White Devil 31 Coupe Build
Discussion in 'The Hokey Ass Message Board' started by WhiteDevil, Jul 21, 2009.
  1. To Tall
    To Tall
    Hay man if you are going with a small block you may want to conceder a 409 or correct me if I am wrong a 348 witch is the smaller 409 that is readily available. I am not a Chevy guy but I have seen them in wrecking yards in old Chevy and GMC trucks a little harder to find and about the same cost as a 327 or 283 .but you will have those cool hump heads (ok Chevy guys correct every thing I just said)
  2. To Tall
    To Tall
    o yea the chrome wheels look sweet
  3. Dude, you are wrong.
  4. To Tall
    To Tall
    Well clarify for the non Chevy guy
  5. WhiteDevil
    WhiteDevil
    Just got in from the garage today. Man was it hot....Got my rear suspension all finished now its totally adjustable so I can actually make use of the 8 inch Z that I have. Got the new lower coilover "adjustable" mounts welded on. Shocks are on the highest mount right now until I get my channel all fixed but the stance is ALOT better now!!! Still can go way lower. Whats the best way to cut the rear panel to give the rear end more clearance??? Got the body moved back another 1-2 inches to where it needs to be. Got all the measuring done for the steering. Long day in the garage was well worth it and my dad came over to lend a much needed hand...the littleman came out and helped alot too! Going to get metal for my floors and some "structural" reinforcement this week. When my pete and jakes front headlight/shock mount combo and chrome shocks come in I will get started on that. Got alot of work done today....
      241.2 KB
      300.8 KB
      248.2 KB
      230.1 KB
      262.1 KB
  6. DirtyThirty
    DirtyThirty
    from nowhere...
    Man, that stance is PERFECT...****, I wouldn't change a thing...
    Once you put a motor up front, and some weight on that spring...hell yeah!
    Hot Rod Rake...
  7. skunx1964
    skunx1964
    is it just me, or does the car look a lil long? maybe just cuz the engine bay is vacant?
  8. DirtyThirty
    DirtyThirty
    from nowhere...
    Looks long...Mine was stretched 6"...no recess on the firewall for clearance. I wonder if this is also?
  9. skunx1964
    skunx1964
    ok cool, thought it was just me, lol
  10. WhiteDevil
    WhiteDevil
    What is the stock frame length? I was told this frame was to stock specs length wise. I think ALOT of it has to do with the fact that there is no drivetrain at all......I love the new stance..I still have to bring the body up a couple inches to even out the channel and then drop the rear suspension to make up for it. It will look good when its done. Also the grill shell is just there for mock up its not mounted at all so dont gig me on how high its sitting
  11. I SMELL SMOKE
    I SMELL SMOKE
    stock length is 103 in wheel base
  12. 31modelo
    31modelo
    Stock for a Model A is 104, you look like you got about 6 extra. No big deal. As long as you like it who cares.
  13. 31modelo
    31modelo
    Smoke is right it's 103 1/2 inches
  14. NortonG
    NortonG
    Looking really good with the wheels and tires on!
    Engine bay looks long to me...
    What is the measurement from the firewall to the grill shell on a model A?
    Norton
  15. WhiteDevil
    WhiteDevil
    So measure from where to where to see what the wheel base looks like? What should the overall frame length be? Im trying to figure out the length if not there may be some changes to be made. Let me know
  16. skunx1964
    skunx1964
    center of front wheel to center of back wheel. thatll give you the wheelbase
  17. DirtyThirty
    DirtyThirty
    from nowhere...
    As far as overall frame length, you should find it doing a search, but, if not, I have a stock length frame I can measure in the a.m....
    Someone should chime in with it...
    Plenty of Model A peeps on here.:cool:
  18. claymore
    claymore
    Ya be different and go with a BLUE OVAL SBF. Thought it doesn't have to be small internally. Stance looks good as it is now and the top height is fine. Are you going to have any ladder brackets on it? :p
  19. WhiteDevil
    WhiteDevil
    Im still browsing for drivetrain...like everyone says all it takes is time and money! I saw a 341 desoto hemi that caught the ol eye! Whats the engine size on a 341 or something close as in comparison to a SBC???? Anyone know?
  20. -Brent-
    -Brent-
    I can't remember off hand, and couldn't find it in my bookmarked sites, but there is a website that has V-8 and inline lengths. I Googled it and couldn't find it. It would be a good things for us to put together here.
    On another note, I like your drive with this project. Keep it up, man.
  21. WhiteDevil
    WhiteDevil
    Wish I had a 341 or something like it sitting in the garage to measure but i dont.....anyone have any engine lengths? Even if its a sbc!
    Great looking coupe there brent! Thanks to everyone for helping me on the coupe so far...going to get some metal for the floors and if my shocks and mounts come in try to get them mounted this week too
  22. DirtyThirty
    DirtyThirty
    from nowhere...
    Gonna stop at garage in the afternoon...I'll get you a few measurements...
    I didn't forget!:D
  23. Mat Thrasher
    Mat Thrasher
  24. skunx1964
    skunx1964
    307 sbc on my patio is 32 from bellhousing surface to fan tips, with a long pump
  25. WhiteDevil
    WhiteDevil
    Awesome thanks alot for the measurements guys!
  26. DirtyThirty
    DirtyThirty
    from nowhere...
    A few of my key frame measurements:
    Front of frame horn to end of rail: 115"
    Firewall/bottom of cowl to front of frame horn: 40 & 1/2"
    Firewall/bottom of cowl to front crossmember @ frame intersection: 27"
    Cowl mounts to front crossmember @ frame intersection: 36"
    Hope these help determine if it has been stretched, or maybe just help in general...:cool:
  27. WhiteDevil
    WhiteDevil
    Thanks for the measurements Ill check it out later tonight
  28. WhiteDevil
    WhiteDevil
    Got all the brake work ****oned up tonight...brakes are all FIN!
  29. Deu55
    Deu55
    Cool Coupe, any new pics...Rod
  30. WhiteDevil
    WhiteDevil
    Nothin really new with pics....nothing exciting about brake work! I should get my pete and jakes chrome front shocks and weld on headlight/shock combo in this week sometime and try to get em on asap w/pics
