T-5 Tranny Questions
Discussion in 'The Hokey Ass Message Board' started by OldCarPilot, Aug 3, 2009.
  1. OldCarPilot
    OldCarPilot
    from Bel Air MD
    Gunna do a 5 speed in a 53 AD truck. It will be behind a mildly hopped up 305. I know I need a world cl***, but does it really matter if its a "chevy" or "ford" one. i.e. does the chevy bell housing bolt on to either ******?
    Also does anyone know the measurements from the front of the ****** to the shifter for both?
    Thanks.
  2. mosimpson
    mosimpson
    <TABLE cellSpacing=0 cellPadding=5 width=300 align=center bgColor=#ffffff border=0><TBODY><TR><TD cl***=articletext height=96>Tremec T5 (5 speed)
    [​IMG]V8 T5's can handle roughly 300 lb.ft. Good for small block Fords, less than 351 cid displacement, street driven. </TD></TR><TR><TD cl***=articletext>
    [​IMG] </TD></TR><TR><TD>Dimensions
    A=19.5"
    B=7.2"
    C=14.5"
    D=24.7"
    Weight
    75lbs
    T5 Rebuild Manual - PDF 4.11MB
    To save the manual on your hard drive, right click mouse and select "save target as", then choose the directory to save to.
    </TD></TR><TR><TD><TABLE cellSpacing=0 cellPadding=5 width=300 align=center border=0><TBODY><TR><TD cl***=captions colSpan=6>Gear Ratios</TD></TR><TR><TD width=34>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]1[/SIZE][/FONT]
    </TD><TD width=28>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]2[/SIZE][/FONT]
    </TD><TD width=40>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]3[/SIZE][/FONT]
    </TD><TD width=36>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]4[/SIZE][/FONT]
    </TD><TD width=61>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]5[/SIZE][/FONT]
    </TD><TD width=55>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]Reverse[/SIZE][/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]3.35 or 2.95[/SIZE][/FONT]​
    </TD><TD width=28>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]1.94[/SIZE][/FONT]​
    </TD><TD width=40>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]1.34[/SIZE][/FONT]​
    </TD><TD width=36>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]1.00[/SIZE][/FONT]​
    </TD><TD width=61>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]0.63[/SIZE][/FONT]​
    </TD><TD width=55>
    [FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-2]2.76[/SIZE][/FONT]​
    </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
  3. 53sled
    53sled
    from KCMO
    only with an adapter. there are two different cases, and newer s10s (2.2L) actually used a ford pattern iirc. There is a nice write up on inliners.org about a wc camaro t5/s10 tailhousing swap.
  4. adventurer
    adventurer
    Bolt pattern on Ford T5 is completely different from GM T5.
  5. onlychevrolets
    onlychevrolets
    why do you need a world cl***? you going to beat on it? if so then I agree
  6. todd_a
    todd_a
    from Tyler, TX
    Is that true? I was thinking the front of the ****** was the same and the bell housing that bolts to the ****** was the place where things were different. I know the tail shaft is different and the location of the shiifter was available in 3 different locations on T5 transmissions. Probably is different as the chevy T5 has a different shifter location than the ford version, so the case is probably totally different.
    Too bad.. I know the ford version inside out! I've rebuild a bunch of them.
  7. OldCarPilot
    OldCarPilot
    from Bel Air MD
    Are they hard to rebuild? Never done a manual ******. Built a few engines.
  8. onlychevrolets
    onlychevrolets
    they are not hard to build, my T-5 screamed in every gear but 4th so I tore it down, it needed a counter shaft and I replaced all the bearings , I think total cost was $220.00 for everything, and it works perfectly my nail head loves the overdrive
  9. Flat Ernie
    Flat Ernie
    Tech Editor
    Check the tech link in my sig. Easiest way to do this behind a 305 is a bellhousing for any old SBC 4-spd & a T5 from a V8 Camaro or Firebird.
    But there's more than one way to skin this cat...
  10. Buzznut
    Buzznut
    Here's a list of T5 factory applications:
    The T5 Page
  11. OldCarPilot
    OldCarPilot
    from Bel Air MD
    Thanks for the good info guys!
  12. Flat Ernie
    Flat Ernie
    Tech Editor
    That's a pretty incomplete list, but it's reasonably accurate for what it does list.
  13. HighlyFavored
    HighlyFavored
    G-Force Transmissions are very popular in the mustang drag racing world. They can handle various levels of power based on your needs, and I'm sure they could tailor a bellhousing to your motor. They specialize in bulletproofing T-5's. http://www.gforcetransmissions.com/
  14. OldCarPilot
    OldCarPilot
    from Bel Air MD
    Is a WC ****** that was behind a v6 car going to hold up the same as a WC that was made for a v8? Are there differences in WC t5s? (besides gear ratio)
  15. blown green t
    blown green t
    Do a search on the HAMB. There is a thread on here that has more info than you can imagine. I'll post a link later if I find it.
  16. OldCarPilot
    OldCarPilot
    from Bel Air MD
    I searched a bunch before posting and read most all that I found, flat ernie's page is the best so far. I was just hoping someone would have a quick answer on the v6/v8 thing.
  17. johnboy13
    johnboy13
    My father in law has a Non W/C from a 4 cyl (I think it was a 2.5L) behind a mostly stock 305. So far it hasn't blown up, but he treats it pretty good. He does get on it every now and then. It's probably only a matter of time before it's done.
  18. 73RR
    73RR
  19. blown green t
    blown green t
    TECH: Ultimate T-5 Article
    The thread I was talking about was Flat Ernie. If I remember correctly, the 4.3 v-6 and the v-8 use the same bell housing. I think most of the info you need is in his thread.
  20. Flat Ernie
    Flat Ernie
    Tech Editor
    It depends. The gear ratio plays a part in the strength. In general, all else being equal, a high 1st gear ratio (lower numerically) is stronger than a lower 1st gear ratio.
    But you won't find ratings for each and every T5 anyway...
  21. bobscogin
    bobscogin
    Ratio differences not withstanding, the difference in the WC and non-WC is in the bearings and synchros, which are the same on the WC version of V6 and V8.
    Bob
