What would you do with a 32 axle and bones? This is what I did
Discussion in 'The Hokey Ass Message Board' started by donut29, Aug 12, 2009.
  1. donut29
    donut29
    from canton MI
    Between layout drilling welding and grinding it took me 10 hours to do this. I want to thank Jeff (gmgrunt) for making the sleeves for me.
    I have been thinking about drilling 3 more hole between the perch bolt hole and the king pin. What do you guy's think about doing that?
  2. model-a-fan
    model-a-fan
    from Kentucky
    AWESOME. I wish I had the balls to do that to mine!
  3. Unkl Ian
    Unkl Ian
    Not if you are going to drive it.
  4. Nice! I think this has come up a few times, and the general consensus is no, don't drill past the perch. I didn't on mine.
  5. KUZTOM
    KUZTOM
    Done my bones the same ,Its a bit of work ,but worth it.
    With ya Axle, I would leave it as you have done ;)
    Looks good...........
  6. Royalshifter
    Royalshifter
    Moderator
  7. lowsquire
    lowsquire
    from Austin, TX
    Done.
    dont drill any more holes.
    would be a bit too tryhard..unless it was under a real early sixties nose-up drag car.
  8. donut29
    donut29
    from canton MI
    Thats not a bad idea never thought about that. I am going to peek the top I just have to find the mag that Gene showed how to do it Any one know what mag that was? Think it was a R/C?
  9. studematt
    studematt
    Leave as is. Don't fill the ends.
  10. solid
    solid
    I think they look real cool the way they are.
  11. The37Kid
    The37Kid
    Nice work, looks great as is. Did you weigh the bones when you started, are they heavier or lighter now?:rolleyes::)
  12. Just Gary
    Just Gary
    Looks great!
    Tell us more about the specifics: What kind/size/grit grinding wheel? Hole sizes? Drill speed? Anything you wish you'd done differently?
    Thanks in advance.
  13. 39 Ford
    39 Ford
    Look great leave well enough alone, quit while your ahead. I have screwed lots of things by not knowing when to quit.
  14. VAPHEAD
    VAPHEAD
    You can't drive around on that.
    How about a Mustang2 front end?
  15. 49ratfink
    49ratfink
    I thought they only filled the ends on dropped axles to hide the stretch marks?
  16. Sphynx
    Sphynx
    from Central Fl
    With a little bit of work I think you could save it but thats alot of holes to fill I will trade you a 40 axle so you want have so much work , nah just pulling your chain looks great .:D
  17. blitz
    blitz
    i think its was Hot Rod Deluxe or Rod & Kulture, maybe. im sure i have the issue it would just take a while to find it.
  18. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Ya done good...
    Just do me one favor, DON'T DROP IT...
  19. donut29
    donut29
    from canton MI
    You know what your right what was I thinking Ill call you tomorrow and order one of your all billet IFS:D:D
    Backing plates are going to get drilled full of holes to:) Any idea when they will go out?
  20. FiddyFour
    FiddyFour
    leave the ends... fill em if you drop the axle but leave it as is untill you do, but unless you want a show only piece dont drill em
    *****in look man. nice work
  21. Kevin Lee
    Kevin Lee
    Super Moderator
    Not true. I've seen old photos of undropped axles filled and at least one completely filled end to end.
  22. Deadbird
    Deadbird
    Looks good as is.
  23. drflex
    drflex
    i'll take it!!!
    edit: sorry not the cl***ifieds
  24. Pewsplace
    Pewsplace
    Nice work. Don't do anymore drilling. I have a MII I cut off mine. I will trade you even up maybe even give you a buck or two. Lots of work but it looks super.
  25. Max Gearhead
    Max Gearhead
    from Wisconsin
  26. Just Jones
    Just Jones
    Yep - X2. Don't change a thing, they look *****en.
  27. donut29
    donut29
    from canton MI
    Axle 1-1/8 drilled on 1.777 centers that leaves 5/8 between holes
    Bones Used three size hole saws 1-1/2,1-1/4,1 250 rpm that's the slowest my drill press goes
    grinding I used a 4in 50grit flap wheel and a DA with 80grit
    Now after I got the input I wanted about drilling more holes I'm done and there is nothing I would do different
    I'm still going to peek it just need to find that tech article on how to do it
    Is this want you wanted to know:D
    Tom
  28. PoPo
    PoPo
    that looks *****in!! sweet job man.
  29. Hitchhiker
    Hitchhiker
    that was my thoughts as well. But, that doesn't mean you couldn't fill the ends on a undropped axle. IMHO it just originated because when you drop it, they stretch, so then you fill it to make it look pretty.
  30. Warpspeed
    Warpspeed
    If this is a show queen, never to be driven, just polished and pushed around by hand, and trailered everywhere, then go for it.
    If you plan to put in some serious road miles, and have some fun on the street, rather you than me my friend.
