Small Block Chevy Distributors
Discussion in 'The Hokey Ass Message Board' started by DMC, Aug 12, 2009.
  1. DMC
    DMC
    from SC
    All right, I need some more advice. What distributor are you guys using in your small block Chevy engine? I need some pics of your set-ups.
    Thanks.
  2. j32
    j32
    I like using a MSD hei if you have the room,their a one wire hook up for 12 v one for tach and your set. If room is an issue use a MSD ready to run dist. still easy hook up, uses a external coil and you don't need to use a MSD box,hope this helps.............
  3. gearsforguts
    gearsforguts
    from temple,pa
    im running stock pionts dist. in my two small blocks both have blue streak points and caps never have an issue with them
  4. Dandingo
    Dandingo
    Here's mine with a Procomp HEI. I mistakenly called it an MSD. It actually is a bit cheap. Doesn't seem to fit 'comfortably' for some reason but still works great...
  5. lowrodderDon
    lowrodderDon
    I just picked up an MSD ready to run, it's all I recommend and I've never regretted it. There are some cheaper ones but who knows how long they will last. I also like the ready to runs because they more closely resemble a stock type dizzy.
  6. jamesgr81
    jamesgr81
    Don't buy the Proform, Procomp, or other HEI China knock offs. Pure junk. The advance mechanism will fall apart and give you locked out advance that will give you fits troubleshooting until you figure it out.
  7. Seepwater
    Seepwater
    a points distributor with a pertronix conversion kit. Looks traditional, isn't huge, and runs like a top.
  8. jerry
    jerry
    A chevy "window" type cap dist with GMCBubba's electronic conversion. Nothing runs better, and looks traditional!
    jerry
  9. Fifty5C-Gas
    Fifty5C-Gas
    Im running a Mallory Unilite mechanical advance.
  10. landseaandair
    landseaandair
    from phoenix
    Sorry, no pics, but my favorite lately has been to rehab a factory distributor and use the Crane drop in conversion. It doesn't require a reluctor wheel and it has a built in rev limiter. I'm not sure if they are currently available, but Summit has them on their website for around $65.00, search XR-i.
  11. 39 Ford
    39 Ford
    A later (small dia.aluminum body) points dist with Pertronics kit. Fits my firewall and looks traditional.
  12. I agree 100% on the Bubbas HEI Distributors!! I have one of his old Mallory/ HEI converted critter and its beautiful and works perfectly! looks like an old dual point with the coil and module hidden under the dash. He even put the old br*** condensor on the side to complete the look. distributor **** at its finest. "GMCBubba" on the Hamb.
  13. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    im runnin a mallory dual point. Still runnin the points too. They work great if you know how to set em up.
  14. hotroddon
    hotroddon
    In one I have an Old Stock dist with a PerTronix conversion in the other I have a PerTronix Plug N Play self contained dist.
  15. Buzznut
    Buzznut
    I'm running a Mallory Unilite vacuum advance with an MSD Blaster II coil...works great!
