AD 1947- 1955 Chevy Truck Pic Thread...
Discussion in 'The Hokey Ass Message Board' started by Hans, May 15, 2006.
  1. caseyjones
    caseyjones
    My little brother's...before the bags.
  2. wheels1950
    wheels1950
    from PA. USA
    will be at goodguys charlotte in a few weeks FRANK
  3. squigy
    squigy
    from SO.FLO.
    that is called a waterfall intake.the intended purpose was to catch any carb gas leakes so they wouldnt drip on the exhaust and cause a fire.and it looks kool too....:)
  4. Old Roadster
    Old Roadster
    Gringo i hate to be a pest how about pics of interior and engine.......Can`t get enough of that truck, also like that it is three window NICE.......
  5. rdstr31
    rdstr31
    from Ney, OH
    Here's my old one. Shoulda never got rid of it....
  6. rdstr31
    rdstr31
    from Ney, OH
    HERE it is...
  7. Danimal
    Danimal
    Nice truck, Chad. I know somebody that could hook you up with enough parts to build one of those. A sweet motor and everything, you just need a trans but that might be under way as well! S10 frame is cut to length and should be welded square by the end of the week, body mounts are designed, and rear axle is swapped. I'll try to post some pics of our progress!
  8. 51Gringo
    51Gringo
    from Nor Cal
    I don't have any pics of the motor at the moment, it had a fresh 350 put in just before Billet'06, although, I can tell you it's pretty simple, shaved firewall and mild dressup motor, a/c, batt still mounted under the floor, etc..Looks nice, but not wild. Here is a pic of the interior in progress.[​IMG]
  9. Old Roadster
    Old Roadster
    Nice and simple I like that, seat looks good.........CLEAN
  10. rdstr31
    rdstr31
    from Ney, OH
    You ****...:)! I've been gettin the itch to build another one lately, but I've got the '71 to finish. There's never enough time or money...
  11. dt50chev
    dt50chev
    Here's my old gem. I'm in the process of swapping to an s-10 frame. My truck was originally a 1 ton. I will be shortening the bed.
  12. Ed ke6bnl
    Ed ke6bnl
    here is my gem in the rough, also in the process of fusing it to an S10 1985 pu.
    I have never seen it with the front fender picked it up this way. no rust Ed ke6bnl
    cant wait till I get it running as a daily driver and then go back to my 50 Ford F1 to do some serious body work and paint to.
  13. Old Roadster
    Old Roadster
    Should be some new trucks by now, led sleds , low riders , let's see.......
  14. CraigKrage
    CraigKrage
    from central IL
    Here is my 49 and my friend Jean. The truck is a constant work in progress. I've got a chopped top cab that I just got started on and will be on this truck............Sometime maybe:D
  15. Danimal
    Danimal
  16. lownslowtexaco
    lownslowtexaco
    from athens,tn
    my 1949 deluxe cab shop truck
  17. ven
    ven
    from Tampa
    Heres a few from some other sites...
    [​IMG][​IMG][​IMG]
  18. DRUGASM
    DRUGASM
    I'll join the party.
    1950 3100, 235 w/4 spd and closed drive. An actual barn find thats been parked since 1967. This photo is from the first drive around the block after going over the truck system by system.
  19. Lone Star Mopar
    Lone Star Mopar
    I got a 49 chevy 5 window in the cl***ifieds if any body wants it 500$
  20. Mine again...
  21. BUDDY HOLLY
    BUDDY HOLLY
    My 52 still working on it getting bags in the near future. THE NEWER PICTURES ARE WITH THE CRHOME SMOOTHIES AND A LITTLE LOWER
  22. LULL
    LULL
    heres my 49
  23. wideside72
    wideside72
    from Leander TX
    Dad's 48 GMC
  24. wideside72
    wideside72
    from Leander TX
    Here's my recently acquired 55 Chevy 1st series. The P.O. said he gave $2k for it a little over a year ago. That seems a little high. I got it for half that. It needs cab corners and floor boards. The original drivetrain (engine # is on ***le) including open driveline is intact. It's too bad it is going on an S10 2wd reg cab LWB frame with a 1994 Caprice LT1/ 4L60E. I already picked up a wider S10 4x4 rear axle with 4.10 gears. I also recently acquired a better grill and a pretty nice tailgate at the Central Texas Swap meet at the Travis Co. Expo center a couple of weekends ago. I have a 55.5 big window, but have a good gate for it. I hadn't bought this truck yet, but the price was right. That is the way my projects usually work. I buy the parts, then find the truck to use them on. Notice that this truck and 54's have flat tops on the bed sides in addition to one piece windshields.
  25. Piston Farmer
    Piston Farmer
  26. dan sutton
    dan sutton
    I have my work cut out for my '48
  27. Mr48chev
    After a 14 month nap the thread is alive and I never managed to see it before.
    This one was hiding out on the edge of things at the East/West No overheads run this year.
    The latest addition in my stable.
    The 48 with My family in front (before the youngest was born) about 30 years ago.
    Nice chop and touches on this one that was at the 09 Portland roadster show. I think it belongs to someone here on the Board.
  28. hershambob
    hershambob
  29. toddwith2ds
    toddwith2ds
    from AZ
    Here are a few pics of mine. Got it a few years ago with a butchered up frame, no interior or wiring. Drove it until said frame cracked and blew it apart. Plan on doing an s10 swap this summer. Wish me luck!!!
  30. dirtydixon
    dirtydixon
