I can't find a trailer for rent!! WTF??
Discussion in 'The Hokey Ass Message Board' started by Ian Berky, Aug 14, 2009.
  1. Ian Berky
    Ian Berky
    Alright, i've been trying to find a trailer to haul my 51' and I'm going crazy!!
    If you live in No Hollywood or valley , burbank and know of a place, PLEASE let me know!! The closest place i found is in Santa Ana, That's far!!! I tried ALL of the usual companies...... Negative!!
    Thanx
    Ian
  2. Q
    Q
    Have you tried telling them you'll be hauling a 2004 Toyota? Lots of the rentals don't have 'our' cars listed in their software.
  3. Ian Berky
    Ian Berky
    Haven't done that!! I ask for a 17'.
  4. rcoffey
    rcoffey
    Yea tell them you are hauling a v.w.,bmw or something like that
  5. 562roadster
    562roadster
    +1 on the VW. Done that many times.
  6. Ian Berky
    Ian Berky
    If i say a VW they'll give me a 10' trailer:confused:
  7. NITROFC
    NITROFC
    Did you try UHAUL ....
  8. Ian Berky
    Ian Berky
    Yep!!
  9. zman
    zman
    from Garner, NC
    Used a uHaul trailer to bring my 38 back for Jersey. They have one size.
    The vehicle being towed:
    • Must not weigh in excess of 5,290 lbs.
    • Must have a maximum outside-to-outside tire width of 79.25"
      Note: outside tire width over 75" must use late-model <nobr>U-Haul</nobr> Auto Transport (identifiable by silver galvanized color).
    • Must have a maximum wheelbase (distance from front axle to rear axle, usually posted on the driver's side door jamb) of 133 inches.
    • Low-hanging equipment on the vehicle being towed such as spoilers, air dams, ground effects, etc., may be damaged by contact with the Auto Transport during loading and unloading. Make sure there is enough clearance for these items.
  10. Fogger
    Fogger
    I went to U-Haul to rent a trailer to get my roadster to the muffler shop. First question was "What is the make and year of the car and weight?" Told them it was a VW weighs 2000 lbs. Good to go. They didn't have any older cars listed on spec sheet. So if ZMAN's info works in California and your car is within the size limits it ought to be okay. Good luck, The FOGGER
  11. zman
    zman
    from Garner, NC
    I told them I was hauling an Acura
  12. Ian Berky
    Ian Berky
    Cool, but the only problem is nobody has a trailer big enough for my car it seems like. If i tell em' im towing a small jap car they'll give me a 10 foot trailer!! TOO SMALL!!
  13. U-Haul only has one size auto transport and your '51 will fit.
  14. Paul
    Paul
    Editor
    pictures of your car make it look very low
    can you get the car up a little?
    I hauled my new '52 home a couple weeks ago on a dolly
    might be easier to find
    and cost about half as much as a trailer too.
  15. Shifty Shifterton
    Shifty Shifterton
    You're towing a dune buggy, one that's too long for the 10' trailer. At least that's what I always tow. Well at least ever since they told me a 3/4 ton chevy with factory tow package and a 454 was not considered enough tow rig to pull an old toyota minitruck. "My dune buggy" is wide and needs the fullsize trailer, but only weighs 1200 lbs.
    good luck
  16. scootermcrad
    scootermcrad
    4 skateboards and some ducktape? ;)
    What's the word Ian? You HAVE to be super close to having this on the road. Where are you trying to transport it to?
  17. have you tried Sun Valley Rantals over on Lankershim between S.F. Road and the 5 freeway....
  18. zman
    zman
    from Garner, NC
    one more time in case you missed it. uHaul has one size of car trailer. my 38 buick fit fine. I'm thinking you 'll be ok. See the specs I posted above. And visit uHaul.com
  19. 61TBird
    61TBird
    When you go to UHaul,tell them you're towing a Corolla,Civic or some other small car.
    Keep the year between '90 an '99 and you'll be OK.
    I told them I was towing a Suzuki Sidekick when I rented one from UHaul a couple months ago.
    It also helps if you have a 3/4 ton truck OR a 1/2 ton with 4wd and the Factory Tow Package.
    I have heard the will NOT rent you a trailer if you have a Tahoe/Yukon/Expedition.
    If anyone has info to the contrary,please correct me.
    Also,IF it's not registered,you do have to tow it on a trailer.If you use a Tow Dolly,it needs to have current Registration to avoid a ticket from a "curious" P.O.
    Here's my truck and the "Sidekick" I towed.....
    (click on thumbnail)
  20. HotrodTrash
    HotrodTrash
    from Hanford,ca
    Yup, I tried to rent a Uhaul (one size fits all) trailer to tow my VW bug(56 dodge:)). They asked the tow vehicle type. Told them a yukon. Nope wouldnt rent it to me. needed a 3/4 ton or 1/2 ton with tow package. And they wanted to see it before they rented it to me. So went and got my friends doge truck, got the trailer took it home and hooked it up to my jeep.
  21. Horsepower67
    Horsepower67
    The U-Hual on Hollywood Way near the I-5 exit has always been friendly to me. I've used trailers from there several times without h***le.
    Yes, there is only one size car trailer.
    I usually tell them I'm towing a '62 Falcon 2dr.
  22. Big Khaunaa
    Big Khaunaa
    i hauled a 62 lincon on a uhaul trailer a 51 chev will fit
  23. John Denich
    John Denich
    Yup I have hauled my 51 on a uhaul trailer tons of time!!!! IT WILL FIT!!!!! YOUR MAKING IT TO HARD ON YOURSELF!!!!!
  24. Shifty Shifterton
    Shifty Shifterton
    Did Uhaul eliminate the small trailers over the last few years?
    It's been about 2 years since I've had to rent but at that time they had 2 different sizes of car trailers. Maybe they considered them the same for rental purposes, but there was a couple inches width difference between the trailer styles on that lot.
  25. pastlane
    pastlane
    Join AAA and then call for a flatbed. Whenever I go to county auctions around here that's how the majority of the cars get taken out.
  26. John Denich
    John Denich
    He is going to Kansas!!!!
  27. hotroddon
    hotroddon
    Tell em it's a Taurus. it will be similar sized and they actually know what that is.
  28. 61TBird
    61TBird
    Get the AAA Plus,the first 100 miles is "free" :D:D:D
  29. pastlane
    pastlane
    I didn't see that in his post... :eek: ummmmm nevermind
  30. Ian Berky
    Ian Berky
    LOL!! Thanx!!
