'54 Special Frame numbers
Discussion in 'The Hokey Ass Message Board' started by phiftybuick, Aug 2, 2009.
  1. phiftybuick
    phiftybuick
    from NM
    Anybody know where the frame numbers are on a '54 Special? I bought this car from the original owner's family, but the VIN tag is missing, and the ***le is long gone. I've read in other posts that the tri-5 Chevys are stamped on the top of the frame under the driver's seat, but I can't seem to find them on this car. I looked on the rear sections of the frame, from the rear axle kick-up back, but nothing. Any ideas??
    :confused:
  2. squirrel
    I would not expect Buick numbers to be where they are on a Chevy...
  3. retromotors
    retromotors
    Hmmmm ... this probably won't help at all.
    I did a Yahoo search on "1954 Buick frame number", and the first one on the list was your question to the AACA.
    The second one on the list was sorta tantalizing, as follows:
    ... Buick decided to stamp the serial number on the frame, on ' ... 1954 is a tough year on frame numbers, because Buick changed their system in April 1954. ...
    forums.aaca.org/ubbthreads.php/<wbr>topics/<wbr>415533/1954_Buick_question
    However, when I click that link, it just takes me to the AACA forums. I'm kind of a search dummy, but if you can track down that post it may shed some light on your question.
    Good luck!:)
  4. gorilla
    gorilla
    from Idaho
    you can check buickgod.com you might find some info there
  5. phiftybuick
    phiftybuick
    from NM
    Yeah, that was me. I thought I could find someone who did a frame-off and had seen it. There were a couple of guys that said they found the stamping on theirs, one was on the right rear frame horn, and the other was on the left. Oh well. I guess I hafta look some more.
    Thanks a lot.
    -phifty
  6. O.Hove
    O.Hove
    from S.D.
    Last year Buick put the serial # on the frame was 1940.
    1952-1960 ,on hinge pillar post,fire wall under hood.
    HOPE THIS HELPS
