drive shaft
Discussion in 'The Hokey Ass Message Board' started by chevy3755, Aug 13, 2009.
  1. chevy3755
    chevy3755
    any one here shorten there own drive shaft.....i only need to take out about 3 inches......
  2. 55 dude
    55 dude
    what is the application?
  3. onlychevrolets
    onlychevrolets
    yup. I have, cut at the weld ( either end) cut out what you need , line the caps back up and tap the yoke back in , now install it and have some one turn a wheel while you watch the tube, you can make a marker to show where its out and tap that spot to true it. I started doing this in 75 when I killed drive shafts in my Chevelle. If you take your time you can get it dead on. Then weld it up. Or you could just pay someone to do it.. but then what fun would that be?
  4. chevy3755
    chevy3755
    have ford 9 inch rear end to gm 350 turbo.....i have the universal......i thoght i would cut to lenght square....then trim the tube from the yoke on the lathe then reweld.....
  5. TomWar
    TomWar
    I have shortened quite a few over the years, Recently, I changed from a 350 to a 700R4, in my El Camino and had to take out about 3". I cut it off behind the yoke, and then cut off the tube that was left on the yoke, about an inch, that left a shoulder on the yoke that just fits in side the driveshaft tube. you can then cut the tube to the proper length and push the yoke back in. and then weld it up.
    I have never had a problem with out of balance, you just have to be careful with what you are doing.
  6. OldBuzzard
    OldBuzzard
    If you put a piston ring compressor around the shaft at the cut line & scribe a line, you can get a nice square cut with a hacksaw.
  7. onlychevrolets
    onlychevrolets
    I see you guys have been there, I don't know if all you guys do it for the sake of doing your own work, but I do it because I can't afford to pay to have it done.
  8. chevy3755
    chevy3755
    i cut it in the band saw....it cuts pretty square......im just concerned about the balance.....i have the yoke turned down on the lathe and a shoulder.....so it looks like im ready to weld er up..........and i have it in phase.......just the balance that bothers me
  9. chevy3755
    chevy3755
    thats the main reson im doing it myself.....cost......dont get much SSI....and havnt got my bailout yet from commander in chief
  10. chevy3755
    chevy3755
  11. onlychevrolets
    onlychevrolets
    if its true I bet ya it don't need balanced...but if it does ( and it won't) take it and have that done
  12. Jimv
    Jimv
    I always use a pipe cutter to shorten them, cuts a perfectly sq edge.Also if you cut it try to cut in on the end that doesn't have any weights.You can semi balance it with 'worm" hose clamps.
    When you have something as small in dia. As a drive shaft the balance isn't that critical.A 1/2 oz out on the outside of a 31" tire makes a big differance!!
    JimV
  13. A driveshaft only spins over 2000 rpm when the vehicle is traveling down the road. Why would it need to be straightened properly before welding and balanced?
    We straighten our shafts to within .003" before we fire off the welder. Then we balance to run smoothly at 3000 rpm.
    Think good workmanship is overrated? Have a good bunch of u-joints, spare ******s and rearends on hand if that's what you think.
  14. chevy3755
    chevy3755
    thanks for thr info guys...........i think i will give it a go.....
  15. Brickster
    Brickster
    I agree
  16. ShelbyStang
    ShelbyStang
    Def get it straightened and balanced! My late model stuff(Nitrous, stickshift, slick) is a driveshaft eater! I have repaired numerous 2pcs myself, but everytime I try on a 1 piece, if I dont get the shaft squared and balanced, it anhilates joints! just my advice...
    Look for a local "Diesel repair" shop, they often to driveshaft work for CHEAP....relatively of course.
  17. Truckedup
    Truckedup
    If you have tall tires and 3.08 gears it spins 2 grand at 60 mph.4.11's gets it spinning a lot more,like nearly 3000 rpm's.
  18. 53sled
    53sled
    from KCMO
    the $200 is worth it for me, if it is not right, they fix it. but inland truck hasn't failed me yet!
  19. Just one more thought about this subject.
    I've built and repaired driveshafts for a living for thirteen years, been selling, advising, and teaching driveshaft knowledge for another seven.
    I've repaired driveshafts modified in home garages that the guy who did it said, "It just needs to be balanced", and the job ends up costing him more money than if he had brought it to someone like me in the first place because of the parts that were damaged from lack of knowledge. I have enough tools and equipment in my own garage to cut at shaft and reweld it almost as precisely as I can at the shop, but almost doesn't get the job done correctly.
    If you have a machine shop at home, you might be able to do the job right, but I've seen dozens of driveshafts modified at good machine shops that ended up being hack jobs.
    Guys like ShelbyStang are my customers. Look up Arkansas Outlaw Racing's web site. The guy with the Willys, Michael, has depended on my shop for fifteen years for his projects. Another customer holds a records at Bonneville at over 240 mph with my workmanship spinning less that a foot away from him.
    So what do I know? Done with my rant, bothered me how some of you guys that know so much will give bad advice. Cutting shafts at home is ratrod ****.
  20. One more time so y'all might learn something.
  21. ShelbyStang
    ShelbyStang
    ^well said. I love reading GOOD advice!
  22. 57JoeFoMoPar
    57JoeFoMoPar
    Agree 100%. Not only precision machinery, but an expert hand guiding it is necessary to get the job done right. Honestly, shortening a shaft isn't exorbitantly expensive in the grand scheme of a build.
    another tidbit, the further off the center line your driveshaft is off balance, the more effect that will have at higher RPMs. A little bit in one direction, a few grams could equal several pounds at 3000 RPMs. Think about a 10 lb dumbell swinging from your driveshaft... Well worth the few bucks to let a pro handle it
  23. SB5332
    SB5332
    from NEW YORK
    Fyi .............. I used a 84 s-10 front in a 32, 36 inches long. Also used an astro van 4 wheel drive front on another 32 ford. Just had to get the ******* universal from gm to ford 9 inch also used on many old mopars b bodys.
    There are others but i forgot which ones.
    Maybe if someone knows where to find driveshaft lengths on the net, it would be a great article to post for tech.
    Still have that 32 4 door to sell on the junk frame. Anybody interested in a real 32 ford project?
    Rich......hiboy32@verizon.net THE 32 IS GONE! WENT TO THE RIGHT GUY TO DO IT THE RIGHT WAY.
  24. I haven't found anything that lists driveshaft length applications. I just use my memory from stuff I've worked on over the years to approximate a proper donor if a used shaft is the needed starting point. Sometimes used isn't the proper option.
  25. bobss396
    bobss396
    I used to do them on my stock cars when I had a Ford rear in a Chevy. I used a big Rigid pipe cutter, the clean square end is essential. I'd cut the rear yoke plug out with a diamond impregnated hack saw, taking my time. I had no lathe access at the time so I used a bench grinder to clean it up. The inside of the tube I'd taper with a round file. From there it was square up the yoke plug to the tube, I'd make the plug so it took a little press to get it seated. Then do a couple of tack welds, check it again and weld it up, skipping around with short welds to minimize the heat twisting something out of whack.
    I've cranked them up to 7k RPMs and never had a vibration issue.
    Bob
  26. theHIGHLANDER
    theHIGHLANDER
    Wrong. Lost count of how many we did. Never a failure. They weren't ratrods though, maybe that's why?
  27. chevy3755
    chevy3755
    thanks for all the info guys.......some very creative.....
  28. plodge55aqua
    plodge55aqua
    from Alberta
    Would cutting the rear section of the drive shaft for shortening be easier and safer??
