubbcat
    from Sweden
    braking in my cam with to much ignition burn away the paint on the headers
