Projects Everybody needs a shop truck, let's build a 49 GMC
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Sep 29, 2008.
  1. TRUCKRODDER
    TRUCKRODDER
    I am going with a inline along the framerail with the filter, hopefully it will be alright.I had a fullsize van pump go out an let me tell you I don't want to be stranded like that again :mad:.
    Yeah just trying to plan where everything should be mounted permantly is a challenge for me sometimes :). Looks like your truck is going great!
    I will be driving mine in primer for awhile more than likely, I am working on getting everything inside the cab all ready to paint as soon as I figure a color that can go with any exterior color I choose . I swear I have changed color choices 3 times at least , right now it is three different color primers.....
  2. ratster
    ratster
    what color is going to be painted?
  3. the-rodster
    the-rodster
    I doubt it will see paint for a few years, but my plan is for dull grey cab/bed, and black fenders/running boards.
    Rich
  4. Harrison
    Harrison
    Be sure to update with pics before Shades of the Past. I don't want to be stealing beer out of the wrong truck.
    JH
  5. burger
    burger
    I thought I saw an a/c compressor in the earlier pics, but don't see anything under the dash. Still planning on a/c?
  6. DMFB
    DMFB
    Super nice truck. Great job!
  7. the-rodster
    the-rodster
    The A/C worked great on the donor Caddy.
    The compressor is still in place, with the ports blocked off.
    I have all the parts that I removed, i.e. condensor, lines, drier, etc and would like to hook it back up someday.
    I don't know **** about A/C, but my plan was to use the original compressor, maybe use the stock condenser (depending how it fits), run new lines, new drier, and purchase one of those new remake underdash units from vintage air (Mach V?)
    Can this be done?
    Anybody here an A/C guru?
    Let's talk,
    Rich
  8. Chuckdriver
    Chuckdriver
    Are the upper A-Arm cross shaft bolts installed upside down??
  9. the-rodster
    the-rodster
    Holy ****!
    You're first post...and it makes total sense.
    It would be much easier if the nut was on top.
    Hey, it's my first IFS, but thanks.
    Rich
  10. Chuckdriver
    Chuckdriver
    Rich,
    You've got a great looking truck coming together! I've been looking here and other forums for a while and I just happened to notice the bolts. Keep up the great work and hope you get it on the road soon!
    JJ
  11. v8 Bake
    v8 Bake
    Gonna drive it or Buckshot to the nats this next week.
  12. Hubbcat
    Hubbcat
    from Sweden
    have done the same its a *****.
    But cool as hell when it´s done
  13. Midwest Rodder
    Midwest Rodder
  14. the-rodster
    the-rodster
    ****, I just started a new job two weeks ago and haven't worked up the courage to ask for friday off :)
    The truck isn't registered yet, so I'll be jumping in Buckshot.
    Rich
  15. vexner
    vexner
    Just checked out your build"NICE!" Makes me think I should get my *** in gear and finish my truck.
  16. Solidaxel
    Solidaxel
    Tell me more about your valve covers, are they a direct fit or did you modify them?
  17. the-rodster
    the-rodster
    The valve covers are not modified, they are just a hair larger than SBC, and the end cover bolts will come down at a very slight angle.
    I did trim a stock SBC gasket to fit into the channel on the stude valve cover.
    They hang over the edge, maybe 1/16" all the way around.
    Don't appear to leak.
    Rich
  18. Solidaxel
    Solidaxel
    Thank You, let me know after you put a few more miles on it.
  19. Big Eddie
    Big Eddie
    Hey Rich, looking good. We need to cruise together once you get it going. By the way this is Sams brother (VW guy). Heres my newest ride....:)
  20. Ole_Red
    Ole_Red
    from 206, WA
    helluva build! looking forward to seeing the end product... yours is one of the many that has inspired me to get an older truck and start building.
  21. sirhc
    sirhc
    from Boise, ID
    Beautiful truck, an inspiration for sure!
  22. the-rodster
    the-rodster
    Front fenders mounted, gauges installed, more wiring done...
  23. the-rodster
    the-rodster
    More test driving shows that she's overheating bad, pulled the thermostat, never got over 140. New thermostat goes in tomorrow.
    The 700R4 was shifting crazy, couldn't decide what gear it needed to be in. I knew it had to be in the tv cable, and wondered if I ever took the ****** connection loose when I had it out. I checked it, and sure enough, it wasn't even connected.
    Shifts nice now :)
  24. the-rodster
    the-rodster
    Next up...
    Insurance
    Registration
    Front end alignment
  25. nexxussian
    nexxussian
    Front end alignment, whoa nelly! :eek:
    Lets not get carried away.
    I mean come on, who doesn't like the 'lottery-O-steering' (Step right up folks, who knows which way it'll go next :rolleyes:).;)
    Looks good, let us know what you wind up with for alignment and how you like it.:)
    I've got a '50 Jimmy that's in the 'gathering' stage at this point.
  26. 55 dude
    55 dude
    really cool build dude!
  27. the-rodster
    the-rodster
    Done, Done, Done.
  28. the-rodster
    the-rodster
    So I got to thinking about the exhaust, and the lack thereof, and figured it would be pretty simple to do it myself, especially if I just dumped it down right before the rear axle.
    Since I scored good deals on stainless headers and mufflers, I splurged and bought 12 feet of polished stainless tubing and two stainless u bends, and started...
  29. the-rodster
    the-rodster
    Tigged with stainless rod, and hung with stainless fasteners.
  30. the-rodster
    the-rodster
    But....
    They ****.
    No sound whatsoever!
    No rumble, nothing, sounds like a friggin' latemodel :(
