NOS FORD 24 Stud aluminum heads
Discussion in 'The Hokey Ass Message Board' started by Ford Farming, Aug 13, 2009.
  1. Ford Farming
    Ford Farming
    I have a pair of NOS aluminum heads for a 24 stud flathead part # C7RA-6050-B, My question is how far can I deck them witha 4" stroke and stock style dome pistions to end up with a streetable compression ratio? OR should I just mount them on the wall next to my 37, 21 stud aluminum heads and buy an aftermarket set of heads for the 48 Merc motor I am building.
  2. DICK SPADARO
    DICK SPADARO
    With the junk gas that you purchase now there is no need to deck the heads, bolt them on and use them. Just check the valve clearance and piston clearance before you bolt them on.
  3. Ford Farming
    Ford Farming
    Thank you for your reply, had a look at your site, I will be needing a cut down drive shaft in the very near future.
    Ford
  4. Ford Farming
    Ford Farming
  5. Bruce Lancaster
    Bruce Lancaster
    Also...are they NOS Canadian or Weiand "cheater" heads for stock car racing?? Same look and number.
    Up top, Weiand is a bit cruder casting, usually has only 2 of the 4 small water outlets drilled and tapped, says "Weiand" on upper edge toward manifold where you can't see it when installed. Chambers totally different...I have CC specs on the real ones in Canadian service bulletins. Honest Charley Speed shop got hold of the last big batches og each in the USA in the late '60's, then Joblot sold of the remaining Ford ones.
  6. tommy
    tommy
  7. BanjoBoy
    BanjoBoy
    Interesting thread. Did not know Canadian Head and Weiand Heads were the same almost!
  8. BanjoBoy
    BanjoBoy
    Would The Weiand And Canadian Heads both Have SAme Specs/ Comp RAtio? CC's?
  9. Bruce Lancaster
    Bruce Lancaster
    No. Chambers are different...Weiand came with two different ratios, likely altered by now and likely not accurate at the beginning.
    Basically a normal Weiand head with no finds and slightly crude counterfeit Canadian markings. I've got the spec for the actual Canadian head at home...it was a bit higher comp than equivalent stock iron heads.
  10. Shaggy
    Shaggy
    from Sultan, WA
    NOT all weiand, just the weiand sportsman, or 'cheater' heads which were intended to look stock to fool tech inspectors, and other racers
  11. BanjoBoy
    BanjoBoy
    I Love The Cheater Idea And Will Be Lucky To Come Across A set of any Weiand Head Model
