Help ,,removing Magic Marker from old Paint
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Aug 13, 2009.
  1. Little Wing
    Little Wing
    from Northeast
    Ok got these wheels that are just perfect for what I want. Only drawback is they got written on with magic marker.. What can I do to remove this and not end up with a spot that stands out from the rest of the finish ?
    Was thinking a lil gas on a rag ,,but afraid of the paint ( specially teh stripes ) perhaps raising or something. or sos pad but affraid of ending up with a 'dull' spot
  2. jimi'shemi291
    jimi'shemi291
    No ****, Little Wing, I recently read all the crazy things WD-40 will do beyond what it was designed for. Given the surface rust, maybe that Magic Marker penetrated too deep to come out. But, hey, at least WD-40 would HURT the pinstripe, buddy. Worth a try.
  3. jimi'shemi291
    jimi'shemi291
    OOPS! Of COURSE, I meant "would NOT hurt" the pinstripes!!!!!!!!!! Damn my clumsy fingers on this keyboard!
  4. Mason
    Mason
    Try "Goof off", Alcohol, lacquer thinner in that order....
  5. autobodyed
    autobodyed
    from shelton ct
    try a little enamel reducer. should'nt hurt the stripe.
  6. budd
    budd
    the other day i was at the laundrymat and i guy came in with shorts that had ink on them, the lady who worked said hairspray would take it out and started spraying them
    with it, you could see the ink start running right away, i have no idea what it would do to your wheels.
  7. blitz
    blitz
    do a search on google, kids write all over walls with everything from crayon to magic marker. i bet theres some stay at home mom that has some way to do this with out hurting the paint. really i would look before i go near it with any chemical those wheel are to cool to risk.
  8. rainh8r
    rainh8r
    That stuff is hard to get out without something strong. Lacquer thinner will work, but it will take the stripes with it. Brakeclean too. Using these markers on bare metal is bad-the ink will get into the steel and keep coming back, even through paint. Use paper and tape to mark your parts, not felt pens or laundry markers please.
  9. Flipper
    Flipper
    from Kentucky
    Permanent markers are the debil!
    I have seen marker come through fresh paint, the paint sanded off, the metal re-sanded, washed in thinner a couple of times....no visible signs of the writting. Every time primer or paint was sprayed the writing would re-appear.
    I don't know if epoxy primer would have trapped it, but regular laquer primer didn't stop it.
  10. skajaquada
    skajaquada
    from SLC Utard
    Magic Eraser...not even kidding
  11. Little Wing
    Little Wing
    from Northeast
    Will gas do anything to paint this old ??
  12. chromedRAT
    chromedRAT
    Denatured alcohol lifts permanent marker pretty well. I think the hair spray trick works because of the alcohol in it, to be honest.
  13. angry
    angry
    from ventura ca
    acetone use it to remove marker every day at work
  14. BangerMatt
    BangerMatt
    if it's sharpee, try dry erase markers . . just rub on, and wipe off.
  15. rjgideon
    rjgideon
    Acetone is the bomb, it takes marker up like you wouldn't believe. Also works great to remove adhesives from painted surfaces (i.e. dealer stickers on the back of your new car/truck).
  16. Little Wing
    Little Wing
    from Northeast
    cool,,thanks everyone
  17. I wrote numbers with magic marker on the spines of some original Hardy Boys books, the old brown ones. Any way to get the marker off? 30 years later and my dad still gives me ****.
  18. Von Rigg Fink
    Von Rigg Fink
    from Garage
    i heard the hairspray thing too...no proof of it yet..but thats what ive heard
    post back let us know what did the trick
  19. strike a poser
    strike a poser
    from Salinas,CA
    90% denatured alcohol works like a charm.
